Rear tires showing excessive inside wear - Bimmerfest - BMW Forums
Old 08-25-2011, 03:35 PM
TOMW TOMW is offline
Mein Auto: Truck
My 2001 BMW 525i, has 125,000 miles--my tires (only have 60,000 miles on them) show good tread but just noticed alot of inside wear..appears the camber needs adjusting or could it maybe be the shocks/struts ? Anyone out there having a problem like this , I know BMW's toe out but this is abnormal/// Please Help TOM
Old 08-25-2011, 03:42 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
This is very normal for a BMW. It is one of the factors that attribute it to great handling. Typically, the rear tires are adjusted for -2 deg of Negative Camber in a WEIGHTED alignment.
Depending on driving loads, this negative camber may be exacerbated if it was previously aligned in an unweighted position.
If you prefer longer wearing tires over more understeer handling, ask your alignment specialist to dial out the negative camber in a weighted alignment.
Also, worn suspension parts can affect the settings. If at 125K miles and still running on original suspension parts, I strongly suggest a suspension overhaul before performing the proper alignment.
Old 08-25-2011, 03:44 PM
moots's Avatar
moots moots is offline
Dinggg....what now!
Mein Auto: '04 525i
BMWs don't toe out but have -ve camber set up.have your camber adjusted first and maybe check some of the multi link bushings for wear......
Old 08-25-2011, 03:51 PM
Not so. ALL cars can toe out if the car was lowered, a suspension part is bent/worn or due to an improper alignment. But yes, a NORMAL BMW aligned correctly has slight toe-in at the front and rear if within specs.
Old 08-25-2011, 03:52 PM
NNY528i NNY528i is offline
Mein Auto: 1997 528i
can you describe the wear pattern, ie how wide is the worn area, if very narrow then you probably need ball joints or other rear suspension componenets, if from middle of tire to inner edge then is probably just normal wear.
>'97 528i, 202500 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers Coming soon 5speed conversion
>'65 & '74 MG Midgets BFC OT Lego Club #48
Old 08-25-2011, 08:06 PM
agent15's Avatar
agent15 agent15 is offline
Mein Auto: 87 325is, 02 530i Sport
I'd be thankful, nee amazed, that my tires made it to 60,000 miles and replace them.
Originally Posted by Fudman View Post
For me, the e39 is the ... best balance of luxury ... performance ... good looks and class. Sort of the Catherine Deneuve of cars, if you get my drift.
Old 08-25-2011, 08:10 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
Michelins
Old 08-26-2011, 04:26 AM
im sorry just noticed the 60000 miles on my tires comment. it sounds like you got your buck out of those tires, the last set of ultra performance summer tires I had lasted about 25000 miles.
Old 08-26-2011, 06:30 AM
Mein Auto: Truck
Tire wear
Thanks for your feedback, I'm grateful to get the milage on tires just concerned me if shocks could cause this wear...Tom
Old 08-26-2011, 06:59 AM
cn90 cn90 is offline
#1 Cause: Worn REAR Ball Joints.
As others said, a REAR Suspension Overhaul will help:
http://www.bimmerfest.com/forums/sho...d.php?t=545345
#2 Cause: factory negative camber is -2 degrees or so. I dialed my REAR Camber to -1 degree and I like it much better that way.
Less inner tire wear.
If you have the gut to do this alignment at home, here is the DIY, enjoy:
http://www.bimmerfest.com/forums/sho....php?p=6137693
Old 08-26-2011, 02:34 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
Unless you buy Continental Extreme Contact DW. I got 14k out of the rears before I was just above the wear bars (I don't like to get them too low in rainy Seattle) Switched to DWS now....I expect considerably longer wear.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
