Old 08-26-2013, 03:11 PM
milovanov milovanov is offline
Mein Auto: 2002 BMW M3 Conv
Re: Bmw x3 FAQ And DIY compilation
The front is also in different incline as the transmission case. So there are 4 different levels you can measure. I would like TIS doco that shows which to level.
Sent from my SCH-I545 using BimmerApp mobile app
"Only after disaster can we be resurrected," Tyler Durden
CURRENT: 02 M3 conv, 06 k1200s
Family: 04 X3 3.0, 98 M3 2dr
Old 08-26-2013, 05:03 PM
Grabby544 Grabby544 is offline
Account closed at users request
Mein Auto: 2009 X3
Dude, jack the car and level it to the point that the vehicle is parallel to the ground. Just like you were driving it on a level surface.
I think that you are splitting hairs, you'll have to down jack the vehicle or shift it on jacks to warm up the fluid and check it again.
I just checked my Bentley's for the E9x series, and it doesn't even specify. It only says "Raise Vehicle and support safely"(pg 240-8).
So... I assume (and take it for what its worth, I am a Fighter Aircraft Mechanic not an ASE mechanic) to level the car, like it was resting on the ground on a flat level surface.
Old 08-26-2013, 05:28 PM
You right, I may very well be splitting hairs. But i'd rather to be overly cautions than not cautious enough. Anyone get to TIS before it got removed from the web?
Old 08-26-2013, 06:15 PM
Sorry for multiple posts, but here is another though. How would I know the transmission is level the same as it was when car was new? Suspension settles and at times not evenly. So what is the height from the ground to jack point on front and rear?
Old 08-27-2013, 08:24 AM
Mein Auto: 2004 X3 2.5i
Note that this sticky thread is intended to be a place where you can look up specific things. Debate and discussion should be in one of the regular threads.
Fuse template for 2004 - 06 models:
Old 11-08-2013, 07:35 PM
neosimago neosimago is offline
nsmgo 2006 X3
Mein Auto: 2006 X3
It Works! :)
Originally Posted by enamoured View Post
Just thought I would add my 0.02.
If your sunroof gets stuck or moves only a couple of inches with every full push of button (when it should normally move all the way) you would want to reset it before calling dealer. To reset, turn the key to position 2, don't start the car, press the sunroof button "up" (where you press it to open in tilt position) and hold it there, after about ten seconds the sun roof will cycle through entire open and close cycle, do not leave the button till it completes the cycle. The sunroof is now reset.
Thank you so much for the info!
8-)
More information shared please.
Old 01-21-2014, 10:17 AM
ArunSingh ArunSingh is offline
Mein Auto: BMW X3
Question Bmw x3 2004 headlight unit
Question,
Headlight assembly on 2004 x3 is identical to later model or there is any difference . I am planning to install one with angel eyes.
Old 01-21-2014, 10:34 AM
Originally Posted by ArunSingh View Post
Question,
With respect, this "Sticky" thread is for documenting DIY solutions, not for asking questions.
You should have just searched on "angel eyes retrofit" and would have found this:
http://www.bimmerfest.com/forums/sho...d.php?t=646174
Note that there are variations in how you go about it depending on model year and trim level (e.g. 'M' Sport option in 2006 has different bumper design from your 2004).
Not an easy project by the look of it.
Old 02-15-2014, 09:15 AM
mtblantonjr mtblantonjr is offline
Vi Regional Director
Mein Auto: 2008 BMW X3
Exclamation
I just posted a question in the X-3 2004-2010 post about a wiper arm issue. If anybody can check out and help... Thx
Old 04-22-2014, 08:19 AM
kenza kenza is offline
Mein Auto: 2007 X3 2.0d MT
X3-t,
Here is the link to the Clutch and Dual Mass Flywheel replacement DIY:
http://www.bimmerfest.com/forums/sho...d.php?t=766846
Old 04-26-2014, 07:06 PM
woofster woofster is offline
Mein Auto: BMW
Excellent sticky. Just joined this forum to say that! And I'll probably stay for a while...
Old 06-29-2014, 10:11 PM
kevo409 kevo409 is offline
Mein Auto: 325I
I have a 2004 X3 with an M54 engine. I purchased it it recently and noticed that where the intake temperature sensor is there was a broken-off plug. I have looked for a 2-prong, loose wire somewhere but am unable to find it. My question: does BMW put a small-diameter hole, exactly 1/2 way in the middle of the intake ONLY TO PLUG IT? To me that wouldn't make any sense! There was only a broken plug/cap where the temperature sensor SHOULD HAVE gone! So please give me your thoughts! Why put a hole in the intake only to plug it?Click image for larger version
Old 06-30-2014, 06:57 PM
herc63 herc63 is offline
Mein Auto:
Old 07-01-2014, 04:31 AM
ngcreese's Avatar
ngcreese ngcreese is offline
Mein Auto: '11 X3
Originally Posted by kevo409 View Post
I have a 2004 X3 with an M54 engine. I purchased it it recently and noticed that where the intake temperature sensor is there was a broken-off plug. I have looked for a 2-prong, loose wire somewhere but am unable to find it. My question: does BMW put a small-diameter hole, exactly 1/2 way in the middle of the intake ONLY TO PLUG IT? To me that wouldn't make any sense! There was only a broken plug/cap where the temperature sensor SHOULD HAVE gone! So please give me your thoughts! Why put a hole in the intake only to plug it?Attachment 448874
Try looking up your X3's engine/parts blueprints on www.realoem.com
'11 X3 xDrive35i -- Coded
'07 X3 3.0si -- Coded & Traded
'91 e30 325i -- Sold
BMWCCA Member
Old 07-13-2015, 05:06 AM
janicejcm janicejcm is offline
Mein Auto:
I just got a 2008 BMW X3. The sat nav won't update as wrong software and the phone won't pair either don't ask me why even the garage say it's not likely to work so uselesd how can get it to actually work??!!
Old 11-20-2015, 12:36 PM
jlex jlex is offline
Mein Auto: 2005 X3.0i
Wow... this thread just isn't working right...
Old 02-15-2016, 07:02 PM
Earlybird Earlybird is offline
Mein Auto:
Carbon air filter delete along with opening exaust valve and dropping in a afe pro dry filter are three mods that increase performance in my book if done as a unit, but are also 100% reversible, so there's zero reason not to try. If done tho, reset adaption and give it a few days to figure out the timing Click image for larger version
ID:	550958Click image for larger version
ID:	550960Click image for larger version
Old 03-10-2016, 06:57 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
2006 X3 Rear Differential oil change
This is a 'lifetime' oil but at 137k I decided I would refresh it.
I put the car up on ramps, and cleaned the two 14mm internal hex drain plugs. I couldn't find my hex bits, so I used a 9/16 inch SS bolt with two locked nuts to remove the drain and fill.
The drain was easy, the fill I had to drop the spare and work through the dropped spare tray to get the tool onto the fill plug.
I drained the diff for one hour - one drop every 60 seconds or so.
I filled with Mobil SYN 75W-90 gear oil using a pump and it took 1.5 liters +-200 mL before dripping.
Old 06-24-2016, 07:29 PM
Shuralee Shuralee is offline
Alex
Mein Auto: 2008 X3 E83
LED Headlights retrofit, any suggestions?
Hi all,
I got a 2008 X3 with original halogen lights, the light pattern is weird and very diffuse. I was wondering if anyone had luck installing Putco or similar H7 LED bulbs with a resistor to fool the Canbus. Any suggestions would be greatly appreciated!
My interior lights are all LED now, much cooler and brighter lights, perhaps it's time to ditch the halogens in the front.
Best,
Al
Last edited by Shuralee; 06-27-2016 at 05:48 PM. Reason: perhaps, wrong thread... Re-posting as a new thread in E83 Forum
Old 09-19-2016, 09:13 AM
lovemotorbikes lovemotorbikes is offline
Mein Auto: 04 3.o x3
oil leak,
hi all, does anyone know if there is a common fault causing an oil drip drivers side engine bay, on my 04 x3, 3.0l petrol, cant see anything in engine bay, but spots the drive, not a lot, but little hot oil goes a long way, rgds dave
Old 09-19-2016, 09:15 AM
x3brian x3brian is offline
Mein Auto: X3
Two common places to look are the oil filter housing gasket or the valve cover gasket.
Old 09-19-2016, 10:16 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
a nice VITON gasket for the oil filter housing
see if you can get the gasket .....only a few bucks .....in VITON .....much better than original
http://blog.bavauto.com/17487/tired-...e-problem-ofhg
Old 09-30-2016, 05:49 AM
rbelton rbelton is offline
Mein Auto: E39
Transfer Case Gear
Old 12-18-2016, 01:17 PM
Attacking Mid Attacking Mid is offline
Mein Auto: 99 328i, 08 X3
Rear Differential Input Pinion Seal Replacement
I didn't see any DIY for this job, so I took a few shots while I did this job and will offer some thoughts from what I learned in the process.
Overall the job is not too bad. It took me way longer than it should (first time that's ever happened ;-) ) due to chasing down a tool that ultimately, I didn't need. More on that later.
Below is a shot of my oil-covered differential. The output shafts don't appear to be leaking, but the input shaft (pinion) seal seems to be spewing oil everywhere. Not only is this messy, but there is the risk of running low on oil resulting in differential replacement.
No need to drop the exhaust to do this job. You will need to remove several of the small bolts holding the heat shield in place, then bend the heat shield back to allow access to the driveshaft mount.
I removed the rear-most exhaust hanger nuts just in front of the rear bumper to allow the exhaust to drop a little for added working room.
The aluminum support needs to be removed. It has several kinds of fasteners, but none of them presented a problem. Simply remove all the bolts and wiggle the support out of the way.
Remove the 4 driveshaft bolts. It's easiest to remove the bottom two, then jack up one wheel, loosen the parking brake, shift to neutral, then rotate the rear tire to spin the drive shaft 180 degrees to get at the other two bolts. I like to use a sharpie and mark the flanges so I can reinstall exactly how it came apart.
The driveshaft has enough space to be pushed aside so you can access the flange nut. Before removing the nut, Mark the nut and the flange so you can retighten the flange nut precisely where it was. This nut is tightened from the factory against a crush washer inside to provide a precise amount of lash in the gears. You cannot "retorque" this nut - rather you should only put it back right where it was.
The flange nut played a trick on me resulting in a bunch of wasted time. It is a 30mm nut, and I only have an impact (thick walled) socket in that size. My impact socket was not even close to being thin enough to fit, so I hopped in my trusty e46 and headed to Autozone to rent a socket. Unfortunately, the AZ socket was still too thick to fit. I ran around to several stores with my dial caliper in hand searching for a socket thin enough to work. Finally, I resorted to buying a 12 pt socket and grinding it down to fit. After that, I was able to remove the nut with my 1/2 impact wrench. As the nut came out, this extra random piece cam with it. I have no idea what the purpose of this piece is, but it fooled me into thinking I needed an ultra-thin walled socket. This piece slips over the head of the nut. You should remove this piece before removing the nut and then you should be able to use a normal 30 mm socket without grinding like I did. See,... that little tidbit alone was worth the cost of admission to this post!
The flange came out with a simple pry of my big screwdriver. Yours could be stuck requiring a puller, but it's a splined slip fit, so it shouldn't take much to get it off. I pried the old seal out with a big screwdriver, cleaned up the flange with some dull emory cloth, then greased up the new seal and used the flange and old seal to help drive the new seal into place with my brass hammer. I couldn't quite get it driven all the way mostly due to limited space for my hammer swing. I finished it up by tapping around the circumference with my hammer until the seal was flush all the way around.
Tighten the flange nut back to where it was, and reinstall the stuff you removed for access.
I plan to spray the diff with degreaser and wash it off so it's not so grungy. Then I'll let my wife drive it for a couple days before changing the fluid. That way any contaminants can be sucked out with the old fluid.
AZ has the best option I've found for differential fluid. They carry Chevron Delo 75w/90 for $5.99/qt. It's a full synthetic gear oil sans the LS friction modifiers which our diffs don't need. At that price, you can change your diff fluid with every motor oil change!
Hope this write up helps someone. I appreciate all the others on here who have shared their experiences with various jobs. It really helps to know what you're getting into beforehand.
AM.
Old 01-02-2017, 03:58 AM
jamies-h jamies-h is offline
Mein Auto:
Thank you. Great post!
Sent from my iPad using Bimmerfest mobile app
diy, e83 x3 maintenance, x3 fuel filter replacement, x3 starter replacement
