Old 06-16-2010, 11:27 AM
M5WannaBe M5WannaBe is offline
Mein Auto: 2003 540i/6
Driver's seat rocks or shifts?
I've had my 540i/6 for almost a month, and am enjoying it immensely. The sport seats are pretty snug, but comfortable. I've noticed, particularly on left hand turns, that the driver's seat seems to shift or rock slightly. It's subtle, but a little disconcerting, and makes me worry about the long-term health of the seat. I am admittedly a fat bastage (6'3", 290 lbs), which I'm sure doesn't help, but I haven't had this issue in any other cars. The interior is in great shape, and I'd like to keep it that way. I've searched the forums, but haven't found anything that specifically addresses what I'm experiencing.
Anybody run into this? Any known fixes?
Old 06-16-2010, 11:34 AM
cn90 cn90 is offline
Go on a diet?
Old 06-16-2010, 11:45 AM
SSJRICH 540i's Avatar
SSJRICH 540i SSJRICH 540i is offline
2000 M5
Mein Auto: '00 M5
Dude that is harsh!!
I have the same problem too!
When I hit a corner sharply my seat will "click" and move very slightly...
Current - '00 M5 - '02 530i M sport - '02 X5 4.4i Sport - Old - 00 540i/6 M sport -Old - 97 540i/6
Old 06-16-2010, 11:58 AM
Sorry, I was just joking LOL!
I wrote a DIY for fuses under the seat here. You can see that the seat is held by 4 Torx 50 bolts.
I took a whole bunch of under-the-seat pictures. If you want I can post them later when I get home.
Make sure these 4 bolts are not loose!
http://www.bimmerfest.com/forums/sho...d.php?t=459397
Old 06-16-2010, 01:03 PM
Thanks cn90, I'll give those bolts a look.
Old 06-16-2010, 01:23 PM
On the driver's side, there is a plastic cover (smaller Torx bolt) covering the access to the Seat Torx Bolts.
Old 06-16-2010, 09:06 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Have the exact same issue, but I'm 100# lighter, so prob not due to your weight. Took it to the stealer shortly after buying the car and they charged $90 to tell me I needed a seat rail that cost about $700. Paid the 90 and never looked back. 7 years later have the same click, although I did find a used seat rail for about $150 that's sitting in the garage waiting to be installed.
Either you are part of the solution, or you are part of the problem.
Old 06-16-2010, 11:20 PM
rashid rashid is offline
Mein Auto: X5 E70, 4.8 - 2010 White
it it electrical seat?
Old 06-17-2010, 07:57 AM
Very interesting, thanks for the info!
Yep, it is.
Old 06-17-2010, 01:53 PM
weasel like's Avatar
weasel like weasel like is offline
Technical Graphite > ALL
Mein Auto: E39 528i 5-speed
I too have this problem. Haven't been able to resolve it. Will have to check out the torx bolts sometime this weekend. Please post if you figure it out!
Rules to live by:
- Fast, reliable, cheap. You can only have two.
- BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
Old 06-17-2010, 06:39 PM
Noisy seats is a common problem on the E39 to my knowledge. Lubing & glue gun in certain positions may reduce but difficult to solve the problem fully unless you change the seat.
Old 06-18-2010, 12:03 PM
aliaw528's Avatar
aliaw528 aliaw528 is offline
Mein Auto: 2008 535i
BMW Tips and Tricks page
http://www.bmwtips.com/
Look at the 3 pages regarding Seat Clicking Noise under Interior
Mine does it once in a while, not consistent enough to worry me yet.
Old 06-18-2010, 12:49 PM
If you look at this E38 write-up, once the seat is out of the car, you have access to the rail.
It works almost like a rail road train.
You might want to try some pipe clamp and gently clamp the rail a tiny bit to tighten it up.
http://www.bimmerboard.com/forums/posts/567475
Bottom of an E38 seat FYI:
Old 06-18-2010, 01:01 PM
Another good reading:
http://faq-bmw.vancouver.bc.ca/530/e...ms-759244.html
