Old 05-27-2010, 09:32 PM
GMan745Li GMan745Li is offline
Mein Auto: 750Li
04 745Li - Stalling while idle
Car starts fine, no hesitation, no ruff idle. Car stalls while idling in and out of gear. Can hear a rush of air from the passenger side of engine when it stalls. Sounds like pressure escaping from midway of to rear of engine. Car will start right back with no problem. Time of stalling varies from when the car is started to when it occur. Easily recreated by pulling the oil dip stick out and pushing it back in.
Old 05-29-2010, 06:27 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Is this only within a few minutes after starting the car, or also when the car has been warm and running for a while?
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 05-30-2010, 07:39 AM
AMONEYXL AMONEYXL is offline
Mein Auto: 91 E30 99 E46 04 E66
clean ur maf sensor
Old 05-30-2010, 10:59 AM
AAOO750 AAOO750 is offline
Mein Auto: 2007 750i
Keif, my 2007 750i is stalling too. It stalls once the car is hot and always seems like it happens when I'm coming to a stop. The last time it stalled when I went to restart the engine turned over about four to five times longer than a normal start before finally firing up. Got the transmission error too during the stall.
Any thoughts?
Fuel pump??? ikob, seems to think my integrated supply module needs to be replaced. I might try replacing next week just to rule it out.
Old 05-30-2010, 11:59 AM
did u guys try to clean ur maf's i had the same problem too and thats what i did and my car works like new again
Old 05-30-2010, 12:10 PM
I'll check out the MAF. I just went out to move the car and it wouldn't start again. I figured out a way to get it to crank which I have recreated three times now. If I go ape **** on the start/stop button pushing it in and releasing it real fast the car will crank on the 15-20th press. I think I have an electrical problem. Hoping the integrated supply module fix will work.
Old 05-30-2010, 12:56 PM
do u have a check engine light if so u sould get it scanned that would help alot
Old 05-30-2010, 01:29 PM
Yes but it comes and goes. They replaced my crankcase speed sensor last week. The codes it's throwing are in this thread.
http://www.bimmerfest.com/forums/sho...=457581&page=2
Old 05-30-2010, 01:45 PM
can u list the codes maybe i can help u.
Old 05-30-2010, 01:53 PM
Reply in the thread in the link below. Don't want to hijack this thread as my problems are different. Codes are in the link. I need to rescan to see if there are any new ones from this morning when it didn't start.
Old 05-31-2010, 03:45 PM
Mein Auto: 750Li
Took it to the dealer who finally took time to listen to me and he was able to hear the pressure release sound when it stalled out. Currently it is at the dealer facing a $3400 repair.
They found:
1) The fuel pump not sending a signal.
2) Replacing the engine wiring harness (???)
3) The crankcase vent valves.
I can go alone with the fuel pump replacement and very little in agreement with the vent valves.
The Wiring Harness - I can't see how this should be a contributing cause, the tech stated he has seen a faulty wiring harness cause the transmissions code that pop in on repeated start attempt. They said it could be worn insultation on the wires. Has anyone heard of this before?
Old 05-31-2010, 03:50 PM
Mein Auto: 750Li
AAOO750 - check your battery cables to make sure they are tight - that was one of my issues.
Check your nav CD, read before it may not be turning off and drawing the battery down.
I took my CD out and will insert when I know I may need it.
Read some guy had himself locked in his trunk to verify this one.
Old 05-31-2010, 05:19 PM
Master Tinkerer
AAOO750, I can bring stuff up to you at some point this week and we can pull information, run tests, etc. if you want. Not a big deal. Let me know. I can't promise we'll find the problem for sure, but we'll likely be able to narrow things down a little at least.
They found:
Heard of the wiring harness and IVM causing similar issues, but I'm not a fan of guessing and throwing parts at something.
CCV valves -- buy these yourself and do these yourself, there is a DIY for this and it takes a flathead screwdriver and 5 minutes. It's seriously one of those things so easy that you shouldn't pay someone else to do it.
Old 05-31-2010, 06:19 PM
Mein Auto: 750Li
Thanks Keif, I agree with CCV DIY, the parts are about $40 and the dealer quoted $314 for the job. I will call him tomorrow to cancel that part of the repair and order CCV.
Old 06-03-2010, 01:48 PM
Mein Auto: 750Li
Problem SOLVED: Engine Wiring Harness was not the cause.
Problem - No Start, cuts off at idle:
Cause: Crankshaft position sensor defective, fuel pump defective causing it to short out SBS relay.
Fix: Performed short test, interrograted fault memory, replaced fuel pump, replaced SBSR and programmed new control unit, replaced crankshaft position sensor.
Old 06-05-2010, 09:04 AM
kippk kippk is offline
Mein Auto: 2004 745i
I had similar issue but only on cold starts after "choke" came OFF. The coils for each cylinder needed to be replaced and problem solved.
'04 745i - 35% tint, Sun Curtains, Convenience & Comfort Access, Premium Sound, 22" DaVinci Wheels, 3M invisible bra
__________________________________________________
I need someone to protect me from all the measures they take in order to protect me.
Old 06-07-2010, 10:08 AM
Mein Auto: 750Li
M. Wong, not sure the purpose of your post but if you could reframe from associating this type of language in my post. Thank you.
