Old 05-22-2010, 03:04 PM
dbill0215 dbill0215 is offline
Mein Auto: 1998 740i
98 740i - Electrical issue
Over the past few weeks, various electrical issue have begun to crop up. My back up lights would not work. My inside blinker signals would not work. The LED display on the front dash and then the radio went blank. My radio would stop when it felt like it and then come back on. My car would not start on the first try but if you sat there for a minute with the key on and then shut if off and then on, it would start. The horn would work some times and not work others. Last night it finally started to get bad. It took me almost 5-10 minutes to get it started each time. The last time when it started, the radio would not work, the windows would not work. I have it now parked in my garage and somewhat leary to take it out again. Any thoughts on what this is. When you go to start it and it does not want to start, you can hear a faint electrical noise like a wire is loose. Any thoughts would be appreciate.
Old 05-22-2010, 03:18 PM
Bimmer750LI's Avatar
Bimmer750LI Bimmer750LI is offline
Mein Auto: 750Li
Likely needs new battery and registration of new battery to get charging system in sync with such. It could also likely be the ignition switch. If the battery is new and it's not the ignition switch then there is likely a charging system problem, alternator or power management control unit. I'd say the ignition switch and/or battery is a good 1st shot.
Old 05-22-2010, 09:01 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
wouldnt be a bad idea to check the cranking amps of your battery. i know that messes with these computers. it quite rediculous how it affects the car.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 08-27-2010, 08:03 PM
Afterburner Afterburner is offline
Mein Auto: 1995 740iL
Sometimes a faulty ignition switch can give such vague symptoms.
HTML code is Off
