E90/E91/E92/E93 (2006 - 2013)
Old 05-19-2010, 10:28 PM
Fredric Fredric is offline
Mein Auto: '07 328xiT
CA, I am truly sorry about your tire experience. But what I am most curious about is what might have caused you sidewall to rupture like that, without your being aware of it. IIRC your first awareness of it came when the tire pressure warning light came on.
Old 05-19-2010, 10:36 PM
captainaudio's Avatar
Worlds Foremost Authority
Mein Auto: 335i E93 - 750Lix
I really have no idea. I do not recall hitting any major potholes. I was very surprised when I got the warning, The rupture was on the inside wall of the tire so the damage may have been there for a while and I just did not notice it.
CA
Drivers Club at Lime Rock
The Glen Club
BMWCCA
Cayman Club Nor'Easters
Sports Car Club of America
American Mural Project
Old 05-19-2010, 11:00 PM
Originally Posted by tturedraider View Post
Couldn't mount the donut tire on the donut rim? I'd love to hear their explanation for that.
I'm not aware of any car manufacturer that designs their RFT designed cars with provision for a spare.
I believe Maserati may but I can't find any documentation,
The Glen Club
BMWCCA
Old 05-19-2010, 11:03 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
CA
likely you hit a pothole that bubbled the inner sidewall. hitting a mild bump in the same spot is enough to rupture it for good. happened once, drove on a bubble, managed to hit a very mild ridge in the road in just the right spot, instant pressure loss.
i've had to use my compact spare 4 times so far across both cars.
in all the cases, as you are likely to find in NYC, the damage causing the flat was severe enough that the conti kit i carry in the trunk would have done nothing. lets face it, in NYC, you're most likely going to be dealing with sidewall damage or a bent/cracked rim. i've never gotten a normal puncture in the past 10 years. every instance has been a catastrophic failure of some kind.
i will say that after the last one, i went with a higher profile tire. still running 19s, but my overall diameter is close to 26" versus the standard 25" 3.5" of sidewall, same as running 18s.
the conti kit is, for what you will encounter in NYC, useless. more likely than not, its going to be a pothole or plate or some other road hazard that does you in, and it wont be tread damage, it will be sidewall/ rim damage.
any thoughts of putting on 17s?
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 05-20-2010, 03:06 AM
pony_trekker pony_trekker is offline
Mein Auto: 328xi
Now you know why I only drive my Subaru into the city.
Old 05-20-2010, 03:46 AM
minicrazy592's Avatar
minicrazy592 minicrazy592 is offline
about the mini part....
Send a message via Skype™ to minicrazy592
Mein Auto: E90 M-tech, E30 M-tech
CA here are my thoughts on some of what you said in your original post.
Low profile tires/large rims-
BMW uses the size rims, on the 335i for example, for a reason. You have pretty large brakes if you took a look. They are fundamental requirements for a powerful or performance vehicle, I mean look at 60s and 70s muscle cars and see how many went into a tree because they couldn't stop from the speed they were capable of achieving.
As for the tire, it comes with the territory. A big thick tire will not fit in the fender wells of the typical BMW, at least not the 3er. The RFTs came out of necessity for weight and weight distribution I believe. Obviously it couldn't be to cut cost. Their "defect" of not being able to handle rough roads isn't exactly the tire's fault. It just comes with the necessity of the design. Most roads, at least in the US, are not in the best of shape. Most road hazards on these roads can be avoided if the driver tries to do so, let alone normally aren't an everyday occurrence. So how can a tire manufacturer design a tire that needs to be stiff to meet the design requirements and be able to handle large, destructive side wall abuse and flex? In all reality, they can't. Technology can only go so far and designing for instances that do not happen all that often can not be a deciding factor when it only affects maybe less than 5% of users. So 5% of dissatisfied customers really isn't that much to a corporation when the other 95% of users are content or have accepted that something can and may happen. The latter is my mindset and also why I have insurance on my rims and tires for such an event.
Suspension-
You drive a BMW. If it wasn't for that suspension you hate, it wouldn't be what makes it a BMW. The camber is what makes it drive like it does. You can't have proper handling without a little bit of camber, a live rear axle car is proof of this, a few cars being an exception of course. Then there's the stiffness that ties into that camber, once again a design tradeoff. Regardless you should expect things to not last as long on a high maintenance car, that is why it is a high maintenance car in the first place. In this price bracket that these cars are in, to some degree, BMW expects their customers to have some "disposable" funds for things such as this. $600 for a set of tires every 2 years or so should not be a burden to someone who buys a $60k automobile.
Where you live-
It is your own fault for having a car that doesn't suit your surroundings or requirements. For example, people who live in colder climates with lots of snow often have AWD or 4 wheel drive modes of transportation to help cope with that and a set of snow tires in the garage in addition. By the sound of it you should have a car with thick tire side walls.
My biggest thing is that you are complaining about, at least what it seems like to me is, your weekend car. A weekend car isn't meant to be practical, that's why it is a weekend car in the first place. If your weekend car isn't practical enough, then I don't think you need a weekend car in the first place IMO.
I apologize for the negative tone of this post, but this is my opinion of your circumstance.
-J.T.
Will be missed: 04' E83 M54B30
Old 05-20-2010, 04:07 AM
Mein Auto: 328xi
Given the current state of NY roads, I think this may be my next car:
Body on frame construction works in NYC.
Old 05-20-2010, 04:08 AM
Lather up an accent then.
-J.T.
Old 05-20-2010, 04:20 AM
supermick supermick is offline
Mein Auto: 08 335i coupe 6mt
Question? Do you think the high pressures you run lead to this mishap?
Can you give me your new short list of the 335i replacement.
THanks
Old 05-20-2010, 04:37 AM
jmsent jmsent is offline
Mein Auto: 07 335i Coupe
CA
Every time I drive the NY metro area, I feel like I'm in a war zone. Driving a ZSP equipped BMW there has to be a real crap shoot. After reading your complaints over the past couple of years, I'm surprised you haven't considered going to a 17" wheel/tire package instead of sticking with 18's. This, combined with perhaps bumping up the sidewall profile to a 50 series tire would go a long way towards preventing a lot of damage along with improving the ride quality substantially. It would also make the speedo more accurate. A softer riding tire like a Turanza Serenity or Conti DWS would also make a considerble difference. Yes, you sacrifice a bit of handling, but in your case that sounds like a reasonable compromise.
07 335i COUPE-SPACE GRAY-STEP-SPORT-PREMIUM-COLD-SIRIUS-RFT DELETE
Old 05-20-2010, 04:43 AM
Suspension-
Where you live-
1. What does a lack of practicality have to do with regularly blowing out tires? That is not a lack of practicality, that is a lack of reliability.
2. Drive around the potholes. Thanks for the tip. That would never occured to me.
3. What relevance camber has to this issue escapes me.
4. "BMW expects their customers to have some disposable funds". Once again thanks for the tip.
The assertion that in order for a car to handle properly it has to have a rock hard suspension and the ride quality of a covered wagon is not valid. As a matter of fact, as many here have noticed, the extreme stiffness of the OEM Bridgstone RFTs is detrimental to handling. They bounce around on bumpy curves and the contact patches loose contact with the road. I am certainly not the only one here who has had this issue.
http://www.bimmerfest.com/forums/sho...ole+explosions
CA
The Glen Club
BMWCCA
Old 05-20-2010, 05:01 AM
THanks
That occured to me but I am only running 3 or 4 PSI above the recommended pressure and should be well within the specs of the tire. Also it happened on a wet chilly morning and I has not driven the car very far so they were not hot. I suspect the damage may have been there for a while and gone unnoticed since it was on the inside side wall on a rear tire.
I was very frustrated when I posted last night but I think I verbalized what a lot of BMW drivers have felt at one time or another. I should have said "I am extremely frustrated by this car" rather than "I hate this car".
I expected to get a certain amount of "BMWs are perfect, how dare you criticize them" responses but as many have posted here the RFTs, while good in theory, are not all that great in execution. I would be interested in seeing how the new third gereration RFTs are but so far they are not available.
Not sure what I will get next or if (in spite of my rant) I will explore options such as Koni FSD shocks, donut spare, etc. for the 335i.
CA
The Glen Club
BMWCCA
Old 05-20-2010, 05:05 AM
DSXMachina's Avatar
Automaticallyparsinglinks
Good morning Captain. Just tuned in. Don't do anything drastic until after The Climb. I promise you good roads in NH, and you'll have the P9'ers to discuss some of your options with.
If you have tire trouble here I will lend you a mounted tire with BMW wheel until you get back to the City!
Here is a pic of my car next to what I drive into NYC.
Old 05-20-2010, 05:10 AM
AF AF is offline
Here since day one
Mein Auto: 535ix, GL450, 991S
OP - Read Here, above suggestion is your solution ... seriously !!!
This is exactly what I was thinking, the difference in ride comfort from the 17" standard wheel to the 18" sport wheel (both with run flats) is huge IMO. The 18's are very harsh and I never felt to provide as much grip as they should have for a high performance tire.
I had both when I had my 335i ... with that said if you still want out of the BMW you should consider looking at the C350 ... I have one and the ride is much smoother there are no run flats, it comes with a spare tire but it also provides the similar type of drive that the 3 series offers.
Anyway OP I am not a fan of the run flats but BMW designed the suspensions around them and I like the safety factor if god forbid there is a blow out which is why I keep them on the 650. Hopefully the next generation of runflats are coming soon and will hopefully work out the negative kinks.
Best of luck and sorry to hear of your problem.
Old 05-20-2010, 05:23 AM
I have a solution. I just hired this guy to follow me around.
CA
The Glen Club
BMWCCA
Old 05-20-2010, 05:25 AM
E92Submarine's Avatar
E92Submarine E92Submarine is offline
Officially Contaminated
Mein Auto: 2009 E92 335i
I guess I went to bed a little too early last night to miss these shenanigans!
CA, all RFT arguments aside, you're lucky you weren't killed on the side of the Saw Mill. Too be honest, I always thought you were a little nuts running 19" wheels in NYC regardless of the tires on the vehicle. Even when we had the 328xi sedan with 16" wheels, the GF and I would always opt to take her SUV down to Presbyterian Hospital.
2009 E92 335i | 6MT | Black Sapphire | Black Dakota | Aluminum Trim | Premium | Sport | Heated Seats | PDC | iDrive | HD Radio | M-Sport Shift Knob |
Old 05-20-2010, 05:29 AM
Majikthese42's Avatar
Majikthese42 Majikthese42 is offline
Philosopher-king
Mein Auto: E91, Volvo, Porsche
Highway maintenance has been a basic function of government since the Roman Empire. I'm not sure what happened to Roman highways during the "Decline and Fall" but I can imagine it's something like this. Today is May 20, and I'm planning on switching from my 16" winter tires and wheels. This is an all-time record. I don't blame BMW, however. I blame the people who I'm paying to maintain the roads and who aren't doing their jobs.
I won't drive a car into NYC. New Jersey is bad enough.
BTW, this is an "original" BMW 325 convertible. It looks like it would do OK with NYC potholes. Maybe BMW should dust off the old plans.
E91 "Classic" BMW inline six, six-speed manual transmission, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
Old 05-20-2010, 05:37 AM
LawrenceSmith LawrenceSmith is offline
Mein Auto: 335i
I feel for you. I want to take the 335 to to New England this summer but I'm not too interested in having a similar experience to yours. I've still got the RFT's on but it doesn't really matter as if I have a problem the best outcome is I can go a few miles down the road before I'm screwed. Let's see... wife, kid me all stranded somewhere on 95. Nope, doesn't sound too attractive.
Lawrence
08 335i Sedan Steptronic AT|Sport|Premium|Alpine White|iDrive
10 VW Jetta SportWagen TDI
I let the pieces lie just where they fell.
Old 05-20-2010, 05:38 AM
DSXMachina's Avatar
I saw a picture of a whole string of those 'verts driving under L'Arc de Triomphe.
(Kind of an ironic name for it at the time.)
Old 05-20-2010, 05:42 AM
I am running 18s. I got rid of the RFTs but I am on style 196 rims that are the same size as the 189s that came with the car and the tires are the same as the OEM size as well.
CA
The Glen Club
BMWCCA
Old 05-20-2010, 05:48 AM
CA
Ah, my mistake. They looked larger. You say you've been able to bend one of those rims? One would think a 14 spoke (If I can count this morning) wheel would be hard to bend.
How does Mrs. Audio's Jaguar perform on the same roads?
Old 05-20-2010, 05:52 AM
thekurgan's Avatar
thekurgan thekurgan is online now
Bad Lieutenant
Mein Auto: S65B40 Powered
CA
It will be sorry to see you go. I agree that the later BMWs have had some quality issues and decisions made with respect to the vehicle "features" are in reality reliable only for 4 years or 50k miles. If you decide to stay with BMW, look for an E34 535i, those things are bulletproof and put the would-be car payment into restoration of one of the best BMWs made (5MT of course!).
08 E90M3 6MT Alpinweiss/Schwartz
Old 05-20-2010, 05:55 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
CA
If you are exploring 'other' options, I would add 17 inch non-RFT tires (and obviously wheels as well) to your list of options.
Old 05-20-2010, 05:56 AM
There is no comparison. The Jaguar is much better at handling bad surfaces.
The pothole that I hit when I bent the rim was extreme. It was more like a crater. There was a section the full width of the lane and about 10" deep with sharp edges. There was a large truck in front of me so I did not see it until the last moment. I could not steer around it because there was a car in the lane next to me. In that case I don't know of any car that would not have taken a hard hit. The rim bent and the tire bubbled but it held air and I was able to drive back to the city.
CA
The Glen Club
BMWCCA
Old 05-20-2010, 06:01 AM
SeeYal's Avatar
SeeYal SeeYal is offline
In Heaven
Mein Auto: 2008 535i - 2008 750LI
I feel your pain, Cap! It has been 2 years for me - just got my pen - and I am down 2 rimms and 2 tires... AND I DRIVE 90% ON I-10...
2" pothole at 80-90 mph does not forgive... when it is not some other junk... it really comes down to that BMW are built for countries who have autobahns, not farm roads...
I am going back to a silverado, or a denali in 10 months...
