Old 06-11-2010, 10:36 AM
TexasBMW's Avatar
TexasBMW TexasBMW is offline
Mein Auto: 08 X54.8 04X54.4 00E46CiC
Thumbs up 2008 X5 Spare Tire
I have my factory spare tire on due to a ruined RFT. New tire is here Tuesday, from CA.
Question: has anyone extensively used their spare tire? And, how fast have you driven it?
The tire says 50mph limit, which I'm guessing is because of heat issues?
I need to drive on a roadtrip about 330 miles each way. How bad of an idea is it?
2013 X5 5.0 Black 02/13
2008 X5 4.8 Space Gray/Tan/Dark Burl - Delivered 01.30.08
2004 X5 4.4 Silver. Acquired 02.12
2000 E46 Vert
2001 X5 4.4, Ret.
Old 06-11-2010, 10:50 AM
georgejm georgejm is offline
Mein Auto: BMW X5 35d
Nope, I would not do it. The spare is not meant for road trips but to manage you way to repair/replace shop to deal with the damaged tire. Now if you were talking about ten or twenty miles then that would not worry me so much but 660 miles is asking for trouble I would think. Just another part about RFT's I dislike, they are hard to find when you have a situation such as this. But it is good that you had a spare as why I ordered one with my new X5.
Old 06-11-2010, 11:03 AM
TexasBMW's Avatar
thanks for that advice.
These 20" are never in stock in any town with a population of less that 2MM!
2000 E46 Vert
2001 X5 4.4, Ret.
Old 06-11-2010, 12:10 PM
This is what made my head hurt when going through possible scenarios with the RFT's. Say you have 15000 mi. and the front left blows out at a cost of $400.00 to $500.00 for a new tire, is it wise to leave the front right alone or replace that one too so they at least match tread life and proper balance? So all of a sudden you pick up a nail and it cost you $1000.00 if you do the correct thing. And because RFT's are soft on the bottom by nature you are more susceptible to more punctures than normal tires. That's a tough nut just for a nail in the road not to mention potholes and such.
Old 06-11-2010, 12:51 PM
TexasBMW's Avatar
Actually, I'm one of the few that likes the RFT. I travel in remote areas very frequently and they have actually allowed me to carry on with out changing a tire. And, you can repair them, contrary to popular lore.
I am only replacing one tire. The other side has about 10k on it.
2000 E46 Vert
2001 X5 4.4, Ret.
Old 06-11-2010, 01:21 PM
Don't get me wrong, I believe RFT's have good attributes as well which makes my head hurt. The tire could save your life or make your life miserable.
Old 06-11-2010, 01:26 PM
TexasBMW's Avatar
Absolutely. I think we can all agree on that!!
2000 E46 Vert
2001 X5 4.4, Ret.
Old 06-11-2010, 01:34 PM
ard ard is offline
Resident Curmudgeon
And now due to lack of a full size spare and BMWs reliance on RFTs for dealing with a flat tire, you have to rent another car for your 660 mile trip.
I for one do not like runflats since they involve, usually, "no spare tire".
Full size spare for me... even if it is kept at home...
A
Old 06-11-2010, 01:41 PM
Maybe the next time you see a set of tires and rims for sale on the forum and get three other owners to pony up the four of you could have that spare sitting in the garage.
Old 06-12-2010, 05:33 AM
notaminivan notaminivan is offline
Mein Auto: 2008 X5 3.0
FYI, I just replaced a set of 19" RFTs at a cost of just under $300 per tire. Still a lot. Especially with very short tread life compared to non-RFTs.
2008 X5 3.0 - Monaco Blue/Saddle Brown - Sport (back when it meant something).
2004 330XI Orient Blue /Sand
Old 06-12-2010, 06:11 AM
Funf Dreisig Funf Dreisig is offline
Mein Auto: 77 530i & 09 35d
Originally Posted by ard View Post
....Full size spare for me... even if it is kept at home...
I agree.
OBTW the full size spare in the garage only needs to be a spare TIRE of the correct size to fit on your rims. It is fairly easy and cheap to have a tire mounted and balanced for extended use (e.g. a 660 mile trip) while sourcing a replacement for a badly damaged tire. For example when I get new tires, I always keep the best tire out of the old set in the garage. Note: this plan works equally well whether you prefer to run RFTs or non-RFTs.
Funf Dreisig
Old 06-12-2010, 05:00 PM
watt watt is offline
Mein Auto: x5d, mb320 cdi, 335d, xkr
i run out on the arizona strip which eats tyres, so i am interested on how far you have run on a RFT once it leaks? think i can get home 50 miles of dirt? they are called run flat, for a reason????
thanks
Old 06-18-2010, 11:25 AM
TexasBMW's Avatar
Thumbs up
Well, I'm back from the 700+ mile trip, and the spare performed very well, under the circumstances. On both 335 mile legs, I averaged about 68MPH of backroads driving. I cruised at about 78MPH for the majority of the trip. The only issue was bad handling. The tire is very unstable when pressed - cornering at speed was horrible and any kind of bump at speed on that side would shift your car out of lane if not careful.
New tire is on, and it feels good to be made whole again!
2000 E46 Vert
2001 X5 4.4, Ret.
