Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
Tire pressure - Blizzak LM-22's vs. ContiTouringContacts
I purchased a set of Blizzak LM-22's (in the 205/50/17 size) from Tire Rack for winter use on my 2003 325xiT Wagon, replacing my OEM ContiTouringContacts of the same size. I have been running the Contis at 37F / 42R, which is a tad stiffer than the door sill plate "normal load" rating of 35F / 41R. However, 42 seems a tad close to the LM-22's maximum pressure of 44. I expect to be doing a lot of sustained high-speed driving (cross-country, 500 miles or so at a shot, on interstates) and I'm worried about getting close to the max rating (which I assume is measured while cold). Gary (or anyone else), do you have any suggestions for both a) a good starting point and b) reasonable maximums for these tires on my car?
BMW recommends using the cold tire pressures listed on the tire placard/owners manual, but yours are close enough that I would not worry about it. The maximum psi on the sidewall is a cold psi, so no worries about it being too much after heat buildup of highway driving.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
