Can't turn heat off???? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 06-08-2010, 01:15 PM
scruffy507 scruffy507 is offline
Mein Auto: 1984 bmw 528e
Hey folks! I have a 1984 528e that I can't turn the heat off. I pulled the heater valve and it appeared clean and unstuck. I also carefully applied 12 volts to it and the plunger did actuate in then out?? I cant seem to stop the heat coming from the defroster or floor vents and the sliders and doors are connected and working too. Please help!
Old 06-15-2010, 12:43 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
The electronic heater valve which is fitted on the bulkhead has failed which is a very common problem, Other symptons are the inabilty to regulate the hot air or cold air above or below 60 mph.
HTML code is Off
