Old 01-07-2011, 05:06 PM
adjmcloon's Avatar
adjmcloon adjmcloon is offline
Mein Auto: e39's , e30's, e46's
87 octane, cel (cat inefficiency) disapears
I have had cat inefficiency codes popping up consistently on bank one for a while. I filled up with Texaco 87 today and my cel went off after a quarter tank or so. This is the first time that's happened. Previously the cel would stay off after I cleared it with my peake tool, unless we drove it @ highway speed for more than about 15-20 miles. If we made short runs around town we would not get the cat codes. We have used super unleaded up until today.
I have done the ccv, new plugs (there was a bit of oil), oil filter housing gasket, valve cover gasket and vanos was done by the previous owner.
I am just wondering if there's someone who might have some suggestions as to why this happened. Could a small vacuum leak make the car run rich? If I have a vacuum leak its small because I have replaced most every hose I could find and I don't hear any obvious air leaks. I know that the i6 will give slightly better emissions on lower octane fuel. Since we are supposed to use super, something isn't right. I have some cats coming but I am worried about running rich and fouling the new cats. I don't have any oil leaks.
My only thought is maybe some residual oil in the plug boots could be causing a problem. I cleaned them but didn't replace them with the spark plugs.
Other symptoms are a small hiccup in idle and sometimes when decellerating. My trans has an issue with being slow to engage reverse but it shifts fine. Otherwise the car runs pretty well and I average around 24mpg in mostly highway driving
2001 530i tiAg sport (sold)
2002 540iA sport (sold)
2006 330i sport (sold)
2008 535i-6 sport (sold)
1999 528iT sport (sold)
2002 525iT alpine sport
1990 325i sedan
1990 325is coupe
Old 01-07-2011, 05:09 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
How old are the O2 sensors. front and rear? Some advocate replacement at 100k.
Old 01-07-2011, 06:42 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Why would you fill up on 87 reg??
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 01-07-2011, 07:13 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Premium fuel has additives which retard detonation, allowing for greater spark advance at higher compression ratios without pinging (thereby giving better performance and throttle response). In an engine with a compromised emissions system (failing 02 sensors or cats), this works against you....a lower octane fuel will burn more easily and completely (albeit with somewhat reduced performance).
The road goes ever onward....
(R.I.P. Jever)
Old 01-07-2011, 08:06 PM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
So you're advocating running low octane fuel for a car that was built for and recommends running premium fuel? Also ami I missing something here? Op you previously ran premium until now and when you filled up with 87 you threw the cel. So either your car doesn't like the low octane fuel (most likely) or you got a bad batch of gas. Just my $.02.
Old 01-07-2011, 08:14 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Wow awesome peice of information!!!
You know your stuff
mujjuman
Old 01-07-2011, 08:59 PM
I don't know the answer ...
But ...
Kudos to you for doing your homework!!!!!
- Octane emissions smog test results
Old 01-08-2011, 01:51 AM
adjmcloon's Avatar
I filled up on 87 as an experiment, because of what I read about lower octane fuel giving better emissions. I have put a lot of time and sweat into the car, and that cel annoys the **** out of me, even if it is something relatively "minor". I am trying to get the "wagz" up to 100%, but she's a stubborn old bitch. (But I do love her)
My pre-cat sensors are new and I'm going to replace my post cat o2 sensors with the cats I have coming. The code is consistently bank one cat inefficiency. I am sure replacing the cats should solve the issue, but the weird little hiccup at idle and on deceleration has me wondering if there's not something else going on. I will report back after I get the cats and new post cat sensors in place.
1990 325i sedan
1990 325is coupe
