Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
Your car has a positive offset wheel. That means that the center of the tire is more towards the center of the car than a zero offset wheel. If you went to a wheel with a 40mm positive offset, your tires would be 7mm more towards the outside of the car than your stock wheels. This generally makes it look like the tires and wheels fill in the fender wells more, and will probably have some slight effects on the handling. Also, tire size becomes more critical; you probably won't be able to use quite as wide of a tire as with the stock offset. |
The above example is right if the wheels are the same width
In other words a 16" x 7" wheel with a 40 offset with be pushed out further then a 16" x 7" wheel with a 47 offset but if the width changes then you need to figure out the difference . . . For example a 16" x 7" wheel with a 40 offset is not the same as a 16" x 8" wheel with a 40 offset . . . the 16" x 8" wheel will stick out approximately 12.5 millimeters more (a 1/2" ). The offset is measured from the center of the wheel EDIT: had equation incorrect, but is now correct . . . Man does this get a little complicated ... Last edited by AF; 11-09-2003 at 10:11 AM. |
Thanks . . . sometimes this gets so confusing |
Ah ok . . . starting to be more clear!! Thanks. Now naturally I would want the offset to be as close to factory specs as possible. My OEM wheel has a offset of 47mm (style 54 wheels). On my snow tires the offset is 40mm. Is that difference significant? Also what bad consequences are there having wheels not to factory specs? |
You don't have to stay with the factory specs . . . there is actually a certain range you can stay within and have no problems at all . . . |
Sure . . . OEM= style 54 wheels (v-spoke) 16 x 7 with 225/50/16 tires 205/55/16 snows on Sport Edition TK5 wheels also 16 x 7 |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
