Old 06-07-2010, 12:52 PM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
Water collecting in the inside of the back air conditioning
Hi guys . Recently I have noticed the condensed water is collecting in the inside of the back air conditioning, i can even hear the water sound when car is moving. One day i took little medical hose and sucked it out - it was like 200ml, then another day 100ml more. Does someone know what to do, looks like the drain line maybe blocked, because i dont see any condensed water under my car after I parked it.
Old 06-08-2010, 07:22 PM
Little Odessa
Mein Auto: bmw
Huh, no one has drainage line problem? maybe anyone have a picture of where exactly the air conditioning drain is located?
Old 06-09-2010, 12:07 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Where were you sucking the water out from exactly? (so I can look on mine)
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 06-09-2010, 01:32 PM
Little Odessa
Mein Auto: bmw
Right from the middle console air conditioning levers, i did put inside medical hose and suck it out its complete clear water, do you know where is exact place for drain under the car i want to just put there high pressure air and try to clear it up
Old 06-27-2010, 03:23 PM
745insane 745insane is offline
Mein Auto: 2002 745i
I have the exact same problem! Did you ever figure out why it wasn't draining correctly?
Old 06-27-2010, 04:48 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
I'd suspect condensation building up in the centre console air ducts.......here's a pic :
Here's how to take the centre console apart :
http://66.196.80.202/babelfish/trans...la_Central.htm
My BMW ACS7
Old 06-27-2010, 07:39 PM
Little Odessa
Mein Auto: bmw
I dont know where is the drain lines for this ducks, but my front drain line open well, i switch off an air conditioning wheel inside the console, and looks like it stop, very nice option for long trips but i cant use it now
Old 06-29-2010, 01:25 AM
Zainudin Zainudin is offline
Send a message via ICQ to Zainudin
Mein Auto: 735i (E65)
Unhappy
Hi guys!
I had the same problem.
I have disassembled the centre console, but can't find where the water come in..
Look under the car, but couldn't find AC drian.
Does anyone solve this problem?
Thanks in advance.
Sorry for my english.
Old 06-29-2010, 05:04 AM
Here is some photo. Can anyone advice me, where I can find that drain tube tap. If I turn on the car in that condition, will anything short or damage? Can airbags shoot? Thanks.
ID:	236373   Click image for larger version
ID:	236374   Click image for larger version
ID:	236375   Click image for larger version
ID:	236376   Click image for larger version
Old 06-29-2010, 05:08 AM
else
ID:	236379   Click image for larger version
ID:	236380   Click image for larger version
ID:	236381   Click image for larger version
Old 06-29-2010, 06:44 AM
Here that I could find out...
This is the drain tube(saloon view) right side.
Old 06-29-2010, 06:51 AM
drain tube under carpet view, connect with the chasis.
Old 06-29-2010, 06:52 AM
Here the condensate coming out when the AC is working.
Old 06-30-2010, 04:13 AM
At first remove trasmission cover. There 4 bolts.
ID:	236455   Click image for larger version
ID:	236456   Click image for larger version
Old 06-30-2010, 04:19 AM
At the rear edge of a transmission cover, you can see the tubes at left and right sides of a cover.
ID:	236458   Click image for larger version
ID:	236459   Click image for larger version
this is it.
Old 06-30-2010, 11:03 AM
Little Odessa
Mein Auto: bmw
Thank you very much for that
Old 06-30-2010, 11:39 AM
you are welcome.
