Old 05-26-2010, 11:30 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Yet another activated charcoal cabin air filter R&R DIY :)
Yeah, it's incredibly simple, but, believe it or not, I actually had to peruse the "mit einbauanleitung" (=== includes mounting instructions") that came with my CUK2736-2 adsotop Mann "innenraumfilter mit aktivkohle" (=== cabin filter with activated charcoal) purchased from Autohauz (P/N: 64.11.0.008.138) for $11.87 each ($23.74 for the set) with free shipping (because I added a dozen Mann $5.47 oil filters to bump the price over $50).
The new filter didn't look like the old filter (and it didn't have a one-way plastic tab), so I had to read the instructions that came with it.
Even then, I needlessly removed the cabin-filter housing spring clip and the three air-duct clips on the first of two exchanges.
So, I decided to write my own BMW E39 cabin-air filter DIY (if not for anyone else, at least for my own future reference).
NOTE: Also useful to remove air conditioning stink (see this thread).
Here goes ... (as always, please improve if needed).
ID:	231663   Click image for larger version
ID:	231664   Click image for larger version
ID:	231665   Click image for larger version
ID:	231666   Click image for larger version
Old 05-26-2010, 11:50 AM
bluebee's Avatar
Since summer is coming up, you should also check your two undercarriage drain hoses when you clean out the cabin air filter drains and replace the cabin air filters.
Otherwise, you may get the dreaded gym-sock air conditioning stink!
Old 05-26-2010, 12:12 PM
bluebee's Avatar
And, if you REALLY want to kill the gym-sock ac stink, drill an acess hole in your driver-side right-foot kick panel to spray disinfectant on the a/c evaporator cooling fins!
Then do the one-time set up of your AC controls, and you're set for summer!
Old 05-26-2010, 05:19 PM
weasel like's Avatar
weasel like weasel like is offline
Technical Graphite > ALL
Mein Auto: E39 528i 5-speed
Bluebee, you rock. Everyone needs to do these simple things to keep their Bimmer smelling fresh.
Rules to live by:
- Fast, reliable, cheap. You can only have two.
- BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
Old 03-14-2011, 10:11 AM
bluebee's Avatar
Today, gunksny kindly posted a cabin air filter DIY PDF (e39 Cabin Filter DIY.pdf):
- E39 Cabin Filter Replacement DIY
I added his link above just now to the bestlinks for future reference:
- How to DIY replace the activated charcoal cabin air filter (1) (2) & what cabin filter to buy (1) (2) & cn90's inexpensive cabin filter retrofit (1) (2) (3) & cabin air filter implications for stinky air conditioning (1) (2)
For convenience, here are the pictures reproduced from that thread, only shrunken to 640x480 pixels:
ID:	270273   Click image for larger version
ID:	270274   Click image for larger version
Name:	3_cabin filter chamber.jpg
ID:	270275   Click image for larger version
Name:	4_cabin filter.jpg
Old 07-03-2011, 01:37 PM
bluebee's Avatar
It feels good to know, that, at least today, this (simple) DIY helped someone:
- E39 (1997 - 2003) > Mann Cabin Filter Air Flow
Originally Posted by chelseafc View Post
Ok searched again after posting, found a bluebee post with this link, appears confirmation of arrow pointing up (as in towards the underside of the hood)
Of course, as simple as this DIY is, it isn't without controversy:
Originally Posted by edjack View Post
The air flows from top to bottom, and then into the car. Arrow points down. Ignore the writing.
Originally Posted by QSilver7 View Post
The arrows on the microfilters should point upward...and Bluebee's as well as the other illustration confirms this.
Look again (closely) at the illustration...the air enters the microfilter compartment and flows UPWARD thru the filter, then the "fresh" air flows FROM the top of the microfilter into the car's HVAC system. The arrows near the microfilter are curved upwards to indicate that fresh air is drawn into the BOTTOM of the microfilter's plenum first...then UPWARD thru the micro & carbon filtering media, then into the car's HVAC fresh air intake. This allows HEAVY objects sucked into the plenum (or water) to fall to the bottom of the plenum otherwise it would have to fight gravity to enter into the system as the air is being drawn into the system. This is also why the water drains are at the bottom of the filter housing. If the directional flow was from TOP to BOTTOM then the filters would get soaking wet every time it rained or you washed the car:
Name:	E39 HVAC System Air Flow Diagram.jpg
Old 12-09-2011, 10:19 PM
bluebee's Avatar
For the cross-linked record, these cabin air filters were suggested in this thread:
- E39 (1997 - 2003) > Cabin Airfilter Replacement...
Originally Posted by Shrobby View Post
Not sure if anyone has found a good place for cabin air filters but I came across this..
http://www.filterheads.com/product/single/AQ1055C..
Seems like a good place to get them....
Old 12-09-2011, 10:43 PM
Blight67 Blight67 is offline
Mein Auto: 2002 530i Sport Pkg
Best deal I've found are the OEM Mann filters on Amazon for $18:
Name:	ScreenHunter_02 Dec. 09 21.38.jpg
Old 02-13-2012, 05:56 PM
joebry joebry is offline
Mein Auto: 525 & 325
Have you got a DIY or a link to a DIY for removing the intake to the passenger side cabin filter housing? It will make it easier to replace plug #6. I think I have seen one but cannot remember where it is.
Old 06-03-2012, 12:17 AM
bluebee's Avatar
I just accidentally realized a neat trick for helping get the cabin air filter housing back into the bimmer.
You can rotate left the snorkel on the side of the cabin air filter housing (and remove it if you need it out of the way).
Then, you put the cabin air filter housing back.
And, lastly, you rotate the snorkel back in place.
ID:	327677   Click image for larger version
Old 06-03-2012, 01:24 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
Nicely timed wakeup Blue. I recently had to check brake fluid and may need new filters soon.
I checked the links and didn't see any mention of aFe filters. Anyone out there using? Cost more but claim lifetime, so you save in the end. I'm asking about the ProDry, not the oiled ones.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 07-30-2012, 04:13 AM
Santorri84 Santorri84 is offline
Mein Auto: E39 523i
Hi fellas
I'm new to this forum so forgive me if this has been discussed before.
The passenger side center front a/c vent is spitting out bits of old grey foam.
What the hell is it and how can i fix it? I have that vent shut off for now but thats not ideal....
Old 03-01-2013, 03:42 PM
bin01123's Avatar
bin01123 bin01123 is offline
Mein Auto: 2013 535i
I'm in Georgia and its going to get warm in about a month so thanks for these posts. Do you have a better picture for the drain hoses? And what should I be looking for with these hoses?
Old 03-01-2013, 04:54 PM
bin01123's Avatar
Sorry I'm slow. I just figured this out
Sent from my HTC VLE_U using Bimmer App
Old 03-02-2013, 01:28 AM
senser senser is offline
Mein Auto: 540i/6 E39
For the engine air filter, they're great. I alternate between a ProDry and oiled between oil changes, but I haven't heard anything about aFe making cabin filters.
My butt dyno told me I lost some low end torque, but when you open 'er up it works extremely well. Also, stick with the dry filter, as the oiled one dirtied up my MAF quite a bit.
Old 03-05-2013, 09:04 PM
bin01123's Avatar
Senser,
Which oiled filter do you use? When it dirty up your MAF, did your dashboard throw out a message?
Old 04-05-2013, 07:38 PM
bluebee's Avatar
For the record, this was asked today:
Originally Posted by John Allen View Post
I purchased Fram air cabin filters for my 528. They have arrows on the side (edges) and the advisory "direction of air flow". It is not obvious to me which way the air flows. Can anyone advise whether the air flows up or down?
See also:
Old 09-03-2013, 11:46 AM
bluebee's Avatar
Here's an exhaustive list of replacement cabin air filters from today:
Originally Posted by doru View Post
Below is a list with the equivalent charcoal activated cabin filters, exact fit for BMW e39. Just pick the cheapest, I think:
Air Qualitee AQ1055C
ATP CF-105 RA-60
Beck Arnley 042-2076
BMW OEM 64 11 0 008 138
Bosch C3821
Champ CAF1722
Fram CF10369
G.K. Industries CF1067
Hengst E960LC-2
Mahle LAK 73/S
Mann CUK 2736-2
Micron-Air BM97130C
Purolator C35509
TYC 800048C2
Wix 49372
Personally, I used TYC for the last 5 years without an issue. Very good quality and very cheap.
EDIT: See also:
- How to replace the activated charcoal cabin air filter (1) (2) (3) & what cabin filter to buy (1) (2) & cn90's inexpensive cabin filter retrofit (1) (2) (3)
Old 04-02-2015, 07:43 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
Removed post. Figured it out; user error.
Old 04-27-2015, 06:43 AM
bluebee's Avatar
This question came up today ...
> E39 (1997 - 2003) > Air and Cabin filters.
Originally Posted by lsrguy98 View Post
Can anyone tell me which brand air and cabin filters to get? Also, is the carbon activated filter a good way to go or are the paper filters best. Fram has all of the ones I need but not sure about the quality.
Thanks.
Get the one th as t looks li I e it will get the job done that it was designed to do...and fits your budget.
As far as activated charcoal or plain...again this is your call to make. Do you know what the actvated charcoal filters purpose is? It's to help filter odors from the fresh air entering the HVAC system. If that matters to you...then again it's your choice to make versus plain filter.
Old 06-12-2015, 08:44 AM
bluebee's Avatar
For cross reference, a related thread was opened today ...
> E39 (1997 - 2003) > Cabin air filters
Originally Posted by gooddeal View Post
2001 BMW 530i 110k miles on the odom. Stale musty smell coming from the interior vents.
I suspect that the cabin air filters have never been changed. I am the 2nd owner.
Air conditioner is ice cold and works great.
open for suggestions..
Gooddeal
The ducting needs hosing out with an A/C spray elixir intended to neutralize the smell. Remove the filters and spray the stuff into the ducts with the blower on low speed. Let it set overnight.
Get under the car and make sure the drain hoses are free. They are on either side of the trans.
Originally Posted by 540 M-Sport View Post
Replacing filters with new ones with activated charcoal will help, but most likely you have mold growing on the condenser...you need to sanitize or clean it...there is an active thread right now on the subject in the E39 section. http://www.bimmerfest.com/forums/sho...d.php?t=786527
www.autohausaz.com has a pair of Mann filters for $20...only problem is you need to buy $75 worth of stuff to get free shipping. But even if you pay for shipping that is the best deal going.
Thanks to all, I 'll replace the filters. I work for a BMW dealer so I get parts for 30% off.
However, I have an independent mechanic who will do the air conditioner cleaning..
gooddeal
See also:
- How to replace the activated charcoal cabin air filter (1) (2) (3) & what cabin filter to buy (1) (2) & cn90's inexpensive cabin filter retrofit (1) (2) (3) & cabin air filter implications for stinky gym sock AC odors (1) (2) (3) (4)
Old 09-07-2015, 08:17 PM
cncmastr cncmastr is offline
Send a message via AIM to cncmastr
Mein Auto: E46, E30, E53 and E39
Here is a video I did for the cabin filter replacement, I figured it didn't make sense to create a new thread.
E46 - ZCP | E30 - 318is | E53 - 4.8is
DIY Video Channel - http://www.youtube.com/user/BluePurpleRedGuides
Old 09-08-2015, 02:59 AM
liter liter is offline
Mein Auto: 525i 2003
Thank you for the video as I have to do mine, and I googled to find this!
Old 10-03-2015, 05:23 PM
Got5.on.it Got5.on.it is offline
Mein Auto: 2000 528
okay I read this thread and seems to be where I wanna be...
Lately my vents have been kicking out this nasty, what looks like, pieces of the filter.
Is this from the cabin filters? Anybody have this problem happen?
Looking to change the filters today to see if this stops.
mann cabin air filter diy
