Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 11-18-2003, 01:42 PM
GOKOOLJAPAN GOKOOLJAPAN is offline
Mein auto: 1997 528i
DIY - 528i OIL Change (E39) 6 cyl
528i Oil Change (no pics because it’s easy)
Disclaimer: The procedure below is to be done at your own risk. I have changed Oil numerous times using these procedures with positive results, but may not work for you. I am not stating that the procedures below are the proper BMW procedures. The instructions below were performed on a 1997 528i. Other years and models may differ, but I do not know for a fact. I will not be held accountable for any mishaps or accidents. Again, please perform these procedures at your own risk.
TOOLS & Parts NEEDED:
½ Drive Ratchet
17mm socket
36mm socket
Torque Wrench
Flat Head Screwdriver
Floor jack, hand jack or ramps and jack stand
7 qts of Synthetic Oil & Oil Filter
Tip: Warm up car to operating temperature to make oil drain out smoothly and almost completely.
1. Start by jacking up your car on the front passenger side jack point using a floorjack or hand jack (OR you can use ramps). Once high enough to get under, make sure to put a jack stand or hand jack underneath the front part of the cross member (place it on a point where you can still access the drain bolt).
2. Locate the drain bolt which will be facing downwards at an angle. The bolt is a 17mm bolt and is facing the passenger side front wheel. You can’t miss it! Look from underneath passengerside front towards the bottom of the engine. It’s the only bolt you can see. And also, you can’t miss it since the oil pan is a big square.
Using a 17mm ratchet (I would use the ½ drive socket and ratchet for added leverage), begin by loosening the bolt (counter clockwise). Strategically place the oil catch pan underneath. When loosening the bolt, push on the bolt until you are ready to remove it (what this does is that you don’t want to just straight loosen the bolt till it falls off). This will aid in not dropping the bolt in the oil pan and not having oil all over your hand. Let the Oil completely drain for a good 10 mins or so.
Tip: If using a floor jac, remove the jack stand and lower the jack just before it touches the oil pan. This enables the car to be leveled in order to get as much oil as possible out.
3. Loosen the Oil filler cap on top of the valve cover so that the oil will drain smoother. Then get your 36mm socket out and begin to remove the oil filter cap. This should be really easy to find since it is the only 36mm socket type in the engine bay. Look for the black plastic cover.
Remove the cap and the filter should come with it. Remove the filter just by pulling it out. Remove the large O-Ring on the cap which is located at the top to seal it (use a screw driver). Your new filter from BMW should come with one. Replace with new O-Ring and put a LIGHT coat of oil(oil that you are using in yor car) on the O-ring. Replace the oil filter. Wait till oil drains from the filter housing and then replace the filter and cap and hand tighten. Then take out your trusty torque wrench and torque the cap to 25 NM.(should say on the cap)
4. Raise car up like Step #1. Clean off drain bolt and replace the crushable copper washer. Replace bolt and hand tighten (clockwise). Make sure you clean ant oil around the bolt and oil pan. Torque that bolt to 21 ft lbs. Lower vehicle.
5. Pour 7 qts of oil into the oil filler on top of the valve cover. Tigten oil cap and start engine. Drive or let the car run for 3-5 mins and make sure there are no leaks underneath or in the oil filter housing.
6. Re-set the oil inspection light & that’s it!
Piece of cake!
-Gokooljapan
Old 04-04-2005, 07:46 PM
sehiser sehiser is offline
Mein auto: 528i
Great post!
You'll all notice on your oil filter cap #NM, in my case thats 25NM. NM is Newton Meters. You'll have a hard time find a Torque wrench that shows NM.
Most of you will see 25NM, which converts to approximately 18.5 foot lbs of torque.
The oil filter cap uses an O-Ring, what's nice about that is it just needs to be snug. When an O-Ring isn't used on an oil filter, you need almost twice as much torque on it.
If you don't have a torque wrench, don't worry. 18lbs of torque is a nice snug tug, just once, don't over do it. You just want to make sure there are no leaks.
To be honest, you don't really have to worry about being as accurate with the drain plug, I would tighten that like you would any other bolt, just give it a nice light tug.
You'll notice on your BMW the torque specification are given in NM. Unless you're rebuilding an engine and dealing with piston rods and rod bearing, you just need to be close.
If you need to convert NM into Ft-Lbs, it's simple. 1 NM is approx. 0.74 Foot-Pounds
eg: 25NM x .74 = 18.5 ft-lbs
Don't skimp on the metric sockets by trying to get american to fit. You're talking $3 a socket, and $35 for a basic torque wrench if you want one.
Other than that, my dealership charges $465 for spark plug, oil, filters, and gear oil changes.
Changing sparks plugs and oil on a BMW is 5 times easier than on a domestic.
$9 or less for an oil filter.
7 qts of synthetic about $5.20 a qt = $36.40
$5.50 for NGK plugs, x 6 = $33
Gear Oil, about $5.
Fuel Filter = $10
You're out the door for under $100. The only other things you need to know how to do are check your brakes, lube stuff, and make sure nothing is getting worn out. Basically the service center is just looking for ways to make money off you. Don't buy the line "Well it's a German car, they are different". Yeah, they ARE different, they are easier to work on and more dependable. It's good to have a micrometer to check your rotors, and a few other tools here and there. If you don't check all these things, it's a good idea to let a service center have a good one over on the occasion, you don't want to be cheap but you don't want to get ripped off either. You can do the entire inspection in under an hour if you don't make a mess.
Probably the only thing I wouldn't do is my alignment and tires. An alignment is about $45-60 and worth it. They use some high end equipment for that, you can buy DIY alignment equipment for about $1400, but I'd personally save that for a service center.
The guys at the service center will get a kick out of a BMW owner who can actually work on a car.
Scott
Toledo, OH
Old 05-10-2005, 08:26 PM
ketchup's Avatar
ketchup ketchup is offline
Wrenchin'
Mein auto: just can't sit still
I don't know if you covered this, but don't forget to fill the oil filter canister with new oil too!
WTB:
01-03 M62 Valve covers
Old 08-05-2005, 12:59 AM
luvdriven540i luvdriven540i is offline
Mein auto: 98 540i/6 Black/tan
Smile
GoKoolJapan, thanks for the info, yes it is easy, but how's the synthetic oil working for your car? I just bought a 98 540i, should I use synthetic? I'm being told at the BMW dealership here in Las Vegas that they don't use synthetic on BMW's models earlier than 2000. I appreciate any and all input on this subject , thank you all.
Old 10-11-2005, 01:57 PM
omarm_2000 omarm_2000 is offline
Mein auto: BMW 528i
Question on final step oil change.
This questions is for Gocooljapan. On step 6 so said that you re-set the oil inspection light, how do you do that and where do I do it?
Old 10-12-2005, 10:37 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E30 E38 E39
Mein auto: The E38
omarm_2000:
This might help...
Link:
Service light reset
M.Wong
E38 2000 740iL Orient Blue
E39 2003 540i/6 Sterling Gray (European Delivery)
E30 1987 325i Royal Blue (Passed on to a new family)
Old 10-15-2005, 09:11 AM
Mein auto: BMW 528i
Reply to oil reset
Mr. Wong, thanks for the info. I have 2 questions,
first where do I get the tool to reset it?
Also some one else posted the following, please let me know if this might also be correct:
The ignition key must be in OFF position.
Press and hold trip odometer button in instrument cluster, and turn ignition key to ACCESSORY position.
Keep button pressed for approx. 5 more seconds until any of the following appear in the display: "Oil Service" or "Inspection", with "Reset" or "Re".
Press button again and hold for approx. 5 seconds until "Reset" pr "Re" flash.
While display is flashing, press button briefly to reset SII.
After display has shown new interval, the following will appear in display for approx. 2 seconds: "End SIA".
Old 10-15-2005, 10:45 PM
M.Wong's Avatar
E30 E38 E39
Mein auto: The E38
Keep in mind that it's usually helpful to post the year (model year and/or the build date on the door VIN plate) when you have questions. The link I posted shows two ways, depending on the year of your car.
Older E39s use the pin method under the hood. The link I posted also has a link to the Peake Research web site for an example of the reset tool:
http://www.peakeresearch.com
My E38 uses this pin method. However, I don't use a reset tool like the one from Peake Research. I use a wire as shown in this link:
Oil service light reset
(If your E39 is newer, the other method on the dash is what you need to do.)
M.Wong
Old 02-01-2006, 07:34 AM
Lord Bodak Lord Bodak is offline
Mein auto: 2001 530i
Bringing an old post back up to the top I know, but I have seen this mentioned occasionally. Is this something you must do, should do, or just might want to do?
Old 02-03-2006, 08:02 AM
M.Wong's Avatar
E30 E38 E39
Mein auto: The E38
Personally, I don't do it... but many say you should.
M.Wong
Old 02-04-2006, 05:43 PM
BMW1983 BMW1983 is offline
Send a message via AIM to BMW1983
Mein auto: 2000 528i
I know this is a dumb question and I'm sorry for asking it but I don't have my car with me because its in the shop til next week. What does the pin configuration look like on a 98 540 i e39? Is it round and I have to buy the adapter that comes with the peake reset tool or is it the kind where I don't have to buy the adapter. The rectangular connection? The only reason I ask is cuz i think I saw it today when I was cleaning up under the hood and it was round but the peakeresearch website says that 97-2000 uses the rectungular connection. Thanks.
2000 528i
Old 02-05-2006, 01:26 PM
aazzara aazzara is offline
Mein auto: 1997 528 i
Thanks for the info. Is there a dipstick on these cars to check the oil level in the engine? I just bought a used 1997 528 i and I could not find the dipstick. I bought it at an auction, so I was wondering if someone swiped it during the inspection.
Old 02-05-2006, 10:19 PM
M.Wong's Avatar
E30 E38 E39
Mein auto: The E38
Originally Posted by BMW1983
What does the pin configuration look like on a 98 540i e39?
It should look the same as in my picture.
Originally Posted by aazzara
Is there a dipstick on these cars to check the oil level in the engine? 1997 528i
Have you no owner's manual? This one is similar: Manual from BMWTips.com.
Yes, it should be red. Left of center of picture for the V8, right of center near the fire wall for the I6. If it's missing, you should get a check engine or service engine soon light as it will allow excess air into the system.
(Second photo from e-bay)
M.Wong
Old 02-09-2006, 08:29 AM
psychop's Avatar
psychop psychop is offline
Fastest 528iA in the EU;)
Mein auto: E39 528iA
For the 1998 no need for the tool; piece of wire will do just fine
E39 528iA/Steptronic,Professional DSP,Comfort Seats,Soft Leather,Xenon,PDC
Old 02-22-2006, 01:07 PM
jimmerbimmer jimmerbimmer is offline
Mein auto: car
Lightbulb Oil Change
You don't have to jack the car up to drain. Just turn the wheels all the way to the right side. It is actually hard to find the plug. It's on the right. Behind right wheel. I don't have a picture, but it would help.
The hard part is resetting the idiot lights. You have to short out 2 jumpers on the diag. I also don't have that detail right now but might post it later...
Old 04-05-2006, 04:55 PM
darrendrake darrendrake is offline
I have a 2000 528i and attempted the reset of the service interval (green lights) indicator. I used the paper clip approach (looped both ends a little) and placed one end in position 7 and one in position 19 (look closely, they ARE numbered). After setting the paper clip in place, turn key in ignition to the 2nd position (DO NOT START) and then get out of the driver's seat and walk back around to the paper clip and remove. The turning of the key and the walk may take a total of 10 seconds. After pulling the pin out, check the dash- the lights will all be green. Secret is having dashboard lights on while SIMULTANEOUSLY removing pin.
Old 05-20-2006, 02:28 PM
truelies truelies is offline
Mein auto: 528i 2000
I am difficult to find a jack or a ramp to do oil change. Do you mean we even don't need to jack the car up? I only have a jack with my bmw.
Old 06-30-2006, 09:29 AM
d101 d101 is offline
Mein auto: 1982 528i
Smile inspection light reset
can any one tell me how to reset the inspection lights on my 1982 528i thank u my e_mail is jamesburns45@hotmail.com
Old 07-02-2006, 09:16 AM
M.Wong's Avatar
E30 E38 E39
Mein auto: The E38
Don't use the emergency jack in the trunk, they are quite unstable. If you have no access to a floor jack and jack stands, or ramps, and you can't get to the plug, you might drive half way on the sidewalk (and half on the street) or onto a couple of very solid 2x10 planks.
I'd buy a floor jack and jack stands (or ramps, but I prefer having the jack/stands) before buying a top sider oil remover.
But on the 6 cylinder, I think you can do an oil change without lifting the car. (The V8 needs a little more room to access the plug.)
M.Wong
Old 07-02-2006, 09:19 AM
M.Wong's Avatar
E30 E38 E39
Mein auto: The E38
This is from an E30 site, but I am pretty sure your car would be the same as the "pre 1987 connector" section:
Service light reset
(photo from bmwE30.net)
(photo from my 2000 E38, which looked like my 1987 E30 connector)
M.Wong
Old 07-09-2006, 06:49 PM
superghost superghost is offline
Mein auto: 97 528i
Paperclip reset
Just wanted to let everyone know that the reset service with paperclip did not work for me, not sure if it was the paperclip itself or something else, but I used a 1 inch long 12 gauge wire and it worked perfectly after that.
Now, my oil filter cap is badly stripped from previous owner and its a pain to take out. So I went searching for the part online and I can't seem to find it. Does anyone know where I can find just the oil filter cap, other than the dealer?
Old 07-25-2006, 08:48 AM
Tony Tony is offline
Mein auto: E39 528i, 57 Bug,97 Jetta
Hi Ketchup.
Old 07-25-2006, 05:11 PM
ptabaco ptabaco is offline
Mein auto: 98 528iA Cosmos Schwarz
Oil Filter Housing Cover
Pelican parts
http://www.pelicanparts.com/bmw/cata..._pg1.htm#item1
1998 E39-528i
Old 08-05-2006, 08:46 PM
ProRail ProRail is offline
"Clunker" *****
Mein auto: 1999 BMW 528A
My 99 uses synthetic. The oil change indicator is predicated on using synthetic, since it calls for a change at 12-15K. Natural oil would not last that long.
Old 08-07-2006, 08:48 AM
gtx510 gtx510 is offline
Mein auto: ist kaput
For those who don't have or can't find metric tools.
17mm = 11/16"
36mm = 1-716"
Bav Auto and Mini Mania sell a (36mm) oil filter cap socket for under $20.
It's not really that good to run your oil past 10k, even with synthetics.
The purdent thing to do it change you oil at the 7-8k mark and not reset the lights.
(German) Castrol 0W30 from Autozone is the best oil for the money, $5.50/qt.
It's better than BMW Hi-Po 5W30 and M1 0W40. It's almost a xW40 and about as thick as M1 0W40. And it's LL-01 approved.
If you want a thicker xW40/LL-98 oil, I'd rec'd Motul, Amsoil, Liqui-moly, or Elf. You can get them on the net for about $7/qt.
Redline 5W40 would work well but I don't think it's LL-98, but that really doesn't matter.
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
