Window wont Auto Up - Bimmerfest - BMW Forums
Old 05-22-2010, 06:12 PM
Payback's Avatar
Payback Payback is offline
Mein Auto: 97' 740iL
Window wont Auto Up
I recently replaced my passenger mirror. After reassembling the door, I tested the window and mirror. Both operate fine. However the window will not do the auto up function. I actually have to hold the button to make it go up.
Is there any advice for fixing this?
Old 05-22-2010, 08:57 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
i would suggest taking the panel back off, and checking all of the connections. i had to take one of the plugs and replug it in a couple of times before it went it correctly. might check the window switch also and see if its connected firmly, but its probably one of the larger connectors on the door itself.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
HTML code is Off
