DIY Glovebox & Bentley supplement: 1-page summary of the dozen recommended E39 fluids - Page 3 - Bimmerfest - BMW Forums
Old 07-16-2014, 07:35 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by MuscleWagon View Post
Hey blue, where is the DIY for the auxiliary fuel tank install that allows your E39 to hold 36 gallons?
It's here, found under /how large is the fuel tank in the bestlinks:
- How large is the fuel tank and reserve in the E39 (1)
See also:
- Gasoline: Engine fuel & octane (1) & "The Gasoline FAQ" & top-tier gas stations (1) & Techron additives (1) & how to clean your gas gauge sending unit (1) & mpg calculations (1) how large is the fuel tank and reserve in the E39 (1) & what gasoline to use (1) & how much gas should be left to cool the fuel pump (1) & how to siphon the fuel out of the tank (1) & what is the cost differential between 87 & 91 octane AKI (1)
Old 07-17-2014, 06:22 AM
MuscleWagon MuscleWagon is offline
Fastest to daycare
Mein Auto: '99 540iT/'10 328iT
Originally Posted by bluebee View Post
Old 01-25-2015, 09:01 AM
bluebee's Avatar
We should probably make a good list of the colors of the dozen fluids, so that others, who have leaks as shown in this thread updated today, have a head start:
Hmmm... there are only a dozen fluids in the E39.
I'll guess at the colors below:
- Manual & automatic transmission fluid (1) (2) (3) (4) BROWN?
- Power steering fluid (1) RED
- Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) (BLUE, GREEN)
- Brake & clutch hydraulic fluid (1) BROWN, BLUE
- Engine lubrication, i.e., motor oil (1) (2) BROWN, BLACK
- Air conditioner refrigerant & PAG oil (1) ?color?
- Differential hypoid gear oil (1) BROWN
- Battery electrolyte (1) CLEAR
- Engine fuel, i.e., gasoline & octane (1) CLEAR'ish
- Windshield washer fluid (1) CLEAR, slightly BLUE
- Intensive cleaning system fluid (1) CLEARLY SOAPY
- Air conditioning condensation CLEAR (wet)
If you have a leak, it's one of those.
BTW, what color is air conditioning fluid?
Or, would it always be a vapor anyway?
Old 04-02-2015, 08:00 PM
bluebee's Avatar
I was looking up my original vehicle options when I plugged my VIN into this particular VIN decoder, which tells you interesting information about certain fluid volumes and which transmission you originally had:
- BMW VIN decoder (1)
Old 04-03-2015, 02:45 AM
pudl's Avatar
pudl pudl is offline
Mein Auto: E39 530dAT 2001
Time to enjoy some German.
Old 04-03-2015, 06:51 AM
bluebee's Avatar
The VIN decoder that gives out the fluid volumes is mostly in English, but I know what you mean, as most of the VIN decoders (which don't spit out fluid volumes) output in Deutsch ...
- BMW 10-character vehicle defect code lookup tool for dealer service records (1) & how to decode your 17-character BMW VIN (1) & the RealOEM parts list based on your vehicle identification number (1) & a list of online BMW VIN decoders (1) (2) (3) (4) (5) (6) (7) (8) (9) & what is the definitive list of electronic computer modules that need VIN recoding once replaced (1)
