Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series
3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 11-17-2003, 10:17 AM
AG AG is offline
Mein Auto: 330i
Oil suggestions?
I've decided to tackle my first oil change and I'm wondering which oil to use. I've checked the archives and I've narrowed it down to the Mobil 1 0w40 or the BMW Castrol. I'm leaning towards the Mobil 1, but I'm not sure.
I've got a 3 year old 330i with 37xxx miles on the clock. I've done oil changes at the dealer every 7500 miles and I've never needed to top off the oil, except since my last oil change. The last 7000 or so miles have mostly consisted of short distance driving and one track event, so I think I might be better served by a heavier weight oil. Any suggestions?
Old 11-17-2003, 11:06 AM
F1Crazy's Avatar
F1Crazy F1Crazy is offline
racer wannabe
Mein Auto: '12 X5,'08 535i, '03 325i
If you wanna stay with oils meeting BMW specs then your choice is limited in US. There is only one more oil (other than the 2 you mentioned)that meets the specs - Castrol Syntec 0W-30, version made in Germany but it is hard to find and distributed only by AutoZone.
Mobil1 0W-40 is not really that much thicker than BMW 5W-30 HP synthetic or Syntec 0W-30. M1 0W-40 viscosity @ 212F (operating range for most engines) is 14.3cSt, BMW HP is around 11.9cSt and Syntec is 12.1.
FYI here is the range for different weights:
Weight__________cSt 100°C_________SUS 212°F
20wt oil_________5.6 - 9.3__________44.6 - 56.8
30wt oil_________9.3 - 12.5_________56.8 - 68.3
40wt oil_________12.5 - 16.3________68.3 - 83.11
50wt oil_________16.3 - 21.9________83.11 - 106.6
60wt oil_________21.9 - 26.1________106.6 - 125.0
There is not much info how well M1 0W-40 works in BMW engines but it showed to thin out to 30wt in some engines. Thinning out of grade is not a good thing since it can lead to sludge type deposits. Also you have to remember that bigger viscosity spread requires more Viscosity Improvers and it's not a good thing either. Both Castrol oils stay in grade.
I'm not trying to say that Mobil1 oil is bad, I just think that this particular grade is nothing special. I wouldn't pay $1.50 per quart more for this oil. You may give it a try and check how well it really does by doing Used Oil Analysis at Blackstone Labs.
All of the oils meeting ACEA A3/B3 and BMW LongLife specs will work fine at 7,500 miles intervals. If you don't care about complying with BMW specs then there is one more oil I wouldn't hesitate to recommend and it's Red Line, any 30 or 40 weight.
Old 11-17-2003, 12:30 PM
magbarn magbarn is offline
Waiting for the d
Mein Auto: '10 335d
I too have been trying to find the magical german castrol 0w-30 elixer but have given up here in southern ca as the autozones never seem to have it. The oil I choose to put in is the BMW 5w-30 (It's Castro Softec TXT which is not the same castrol 5w-30 at walmart or other stores) while not the best it does seem to work well for me. However, some people have seen sludge on their oil caps and so far my car has been immune to it.
'10 335d Monaco blue/oyster/SP/PP/Enhanced Premium Sound/nav from phillipek SBBMW
Click Here for Pics!
Old 11-17-2003, 12:47 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
I plan on using Castrol Syntec 5 - 50.
Not sure that this is the made in Germany stuff but on the bottle it says that it exceeds manufacturer specs for BMW and Mercedes.
My dealer dosent sell BMW oil.
Photobucket
Old 11-17-2003, 01:34 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
All the German automakers have oil standards that get updated periodically and/or specified for different engine families, so it could be approved under old ones but not current ones. I need to post it one of these days, but I've compiled a list of oils sold in the US that meet the 4 primary BMW oil specs currently in use:
LongLife 98
LongLife 01
LongLife 01 in a different spec for Valvetronic
Special Oil for some S54/S62 applications
Most commonly available synthetics in the 0w-30 to 10w40 grades meet LL98. LL01 is specified for non-M and non-Valvetronic engines after 09/01, and are generally 0w-30 or 0w-40 (often called 'European Car Formula' in the US) with a couple of 5w-30s in the mix.
As for that M oil, there is only one other than the dealer spec 10w-60 Castrol, and is a product not sold in the US.
Now, all this said, using RedLine, AmsOil or some other favorite most likely isn't going to do anything. They've most likely just not been submitted for testing.
Old 11-17-2003, 03:51 PM
F1Crazy's Avatar
racer wannabe
Kaz,
I posted the list of BMW approved oils in another thread but I'll post it here again. I don't know if this is the same one that you have, I got it recently. Nice fellow that sent it to me says it's a copy from BMW Technical Information System as used by the dealers worldwide.
BMW TIS -2003:
5.0 "Longlife-01" for all engines, except:
M43/CNG, S54, S62/E39 (till 02/2000)
BMW Quality Longlife-01 0W-40 (supposedly just showed up at US dealerships)
BMW Quality Longlife-01 5W-30
ACEA A3/B3
Agip Formula LL B 01 0W-30
BP Visco 7000 0W-40
BP Visco 7000 Special 0W-30
Castrol Formula SLX 0W-30
Castrol Syntec 0W-30 (new formula in US, imported from Germany)
Castrol Super Racing 0W-40
Castrol TXT Softec LL01 5W-30
Havoline Synthetic BM 0W-30
Mobil 1 0W-40
Motul Specific LL-01 0W-30
6.0 "Longlife-01 FE" for last generation engines only: N40, N42, N62, N73
BMW Quality Longlife-01 FE 0W-30
Castrol SLX 01 FE 0W-30
7.0 "Longlife-98" for all engines except:
M43/CNG, M54 (from 09/2001), N40, N42, S54, N62, N73, S62/E39 (till 02/2000)
BMW Super Power Plus 5W-30 is substituted by
BMW Quality longlife-01 5W-30
BMW Super Power Oil 5W-40
ACEA A3/B3
List of around 160 oil names and grades, some of them are:
76 Pure Synthetic Motor Oil 5W-40
Castrol Formula RS Power and Protection 0W-40
Castrol Formula RS Road and Track 5W-40
Castrol GTX7 Dynatec 5W-40
Castrol Performance 5W-40
Castrol Syntec 5W-40
Castrol TXT Softec 5W-40
Castrol Softec LL98 5W-30
Castrol Softec Plus 5W-30
Chevron Supreme Synthetic 5W-40
Mobil1 5W-30 (think it is not the same 5W-30 SS or Tri-Syn sold in N.A)
Mobil1 5W-40
Mobil1 Rally Formula 5W-30 and 5W-40
Mobil1 Turbo Diesel 0W-40
Mobil Super S 5W-40
Mobil Synt S 5W-40
Quaker State Full Synthetic European Formula 5W-40
Valvoline Durablend MXL 5W-40
Valvoline SynPower 5W-30 and 5W-40
Valvoline SynPower MXL 0W-30
Valvoline SynPro 5W-30 and 5W-40
This list doesn't have a special oils list.
Old 11-17-2003, 04:00 PM
F1Crazy's Avatar
racer wannabe
I don't think M54 can stomach 50 weight...
Old 11-17-2003, 04:38 PM
LmtdSlip's Avatar
Mein Auto: 325iC
Thats what the owners manual calls for for my climate.
Photobucket
Old 11-17-2003, 04:40 PM
F1Crazy's Avatar
racer wannabe
What car is it? I thought that you have E46
Old 11-17-2003, 04:49 PM
LmtdSlip's Avatar
Mein Auto: 325iC
nope.
E36
Photobucket
Old 11-17-2003, 05:32 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
nope.
E36
I believe most E36s fall under the older Special Oils spec which doesn't mandate synthetic.
Old 11-17-2003, 05:44 PM
The Roadstergal's Avatar
The Roadstergal The Roadstergal is offline
Butting back in
Mein Auto: GS500F
Why is 0W-x "European car formula"?
"This is a revolution, dammit! We're going to have to offend SOMEbody!"
Old 11-17-2003, 06:05 PM
F1Crazy's Avatar
racer wannabe
It's simply a marketing gimmick since many cars in Europe come with 0W-X oils from factory and 0W-40 seems like a preffered weight in Europe lately.
Old 11-17-2003, 07:41 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Here's the list I compiled. This is out of last November's BMWTIS CD, so it's a bit outdated.
BMW Specified fluids
These fluids are those specified by name or specifaction for their appropriate applications. Other equivalent fluids may perform satisfactorily, but are not specifically named by BMWAG. I've narrowed the list to those products that appear to be readily available in the US. Products with grades or styles specified imply that only those matching are specified. i.e. an approved motor oil in a 5w-30 is not approved in 5w-40 unless it is listed.
Engine Oils:
* BMW LongLife 98 Specification for all engines EXCEPT: M54 after 09/01, S54, N62, S62/E39 before 02/00
o 76 Pure Synthetic 5w-40
o Castrol Syntec 5w-40
o Chevron Supreme Synthetic 5w-40
o Texaco Havoline Synthetic 5w-40
o Mobil 1 5w-30
o Motul 6100 Synergie 5w-40
o Motul 8100 Synergie X-cess 5w-40
o Pennzoil Synthetic European Formula 5w-40
o Pentosin Pentosynth 5w-40
o Quaker State Full Synthetic European Formula 5w-40
o Valvoline SynPower Full Synthetic 5w-40
o Valvoline SynPower MXL 0w-30
* BMW LongLife 01 Specification for all engines EXCEPT: S54, S62/E39 before 02/00
o Castrol Syntec 0w-30
o Mobil 1 0w-40
o Motul 6100 LL-01 0w-30
For the S54 and S62/E39 before 02/00, BMW only specifies the following:
o Castrol TWS Motorsport 10w-60
+ Castrol Formula RS Racing Syntec 10w-60 is an older name for the above product. Castrol markets a new product under this name which is NOT an approved product.
o Veedol Synthetic Z 10w-60
The Veedol product doesn't appear to be available in the US, but I kept it in this list since it's the only alternate listed.
Old 11-17-2003, 07:55 PM
F1Crazy's Avatar
racer wannabe
Veedol sells Castrol oil. I don't know if it is just rebottled or if they blend it themselves but it's the same as Castrol oils.
Old 11-18-2003, 08:49 AM
LmtdSlip's Avatar
Mein Auto: 325iC
What is "special" about the oils? Are there non synth oils that I could use considering the fill cycles that the computer is recommending?
I will probably run the 5-50 Castrol Syntec anyway. Couldnt hurt considering the extended fill periods I am getting out of the computer. Although, I think I will start changing at 7500 from now on.
Photobucket
Old 11-18-2003, 09:49 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
I've never looked into the pre-LL98 oils, as they don't apply to my car. As indicated, the newer specs superceed any old ones, though if your application calls for a 50 weight oil, it looks like you're SOL as there is no such thing in a LL98 or newer.
Old 06-17-2004, 05:15 PM
dkotanto dkotanto is offline
Mein Auto: 2006 BMW 530i sport
Hi,
Has anyone heard any comments or tried the new Amsoil 5W-40 European Engine Oil yet? It meets BMW LL-01/98 requirements:
http://www.amsoil.com/products/afl.htm
2007 530 xi
2004 X3 3.0i
2006 530i
Old 06-24-2004, 05:01 PM
euroPower euroPower is offline
Mein Auto: 01' E46 Limousine
I thought we choose oil based on the climate..
anyway, what oil grade should I use in s.california??
it's so hot right now..
Old 06-24-2004, 05:23 PM
mallards mallards is offline
custom user title!
Mein Auto: l
mobil 1 5w-30 w/ stock filter every 7500 miles ...
ben
Old 06-25-2004, 07:14 PM
Iniquity Iniquity is offline
Mein Auto: 2003 330i ZHP
ben
Mobil1 5w-30 meets the BMW viscosity requirements, however it doesn't meet the BMW performance requirements.... you should be using either BMW 5w-30, Mobil1 0w-40, or that magic German Castrol 0w-30 that no one can find..
