Old 12-13-2010, 11:04 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Originally Posted by doru View Post
Riskant, in this thread serviced his tranny at ZF Industries - Dortmund. In post #11 he posted that ZF recommends to change the ATF at 100,000 - 120,000 Kms max (60-75 k miles). That's right from the horses mouth.
Having mine done for the first time in two weeks, 65k miles. I have no idea what ATF to use (and don't have the time or energy to wade through all the opinions) so I'll probably defer to the guys at VAC Motorsports recommend. Hoping/praying my TC seal is still intact.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 12-13-2010, 02:26 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
The Mobil product in my post above is the factory ZF/BMW approved product to use. Obviously there are many products claimed to be compatible, but only the Mobil (formally Esso) is the approved stuff. It may be all for not, and really doesn't matter, but transmission repairs are always rather costly, so I tend to error on the side of caution...but obviously the choice is yours to make.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 01-04-2011, 09:50 AM
justin182 justin182 is offline
Mein Auto: '11 335d & '99 Z3 2.3
Just had the multiple drain/fill procedure done using valvoline maxlife. My mechanic called valvoline and verified it was approved for use in my A5S 440Z transmission. Also replaced the transmission filter, o-ring, pan gasket, drain plug and cleaned pan and magnets at the same time. The drain and fill was done 3 times while running the car up to speed in various gears between changes while on the lift.
My car has almost 59,000 miles. Before the change, I had noticed hard shifting during hard acceleration and a slight bit of jerkiness/clunkiness when initially putting it into drive. I definitely notice smoother shifting after the change. I wholeheartedly disagree with lifetime fluid.
Old 10-04-2011, 04:46 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This recent thread by Fudman has a lot of current ZF5HP19 slushbox ATF information:
- E39 (1997 - 2003) > ESSO ATF Alternatives Update
So I'll update the BMW E39 glovebox printout with the following recommendations ...
Originally Posted by Fudman View Post
ESSO LT71141 is a bit expensive ($18+/qt) so I am considering ATF alternatives. ...Valvoline Maxlife ATF cautions against use in BMWs...Mobil 1 synthetic ...Royal Purple ...
... is Valvoline Maxlife ATF still considered a viable substitute for ESSO ATF?...Is Mobil 1 Synthetic ATF still considered a viable substitute
Originally Posted by dvsgene View Post
I've used Castrol Import and it runs great.... Still meets Lt71141 specs.
Amsoil seems to be OK too. Here's the spec sheet
Castrol meets LT71141 and is only $6.29/qt
Originally Posted by rdl View Post
Mobil Super Multivehicle ATF sold in Canada claims LT71141 compatibility
Originally Posted by POof540i View Post
I recently used Pentosin ATF with good results.
Old 10-04-2011, 04:57 AM
ThoreauHD ThoreauHD is offline
Mein Auto: 02/1994 530i 8cylinder
Red line D4ATF transmission fluid and 75w-90 red line gear oil every 30,000 miles. How do I know it works? My 17 year old automatic transmission is flawless.
Old 10-04-2011, 05:45 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
BG for the tranny(deal I couldn't pass up) and Mobil 1 75w90 for the rear diff. Next trans fluid change, it will be either Redline or RP.
Old 10-04-2012, 07:05 AM
bluebee's Avatar
There is a nice large picture of the green automatic transmission sticker posted in this thread today:
Originally Posted by teklord69 View Post
Look under your transmission pan, the model of the transmission will determine what type of fluid you need.
ID:	344297   Click image for larger version
Old 03-20-2013, 04:02 AM
bin01123's Avatar
bin01123 bin01123 is offline
Mein Auto: 2013 535i
I found the OEM stuff for a decent price so I'm just going to go with the Pentosin.
http://www.fcpeuro.com/products/manu...ntosin-8056107
Old 03-20-2013, 10:51 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
That is a decent price... ^^^^....???
LOL...
Um, no....
Old 03-20-2013, 08:52 PM
gibo58's Avatar
gibo58 gibo58 is offline
Mein Auto: 530i MSport
Sticker
Is that corrosion on that pan??? if so
Old 03-20-2013, 09:55 PM
bmw4te bmw4te is offline
Mein Auto: 2003 BMW 530i
I used Castrol Import Multi-Vehicle on my first fluid change at ~75K miles. Run it for 1,000 miles but the tranny felt sluggish. Did another change with Valvoline Import Multi-Vehicle at that point which improved shifting: it got much "crisper", more responsive. So I guess the composition ended up roughly being ~70% Valvoline, 25% Castrol and 5% old original ESSO fluid. I have driven another 5,000+ miles on that cocktail since then. Right now, on slower take offs it shifts smoothly (hardly noticeable) but harder on stronger acceleration. And that concerns me a little bit now .
I am planning to change the fluid again in the next few weeks, but this time, and from now on, I will be using OE fluid: ZF Lifeguard 5 (Pentosin owns ZF). Costs $87 per 6x1L bottles plus shipping from here. It is more expensive than Castrol, Valvoline, RP but so it's a new tranny. Furthermore, I intend to go 30.000 miles on ZF fluid before draining it as opposed to max 15.000 (or rather 10.000) on Castrol/Valvoline.
One thing to keep in mind with frequent tranny fluid changes is that the pan is made up of aluminum and the risk of stripping the threads on the tranny block is real and increases over time. I doubt that BMW engineers designed it to be removed and put back that often.
As for the differential, I change it every 30.000 miles and use Motul Gear 300 75W90 (which is non-LS). Got far better performance with it (no drag) than compared to Red Line.
Old 03-21-2013, 07:22 AM
bin01123's Avatar
LOL...
Um, no....
Ok you got me. I'll say decent for OEM fluid. It was only 3 bucks more than RP. Other places had the OEM fluid for more
Old 03-21-2013, 01:57 PM
bin01123's Avatar
My sticker from my manual 540
Sent from my HTC VLE_U using Bimmer App
Old 03-21-2013, 02:51 PM
firehawk17 firehawk17 is offline
Mein Auto: 97 528i
has anyone had issue with removing trans pan screws?... i fear stripping as i believe mine has never been touched.. but im definitely gonna do this myself in the very near future...I see there isn't a clear consensus on what ATF fluid to buy... synthetic i know that but whats safe? and what components of the fluid make one not up to par from one brand to another?
Old 03-21-2013, 04:59 PM
occhis occhis is offline
Mein Auto: 1998 528iA
BMW 528i to 9/1999 M52: GM THM-R1 (A4S 310R)
I use Maxlife approx. every 30-40K. 3.8 qt drain & fill
Either you are part of the solution, or you are part of the problem.
Old 03-21-2013, 05:13 PM
Mein Auto: 97 528i
how hard is it to change the filter as well?
Old 03-21-2013, 05:50 PM
markhersh markhersh is offline
Mein Auto: 530i, 528it
I bought a 2000 528it w/92000 miles. I wanted to change to trans fluid and filter, so after some reasearch I have an A4S with a green sticker that says use only Dextron fluid. I bought a new filter and gasket and 10 quarts of Valvoline max life atf. I shoud mention that I called the tech hot line at valvoline and the tech told me that Max life was comletly compatable with the fluid that was in there. I referenced the esso # I got from my bently manual. I checked the capacities and figured that i would replace all the fluid. When I drained the pan and took it off I think only about 4 quarts came out. I replaced the filter and checked the level (warm and level) and its running great. I used to have a little slip in lower gears when cold but it went away when warm. This is gone. seems ok, but my question is, I know im mixing old fluid with new, is there a drain plug for the torque converter, or do I just have to made multiple oil changes to insure I have a mostly new fluid ratio?
Old 03-21-2013, 06:02 PM
NZ BMW NZ BMW is offline
Mein Auto: 2007 X5
Multiple changes - from what I understand waiting a few hundred/thousand miles and then changing again will clear most of the old fluid.
Old 03-21-2013, 11:15 PM
I never had problems with removing the bolts as the danger is to strip the housing threads, not the bolts head, when putting the pan back. Get the torque spec from the Bentley manual (it should be low torque anyway) and use a torque wrench.
I am sure there are tons of threads on this subject. It has been discussed just as much, if not more than which brake pads are the best. Also check the Bob Is The Oil Guy (BITOG) forum for recommendation on fluid for your type of tranny.
Hope this helps.
Old 03-21-2013, 11:20 PM
I think that is the easiest part of all job. Filling her up following the correct procedure however is the tricky part.
Old 03-22-2013, 06:38 AM
Mein Auto: 97 528i
cool thanks on the feed back...ordering a filter and gasket today
Old 03-22-2013, 11:13 AM
Yep...
I think I will stick with Amsoil Universal ATF...
Link:
http://www.amsoil.com/shop/by-produc...?code=ATFQT-EA
Note: The price will be less if you are an "Amsoil Preferred Customer".
My car has been through (2) changes now with the Amsoil ATF, and is now due for another...
My ATF thread 1:
http://forums.bimmerforums.com/forum...Don-t-Think-So!
ATF thread 2:
http://forums.bimmerforums.com/forum...*-***!-Part-II
Jason
Old 03-22-2013, 11:23 AM
Has anyone had issue with removing trans pan screws?...
I fear stripping as i believe mine has never been touched..
But I'm definitely gonna do this myself in the very near future...
Synthetic I know that but whats safe?
And what components of the fluid make one not up to par from one brand to another?
The pan screws can shear off very easily.
The pan screws are made of a very soft metal.
A low torque is required, or else you will shear off the heads of the pan bolts when tightening them.
The idea/ fear of using an "aftermarket ATF" is that the viscosity might not exactly match the original ATF.
Also, filling the new ATF is crucial, regarding the correct amount, have the car/ fluid to the correct temperature, and having the car level when filling.
Also, there is "fear" of replacing the original ATF if the car is past 100k miles, because the "boogie-man" / new ATF might dislodge sludge/ gunk in the transmission, and thus causing the transmission to fail...
Jason
Old 03-22-2013, 07:14 PM
I only changed the filter once. Hardest part was getting the pan to break with the trans. Spent much time removing the old gasket from trans and pan. Be very careful when tightening pan bolts - very east to strip the threads in the aluminum trans. Use a good torque wrench and follow the tightening specs.
Old 03-22-2013, 07:33 PM
If you haven't ordered yet, me and many other here would highly recommend for the tranny filter to order the BMW OEM part. It's not a lot more expensive than other brands (~$30) but there have been reports over here of problems with aftermarket filters. And it's just not worth the risk.
Hope it helps.
F.
PS. If you ordered an aftermarket already, well ... you could do a second fluid change in 1000 miles and use the BMW filter then (actually, now I remember that that's exactly what I've done )
