Old 10-26-2013, 10:11 AM
BigPhilly BigPhilly is offline
Mein Auto: 2001 BMW Z3 2.5i
Question 2001 Z3 2.5 it just clicks will not start
so i went out and my bat was dead. I jumped it and started right up. then the same thing happened it jumped again no problem. drove it home and parked it. i went start it again the next day and the same thing happened now when i put the cables on it to jump it, it just clicks and will not start. any help on this would be appreciated. I am thinking the ews and the dme? but i am not quite sure...
Old 10-26-2013, 02:14 PM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
You almost certainly need a new battery.
Old 10-26-2013, 03:02 PM
FZbar FZbar is offline
Mein Auto: 2002 Z3 2.5 Roadster
When the engine is running, do you get more than 12 volts at the battery? If you don't your alternator may not be working.
Fred
Old 10-27-2013, 11:18 AM
Kornknarr Kornknarr is offline
Mein Auto: -98 Mroadster S50 Estoril
New battery.
Old 10-27-2013, 11:32 AM
I cant get it started to test the battery. but if it was the battery wouldnt it start when i hooked up cables to it?
Old 10-27-2013, 12:14 PM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
You can't jump start a completely dead battery.
Also, did you clean the battery connections? Sometimes a "bad" battery is actually a poor battery connection.
Old 10-28-2013, 08:20 AM
Jortiz96 Jortiz96 is offline
Mein Auto: 1996 BMW Z3
Bad relay?
Old 10-31-2013, 11:08 AM
divinity divinity is offline
Mein Auto: Z3
I'm positive that it's a bad battery.
Old 10-31-2013, 04:24 PM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Originally Posted by BigPhilly View Post
... my bat was dead. I jumped it and started right up. then the same thing happened it jumped again no problem. drove it home... the next day and the same thing happened now when i put the cables on it to jump it, it just clicks and will not start...
The battery is not holding a charge.
You can test the battery in or out of the car with a pocket multimeter. Less than 12.5v means it's weak and much lower means it's bad. As to why jump starting no longer works, tell us more. You jumped it twice on the street from another car, then jumped it at home from another car, and the next day you jumped it from another car on the street and it just clicked? Is that the sequence?
Old 10-31-2013, 04:30 PM
Mein Auto: Z3 & X3
He certainly has a dead battery either because the battery is bad or due to a charging problem. That may explain why he had some minimal success in the beginning but none now.
I would also suggest that the battery, being left in a deep state of discharge for what I perceive to be days now, is permanently damaged and needs to be replaced in any case.
Old 11-02-2013, 03:09 AM
It was the battery. I thought that since it jumped twice it should have jumped again. Thank you everyone for your help. It is very much appreciated.
Old 11-02-2013, 04:55 AM
Mein Auto: Z3 & X3
Not necessarily.
The battery probably failed when some of the plates lost their mechanical strength and shorted to one another. This happens due to age, crappy manufacturing, or especially deep discharging.
Conventional lead acid car batteries (not marine deep discharge lead acid batteries) are not designed for a deep discharge, especially a prolonged discharge. Even leaving one of these batteries in a shallow state of discharge for just a short period of time will take capacity out of them as the un-reversed sulfate deposits harden. Car batteries are designed to always be fully charged. Their design basis is to only provide a lot of energy for a very short period of time to start the car and then be immediately recharged. If for whatever reason, the battery is found to be in a state of deep discharge, it is probably permanently damaged and will fail eventually prematurely. At best, if your lucky, the deep discharged battery, not immediately recharged, will no longer have its design basis capacity.
battery drain, dme, ews, no start
