Old 06-08-2010, 09:36 AM
kingfish kingfish is offline
Mein Auto: 525i
2001 525i AC Pusher Fan doesn't work
My AC in the car gets that musty smell and stops cooling until I start driving the car. But when ever I come to a stop light the smell comes back and the humidity rises. I noticed that when the car is sitting idle that the Pusher fan in front of the radiator doesnt turn. i poked the fan motor to see if it was frozen but it turns freely so I'm suspecting the motor is fine and the control unit that engages the fan is not working. Any suggestions?????
Kingfish
Old 06-08-2010, 09:49 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Search this site for troubleshooting instructions. Your fan has an integral controller that gets a signal from the engine computer. Sometimes the controller goes bad.
Old 06-08-2010, 09:51 AM
cn90 cn90 is offline
Check Fuse 75 (30A). Also check the temp sensor (lower radiator hose, "Coolant Outlet Temp Sensor" in the pic below):
Old 06-08-2010, 10:05 AM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
You're in good company. Several of us have suffered at the hands of this little bit of German egineering. Start with the two suggestions above. Good luck.
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
My coolant outlet temp sensor had some corrosion that was affecting the main fan speed due to inaccurate temperature reporting. Easy and cheap fix. Just pull the sensor out and check the connections. One possible solution.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 06-08-2010, 10:06 AM
Also, if you pull the coolant temp sensor out, replace the O-ring, search the forum for the O-ring size.
BMW only sells the whole temp sensor, the O-ring is not sold separately.
Old 06-08-2010, 01:24 PM
Mr Majestik! Mr Majestik! is offline
Mein Auto: 2002 525i
Question Where is fuse 75 located?
I can't find it???
Old 06-08-2010, 01:33 PM
Originally Posted by Mr Majestik! View Post
I can't find it???
Here you go:
http://www.bimmerfest.com/forums/sho...d.php?t=205728
Old 06-08-2010, 03:20 PM
Thumbs up
