Old 06-24-2010, 11:17 AM
phnman phnman is offline
Mein Auto: 2000 528i
Oil drain plug
I'm changing my wife's oil in her 2000 528i. The Mahle filter comes with a copper washer for the drain plug. There's already an aluminum washer on the drain plug. Am I supposed to remove the aluminum washer first, or are there supposed to be two washers? ( aluminum and copper ).
May seem to be a stupid question, but the aluminum washer doesn't want to come off.
Old 06-24-2010, 11:44 AM
cn90 cn90 is offline
Pry with a small screw driver, the aluminum washer will come off. If not, leave it there and re-use it.
One (1) washer only!
Old 06-24-2010, 11:45 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Does it look like this?
Old 06-24-2010, 12:20 PM
Thanks cn90. Easy enough. Also, when shorting pins 7 & 19. With engine running?
Also thanks bluebee. It looks that way now that I've removed the aluminum washer.
Old 06-24-2010, 12:41 PM
- Use white out paint to paint these 2 terminals. The numbering is very very small and easy to get mixed up.
- Reset with Key in Position II (Engine off).
READ THis by QSilver7:
http://forums.bimmerforums.com/forum...75&postcount=9
Old 06-25-2010, 08:58 AM
Thanks cn90. Worked just as written.
Old 06-25-2010, 09:22 AM
bluebee's Avatar
The reason I posted the picture of the oil drain plug in situ was that it looks like there's an extra washer due to the shape of the drain bolt.
The drain bolt has a nicely machine circular landing that I thought was an additional washer while it was on the car; but off the car, it shows itself to be part of the drain bolt as shown below.
Old 06-25-2010, 09:24 AM
bluebee's Avatar
BTW, I noticed in the picture below a slight bevel on the copper washer.
Which direction does that washer go?
