#51
And follow the procedure below to top off the coolant level |
#52
A newbie's first post was asking what coolant to use, so, for the record, I pointed him to this "What Coolant you using?" thread, which I consider the canonical thread for E39 coolant:
- E39 (1997 - 2003) > Toping off Coolant Quote:
#53
For the cross-linked record, a short history of Zerex (Zerez, Zerone, etc.) is in this thread today:
> E39 (1997 - 2003) > A coolant I came across Quote:
> E39 (1997 - 2003) > recommendations for coolant
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 08-11-2012 at 07:03 PM. |
#54
Additives
Tried WaterWetter with no measurable difference in temp. My indy says it's a waste. Just use 50/50 BMW coolant and water plus maintain the cooling system.
#55
I'm not vouching for what is said in this video (after all, it's put on by a magazine collaborating with a coolant manufacturer); but it's an hour all about coolants, which contains some interesting information.
1. Only BMW recommendatrions 2. BMW recommendations plus anything that meets BMW standards 3. BMW recommendations plus anything meeting BMW standards plus logical alternatives
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#56
For the crosslinked record, the "what coolant" topic came up again today, over here:
#57
I've been trying to figure out why the 'what coolant' comes up, and specifically why anyone would think to only consider BMW coolant, when it finally dawned upon me that the coolant choice, is based on personality just as much as almost every other choice we make.
Here's an example which was posted today
#58
Simple, any of these readily available three will work: Preston Extended Life (Green)5-150/Valvolin Zerex G-05/Peake Green. Mix in pure water from anywhere at less than $1 per gallon (if coolant not premixed) and ready to go. For those asking about water wetter and other coolant additives: As far as I know, BMW coolant contains a water wetter.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
