BMW X3 transfer case problem - Page 12 - Bimmerfest - BMW Forums
Old 08-17-2014, 11:54 AM
fastm3 fastm3 is offline
Mein Auto: 2005 X3
Originally Posted by swampX3 View Post
with access to a lift this job is 1/2 to 2/3 of one day
we once installed a ford transfer case in the airport parking lot in New Orleans .....4 of us just off the plane from from Alaska ......kids bought over two jacks/4 stands and oil/tools ......took 2 hrs......!
I've seen many actuators installed in 30 mins....the dealer shop hrs have no reality basis
also ....dyall need the actuator motor or just the gear
Thanks again for all the links and info, swamp.
With regard to the actuator, I thought all that sometimes goes bad is the gear (which costs only about $30), but I'll leave that to people who know more than I do. One question though - once the transfer case is opened up, is it straightforward to access and replace the actuator gear?
Past BMWs:
1983 320i
1987 325
1996 M3 (ED)
1998 M3 Cabrio (ED)
2002 530i (ED)
Current Cars:
2005 X3 (ED)
2006 Mini Cooper Cabrio
2006 Porsche 911 Cabrio
Old 08-17-2014, 12:01 PM
swampX3 swampX3 is offline
Mein Auto: bmw++many
gear etc
another good generic transfer case tear down for you
you are correct about the gear ......it's quite easy to replace ....lots of good vids etc on diy.....here's an 05 X5 generic .....nearly identical to yours
http://www.youtube.com/watch?feature...&v=3xEJbpVupuw
Old 08-17-2014, 12:14 PM
a good x3 actuator vid
some good pointers in this but he didn't know about the replacement plastic gear ....shows the value of this fest
also shoudda pointed out that the actuator with the pesky gear is planted on the outside of the transfer case so it's very very easy to pop off if the case is out of the X or if it's still on the vehicle and you lower the support as he does in the video
Old 08-17-2014, 12:17 PM
a good actuator plastic gear company
this is the known quantity nylon / carbon fiber reinforced gear .....yer pays yer money and yer takes yer chances !.....there are other makes on flea baby etc.....but best be sure of what you buy
Old 08-17-2014, 06:03 PM
transfer case top bolts
some good vid of the top bolts that are hidden from view when you're under the X
Old 08-29-2014, 08:56 PM
Mein Auto: 2005 X3
Duplicate post!
Mein Auto: 2005 X3
Just had the chain, the actuator motor gear and fluid replaced, and am glad to report that the dreaded clunk is GONE! According to my indy who did the job, the chain was loose, but the old gear seemed OK.
A BIG THANKS to Swamp for all the info and tips!!
Past BMWs:
1983 320i
1987 325
1996 M3 (ED)
1998 M3 Cabrio (ED)
2002 530i (ED)
Current Cars:
2005 X3 (ED)
Old 08-30-2014, 06:23 AM
here's wishin
a darn good outcome ....here's wishing you another 50,000 miles with no problems !
Old 10-03-2014, 09:18 AM
lovemotorbikes lovemotorbikes is offline
Mein Auto: 04 3.o x3
transfer case
hey steve, any further news on the noises from the transfer case, mine has that very noise when going over a bump at low speed, rgds dave
Old 11-14-2014, 03:21 PM
mchaney mchaney is offline
Mein Auto: X3
X3 transfer case noise
It sounds like I have had better luck. My 2006 X3 176k miles and I started hearing the noise
in 1st and 2nd about 5k miles ago. My local Mechanic has told me to keep driving it, he's heard worse.
I still love the car, thinking of having it fixed and letting the kids drive it around town.
Is it worth having them rebuild this?
Old 11-24-2014, 02:46 PM
BMW-North BMW-North is offline
Kostspieliger Spaß
Mein Auto: 325ci;330i;330xi;325xi,x3
Hi - Great thread - I spend most of my time on "the other forum" but I've read through this thread as I'm picking up a used X3 for my wife. I've owned a couple AWD BMW's going back to my first one - a 1989 325iX - I used to keep a spare transfer case for that thing - ha ha. I had an X5 for a couple of years without any transfer case issues fortunately, but I'm preparing for them with this X3.
When I test drove this (new to my wife) X3 I paid close attention to any noises or issues with the 4x4 - seemed ok. No error lights and the shifting and driving was smooth. The car salesman went into shock when I floored it half in a snow drift at about 40 mph as I wanted the xdrive systems to engage.
After the test drive I told the dealer I wanted to run my diagnostic on the vehicle and all the modules were clear with the exception of the VTG which showed an Oil Abrasion Error. Since I had not seen that error with any of my prior BMW's I searched online and ended up at this thread.
After reading through the thread I understand what I need to do with this used X3 which is approaching 100k. I'm hoping that the trans oil has been replaced at least once before I do it now ( lack of maintenance records). I will use my DIS to reset the adaptation values. I'm prepared to replace the plastic gear and chain but will wait till after doing the oil & adapt. reset to see.
Do folks here who have replaced the TC chain and sprocket see this as a preventive maintenance job or as a reactive repair job to appearing symptoms (chain knock - trio light etc.)? Should I wait till it acts up or do it prior?
Lastly - I saw quite a few posts here where folk were unsure how the X-Drive worked and how it differed from prior BMW AWD systems (myself included) I know none of my prior vehicles e30, e46 (X5 excepted) had a VTG module that required resetting so I've attached a BMW training document that does a good job explaining the Xdrive system.
Old 11-25-2014, 06:08 PM
kma90 kma90 is offline
Mein Auto: 05 bmx x3
I have an 05 x3 with over 150000 miles on it and it started to make a grinding/howling noise. I took it to bmw and they told me my gaskets are leaking on my transfer case, I do have a warranty but unfortunately it doesn't cover gaskets and its going to cost me $1200 to fix it. I called another bmw shop and they said they've never heard of such thing and I shouldn't ever have to have those gaskets replaced and the transfer case is completely sealed. Does anyone have any idea what else this could be in the transfer case or has anyone ever had to replace them?
Old 12-02-2014, 05:19 AM
UberXY UberXY is offline
Mein Auto: 00 M5
OK, here's a slightly different take on the xfer case.
My wifes '08 automatic had a set of Pirelli Scorpions with about 7k miles on them. One front tire was damaged on a trip, so she bought two new front tires. When she returned home she said "the brakes are clunking when I come to a stop". Which meant to me the transfer case was thunking. When I drove it, there was a pretty good thunk in the last few feet when coming to a stop
I swapped the new fronts with the 7k rears, and the thunking is gone. Is the AWD system in the X3 so sensitive that it is bothered by 7k miles difference in tires good for 40k? Normally I buy four tires at a time, but I couldn't see throwing away all four low mile tires to replace one damaged one.
BTW I had an MB G500 that had a crappy plastic gear in the xfer case. It rotated as a check item on start up. If it did not rotate correctly, the computer would not engage the starter. No one sold spares - you had to buy a new actuator motor. Fortunately, the gear only rotated 90 degrees, so only a quarter of the gear was worn out. The free fix was to take the gear off, rotate it 180 degrees, reinstall, and drive another 50k miles.
Old 12-02-2014, 05:24 AM
guest13015 guest13015 is offline
Account closed at users request
Mein Auto:
Yes the Xdrive system is very sensitive even if you have different tires/air/brand etc. Trust me I changed 2 times Xdrive and the fallt was by the tires!!!!!!
Old 12-31-2014, 04:55 PM
spencefletcher spencefletcher is offline
Mein Auto:
Hi,
Re the X3 Xfer case, my 07 X3 (3.0d xdrive model) with 250000 km had a series of clunks on acceleration, especially up hill. I recently changed the oil in the Xfer and like magic, the car drives as smooth as a peach.
Highly recommend this simple and quick fix to anyone who doesn't want (or think they need) to meddle with the gear or chain as a first step in the diagnosis of Xfer case issues.
Old 12-31-2014, 05:27 PM
surfsupjoe125 surfsupjoe125 is offline
Mein Auto: X3 3.0i
X3 transfer case
Hi all
Well I have experienced just about everything on this forum. I did rebuild the xfercase and gear. One thing I can say, whenever you experience the shudder, clunk, knocking in the xfercase, FIRST, change the fluid. It seems to be vitally important. It usually fixes the problem. If you experience the clicking sound when started or after turning off it is the actuator gear. It's a cheap fix and be done without removing xfercase. In some cases with a lot of miles, the xfercase chain is probably stretched and after replacement drives like a dream bi would ALWAYS check the xfercase fluid first. It is amazing how it responds when topped up or changed. Since there is no gasket, they develop leaks and you can be driving with very little fluid in it and it's is not happy, LOL
CHEERS
Old 01-05-2015, 05:17 PM
jmedeiros40 jmedeiros40 is offline
Mein Auto: 2008 X3
Well all I can say is, I maybe looking to trade my 08 in. I'm somewhat mechanically inclined but I don't think I would want to have to fix that problem. I just broke 101500 miles on it, I bought it used, it had 68.000 on her when I bought it. I haven't had any of these signs but why wait, between what I've read about the water pump and expansion tank, the panoramic roof and now this monster repair I might even be willing to take a hit on it and dump it. I did check with my mechanic who has been with Mercedes and BMW for over 40yrs, and he told me they had a good little motor. I guess there is more to a vehicle than the motor.
Old 01-05-2015, 06:32 PM
Mein Auto: 2004 X3 2.5i
Originally Posted by surfsupjoe125 View Post
.... Since there is no gasket, they develop leaks and you can be driving with very little fluid in it and it's is not happy, LOL
Which part of the xfer case were you referring to with no gasket?
The drain and fill plugs have a thin copper gasket:
http://parts.bmwofsouthatlanta.com/p...119963308.html
That part no. is used in over 100 BMW applications.
I bought a couple online but now I see that I could have just gone to the local BMW motorcycle store and got them at the same price or less.
Looks like m/cycles use them somewhere in their engine or transmission.
Maybe you meant the case itself is assembled w/o a gasket?
I would think where the drive shafts enter would be the place where seals could leak?
As the actuator sits more or less on top that should not be a problem.
Old 01-19-2015, 10:54 AM
DriveThruRecFan DriveThruRecFan is offline
Mein Auto: 1999 bmw 328i
My BMW dealership confirmed that the divider oil is the re-brand of this:
Much cheaper. $14.05 per liter
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 01-19-2015, 03:56 PM
R ODonnell R ODonnell is offline
Retired
Mein Auto: 2009 E83 X3
I'm pretty sure it's nothing but manual transmission gear oil.
http://www.febi.com/fileadmin/user_u...B_internet.pdf
BMW's xDrive "power divider oil" is much more than that.
Old 01-19-2015, 04:40 PM
We often see on this forum that you can't believe everything a BMW dealership tells you.
There is no doubt that the BMW fluid is made by Shell and is TF-0870.
No disputing that it shouldn't cost anywhere near $50 even if the additives in it (over other 75W GL-4 gear oils) are very exotic.
I see the Febi oil has been used by VW manual gearboxes well before BMW developed xDrive.
The quoted weight of a 1L bottle of the BMW oil is 1.8lb. compared to 2.1lb. for the Febi. Not sure if the difference can all be in the type of plastic container.
Here's the material safety data sheet for the BMW fluid:
http://www.worldpac.com/tagged/Trans...22_0397_24.pdf
Can't find anything in the Febi description to directly compare.
One other clue - the BMW product used to tell you on the label to shake before using (to mix the additives).
Not sure it still has that, but I have never seen it on other gear oil containers.
Old 01-21-2015, 05:26 AM
enjoydriving enjoydriving is offline
Mein Auto: 2.0d X3, 2015
Today I checked the magnetic plug I placed at the transfer case drain plug position 10K KM since last oil change. The finding is shocking, lots of metal particles on the plug. I am not sure how to attach the comparison photos here.
Although I've used synthetic TF-0870, it looks like I need to change the oil more frequently.
Old 01-21-2015, 05:38 AM
Now photos are attached:
Old 01-21-2015, 05:43 AM
Burning2nd's Avatar
Under the lift arms
thats not that bad... you could say thats normal
when it comes out looking like a small mountain... thats bad
15486372<-----
