Headlights update - Bimmerfest - BMW Forums
Old 05-05-2010, 06:01 PM
krischapel krischapel is offline
Mein Auto: 2012 640i Alpine White
Headlights update
just got back from getting rid of the piece of crap town and country and picking up my car. the total they wanted to charge me for my lights was $8,200. main charges were
2x headlights-$3,144
2x control unit xenon (ignitors)-$1,149
2x xenon bulbs-$554
1x light module-596
taxes-$547
labor-$1,400
the other $810 is a bunch of misc items.
obviously i know i can do this for "A LOT" cheaper. does anyone know where i can get any of these items for cheaper? i know some people replaced their headlights for 250 each. does anyone have their stock pair headlights? or can anyone point me where i can find these items at a much lower cost? thank you in advance.
2012 640i Alpine White, M Sport, LED Headlights, Premium Sound, Ceramic Controls, HUD, Lane Departure, Contour Seats, Blind Spot
Old 05-05-2010, 06:06 PM
OneNightStan OneNightStan is offline
Mein Auto: 645ci
Why do you need to replace the headlights and xenon bulbs, shouldn't your old ones work?
I would imagine you only need:
1x light module-596
at most...
Old 05-05-2010, 10:22 PM
kaveiki13 kaveiki13 is offline
Mein Auto: BMW
HI, I can not understand why they want to change your headlights ? does anything is broken there? I believe that the main problem is in light module. Go to the repair shop that you can trust, they can test ignitors and bulbs, you can do it buy your self, but you will need to remove headlight and power it up directly from battery or from other 12V source.
when you will change light module, your car will need programming.
Old 05-06-2010, 04:41 AM
chasz17 chasz17 is offline
Mein Auto: x5 4.4i
Do you have adaptive headlights?
Old 05-06-2010, 04:53 AM
Yes I do. Y?
Old 05-06-2010, 05:40 AM
Mein Auto: x5 4.4i
Since you have A.H. and based on the diagnosis, you do, in fact, have to replace what was listed. I had a failure of the light module which took out the stepper motor in one of the headlight buckets. The headlight bucket is a sealed unit and the stepper motor cannot be replaced on its own. While you have a different cause of failure, it sounds like the end result is the same. The total cost of the repair was was somewhat over $3200. I have an extended warranty that picked up the tab. Since I suspect you don't, but probably have auto insurance, you might want to call your agent.
Old 05-06-2010, 07:38 AM
FLIGHT20THREE's Avatar
FLIGHT20THREE FLIGHT20THREE is offline
Mein Auto: 2004 BWM 645ci
Good lord, that cost is out of this world.....is your car under warranty?
Old 05-06-2010, 07:48 AM
Mein Auto: x5 4.4i
You do not want to have something serious fail on one of these cars without some sort of financial plan in place. These are not easy cars to fix and some of the parts are very expensive. For us that have the 'vert, some failures can cost over $10,000 to fix the top properly. The amp for the sound system is $1100. Forget a serious mechanical issue with the engine.
If you cannot afford a hypothetical $4000 to $5000 repair, perhaps you shouldn't own the car.
Old 05-06-2010, 08:28 AM
My warranty will not cover it becuase an aftermarket part is the reason why they do not work. And that aftermarket company has not even refunded my money for the bulbs like they said they would
Old 05-06-2010, 08:29 AM
NWS Alpine NWS Alpine is offline
Mein Auto: 650i
I would start with the 2x control unit xenon (ignitors) and see where that gets you. I opened up my lights to paint the reflector and when i installed them back in the car had all thses failures. After a power cycle of the battery the lights came back except I had an adaptive light error and the lights wouldn't turn laterally. I power cycled a couple of time and now everything has been working 100% for months. Seems like the lights can have issues clearing codes when they lose power.
I tried the power cycle after talking to an angel eye installer down here who said they run into this frequently and a power cycle until it's fixed is the only solution.
2006 650i - SMG - Alpine White / Chateau
Mods: OEM style 249 19" rims, H&R 10mm front spacers and 12mm rear spacers, KW v3 coilovers, Magnaflow exhaust (x-pipe, mufflers, resonator delete), RPi scoop, BMC filter (charcoal delete), LED angel eyes, 30% tint, OEM iPod interface, AC Schnitzer aluminum pedals, black kidney grill
Old 05-06-2010, 09:24 AM
great to know thank you so much!!!
Old 05-06-2010, 09:30 AM
TimDogg's Avatar
TimDogg TimDogg is offline
Who u r, u r forever....
Send a message via Yahoo to TimDogg
Mein Auto: 2004 645ci 2008 535i
this is not good news...... for my adaptive headlights no longer adapt! They still auto level on initial start up but that is all the movement they are now capable of. Dealer looked at em and said the internal gearing is jammed and that the entire unit needed to be replaced.
In the garage, when i turn the wheel i can see them "bump" like they are trying to move but there is no lateral movement at all, so gearing seems like it might be the issue!
DAMN....
Yes, I collect stamps....PASSPORT STAMPS!!!
Red 1998 Ferarri 355 Berlinetta F1, Black 2004 645ci, Space Gray 2008 535i
Old 05-06-2010, 09:42 AM
BlaZinMJ3's Avatar
BlaZinMJ3 BlaZinMJ3 is offline
Mein Auto: GranTurismo, RR Sport SC
i would never own this car out of warranty, its just too expensive. next year im selling this baby and getting something else thats under warranty
2013 Nero Carbonio Metallic Maserati GranTurismo MC Sport Line
2012 Valloire White Pearl Mica Range Rover Sport Supercharged
Old 05-06-2010, 11:35 AM
djmatrix djmatrix is offline
Mein Auto: 2005 645 Convertible
Cant you do a search and get some of those parts used ? I really feel for you man. This place claims to have parts from slavaged BMW's..http://www.bmrparts.com/index.htm. Good Luck Bro...
Old 05-06-2010, 08:23 PM
WU99WU WU99WU is offline
Mein Auto: 05 645ci 07 335i cpe
Damn!...
DAMN!... homie i feel bad for you! don't get bopped like that over some headlight bs... start with the ignitors like the other guy said! i installed some 10k headlight bulbs once and i accidentally broke one... cost me like $150 at the dealer! felt like a dumba**!... so buy these 1st, then take it from there... also buy some new d2s bulbs, i bought mine off ebay and they work great, had them almost 1yr now!
http://cgi.ebay.com/ebaymotors/04-07...item35a8e3e23b
http://cgi.ebay.com/ebaymotors/BMW-E...item20b0d31bd2
http://cgi.ebay.com/ebaymotors/BMW-E...item20b0d31bf1
Old 05-06-2010, 10:28 PM
docpaulo docpaulo is offline
Mein Auto: 07 650i Convertible
http://cgi.ebay.com/ebaymotors/BMW-X...Q5fAccessories
not sure if you needed this module as well, but the first seller above is selling this too..
07 650i Cabrio CPO, Titanium Silver
Black Matte Grill
Dark Birch Wood Interior and Shifter
HUD, Cold Weather and Sports Package
Logic 7 Sound
Aluminum Racing Pedals
K&N Air Filters
Rays Master Piece REM 20" Forged wheels w/ Conti Extreme DWS
Old 05-07-2010, 01:40 AM
Mein Auto: 645ci
A lot of helpful people on this forum.
Old 05-07-2010, 06:47 AM
BlaZinMJ3's Avatar
this is the best 6er car forum hands down!
Old 05-07-2010, 07:21 AM
yes there is and i am thankful for that!!!
Old 05-07-2010, 08:54 AM
daxxkid daxxkid is offline
Mein Auto: 05 645
Good luck with the fix buddy, keep us updated please
Old 05-07-2010, 09:54 AM
Will do. I bought the ignitors of eBay last night. I know I need new ignitors for sure
