Old 05-02-2015, 01:10 AM
BavarianE31 BavarianE31 is offline
Mein Auto: '03 BMW 530i Sport Auto
M52 vs M54 Cooling Systems...
So a friend on mine went out and bought a radiator and expansion tank for a cooling system refresh and realized that he got a M52 setup rather than a M54 (he owns a 530i).
I'm wondering what exactly are the differences between the two? I see that the radiator of the M52 doesn't have a place for the aux water pump and the expansion tank only has 2 ports instead of the 3 on the M54.
My friend will be returning his purchase, but just out of curiosity, could one actually retrofit a M52 expansion tank/radiator into a M54 setup? Would the hoses connect properly? Or are they that different?
Old 05-02-2015, 05:05 AM
m735is m735is is offline
Mein Auto: e23, e32, e34, e39
m52 radiators have the old style clamp on hose connections. m52TU/m54? have the press fit style.
m52TU aux water pump goes to one of the two expansion tank connections, not sure about m52
Does his radiator have press fit connections or clamp on ones?
What year is his?
Old 05-02-2015, 09:53 AM
He has a '98 so I believe it's the old style clamps. Doesn't seem easily possible to retrofit huh?
Old 05-02-2015, 09:54 AM
Zerodynamic's Avatar
Zerodynamic Zerodynamic is offline
Respect my authoritay!
Mein Auto: 2001 540i6
Even if you could, I wouldn't. I don't understand why BMW has to use the quick connect fittings, they are such a pain!
Current Ride: 2001 540i6/Cosmos on Black/E60 SSK/CDV Delete/ZHP Knob/Euro Corners/M5 Front Bumper w/front respray/SS Brake Lines/Drilled and Slotted Rotors
Coming Soon: Tint/Rear M-Tech Bumper/Cat Back Magnaflow
Past Loves: 00 528iA/95 M3/90 535i5
Old 05-02-2015, 10:39 AM
I can only tell you what the M54 looks like, which is here:
- Behr radiator and Behr expansion (aka surge) tank autopsy (1) (2) & request for another autopsy (1)
Old 05-02-2015, 10:47 AM
Here is a head-on view of mine (M54)...
Old 05-02-2015, 01:19 PM
If his is a 98, then it's a 528i (m52b28).
Your saying he got the radiator that has the quick connect style fittings?
Can you post part numbers for the radiator and expansion tank he got?
It will be easier to just get the correct parts.
I did entertain that exact idea this week. I had a good clamp style radiator and was going to try to fit it in my press fit car. I only thought of this because I have extra parts laying around to play with, like upper and lower radiator hoses to cut up. I just got the right radiator for $120 and did it the easy way.
