E36 (1991 - 1999)
Old 06-13-2010, 08:41 PM
gcbimmer gcbimmer is offline
Mein Auto: 2001 540i/6
1998 328i ac/heat not working...need help!!
Need help... 1998 328i ac/heat not working. The climate control computer lights are out and pushing the buttons does not activate the blower. It seems to have a mind of it's own and works on occasion, but under no certain circumstances. Any suggestions on what the problem is or what can be done to repair this before it has to go to the indy?
Thanks in advance!!
Old 06-14-2010, 09:05 AM
Did I not give enough info? Did I post to the wrong forum? Or has no one had this problem?
Thanks.
Old 06-14-2010, 09:15 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Did you look at your fuses and relays?
Have you used a voltmeter to see if the unit itself is getting power?
Are the wires going to it in good condition? Have they been chewed by what looks like a mouse?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 06-14-2010, 09:16 AM
jonesin's Avatar
The Canadian Prick.
Also with what's wrong, it helps us immensely for you to tell us what you have tried/done.
Old 06-14-2010, 09:17 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
This doesn't sound like it's a blower resistor or final stage unit. Rather, it seems like it's a problem with the climate control head unit itself, or possibly some wiring as mentioned above. Does THIS article help any?
1998 BMW 328is
1966 Pontiac GTO
Old 06-14-2010, 09:52 AM
I just got to look at it yesterday for a friend of mine. I figured I could get pointed in the right direction before the elimination process begins. I was just hoping to get a game plan together and take it from there.
Old 06-14-2010, 09:58 AM
I did see that article when I was doing some research prior to even seeing the car...thanks. We'll have to check the wiring and go from there. As I mentioned in the earlier reply I just saw the car yesterday and it was a quick look and it was just a look.
Thanks again.
Old 06-16-2010, 03:00 PM
Leusent Leusent is offline
Mein Auto: 328is
Mine does that exact same thing. Fuses are OK. Honestly didn't check relays, though in retrospect I should have. I ordered a new FSU because I had done a lot of research and that appeared to be the most likely cause (I realize most FSU failures don't act this way, but this type of behavior has been seen). My next best guess is a physical break in the wire going to the blower. I have also read about the circuit repair in at actual head unit, but that behaviour doesn't seem to match up -- there is no visible issues with the display on the unit.
I should be able to pop in the FSU on Friday morning. I'll let you know. If you figure it out before me, give me a heads up so I can try to return the $107 FSU part
Craig
Old 06-17-2010, 11:55 PM
Mein Auto: 328is
Replacing the FSU fixed my problem. See: http://forums.bimmerforums.com/forum....php?p=3349096
Note that those install instructions weren't 100%, but pretty close.
Craig
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
Old 06-17-2010, 11:56 PM
Mein Auto: 328is
By the way, hi Jonesin. I drive the same car as you (1997 though) and I'm in Ottawa too. Catch you around sometime.
Craig
