1 headlight not working (sometimes) - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-01-2010, 04:38 PM
Grant93 Grant93 is offline
Mein Auto: 323i E46
I installed Depo HID headlights into my car, the driver side headlight turns on every single time, but the passenger side headlight will only turn on on occasion. They are both wired exactly the same, both have decoders, and the left side works perfect, as i still get the bulb out warning on the right side. Where to start?
Old 06-01-2010, 04:50 PM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
Probably with either the ballast or ignitor on that side of the car...
Old 06-01-2010, 07:38 PM
Mein Auto: 323i E46
should i try to switch the ballast from the left side to the right side? and see if its that? any other suggestions?
Old 06-01-2010, 09:28 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
That would be the best thing to do first, then report back.
Old 06-02-2010, 02:51 PM
Mein Auto: 323i E46
So i did just that, and sure enough, the driver side works with the ballast from the passenger side, and the one from the driver side does not work. Does this mean the ballast is no good? In that case i need to call DDM and get a new one shipped, correct?
Old 06-02-2010, 03:33 PM
you'll have to be more clear... you have interchanged drivers side/passengers side and left and right side... are you in Maryland or the UK?
If the "working" ballast works on both sides of the car then the ballast is good. If the side of the car that is "not working" doesn't work no matter what ballast is used I would say it's the bulb that's bad.
To add another layer... Not knowing what kit you got from DDM doesn't help either... the kit I got for my Mercedes has a separate ballast and ignitor, if yours is the same way, I would say the ignitor is bad if the non working side doesn't work with either ballast.
This is confusing me... I hope it's somewhat clear.
Old 06-02-2010, 04:07 PM
Mein Auto: 323i E46
Im in maryland, DDM Brand 55w Ballast, lets try it this way,
Headlight(driver side) A: Ballast A
When Ballast A is with Headlight A, headlight Functions correctly.
Headlight (passenger side) B: Ballast B
When Ballast B is with Headlight B, The headlight only turns on sometimes
Now, after switching these two,
Headlight(driver side) A: Ballast B
When Headlight A is with Ballast B it does not work, which leads me to believe that it is ballast B that does not function correctly.
Headlight (passenger side) B: Ballast A
When Headlight B is with Ballast A it works properly, proving Ballast A is functional.
If that made no sense i completely understand, its been a long day >.<
Old 06-02-2010, 04:51 PM
I am with ya... so yes... the ballast is the issue and DDM needs to replace it for you
Old 06-03-2010, 04:18 PM
Mein Auto: 323i E46
woo woo! sending it back now should have the new one sometime next week ^^, btw, do you know how to fix a door handle that sticks once you pull it? WD40 or something along lines?
