E36 (1991 - 1999)
Old 06-26-2010, 09:17 PM
TheRockObama TheRockObama is offline
Mein Auto: BMW E36 318i
96 BMW 318i Overheating
Recently my car has been overheating. It doesn't overheat while I'm driving but only overheats while I'm in idle. I'm pretty new with cars and was hoping you guys could help me find the problem. I'm not low on coolant either and she has 130,000KMs on her. Thanks :]
Old 06-26-2010, 09:29 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
coolonat overhaul
new tstat and housing, water pump, hoses, radiator.....
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 06-26-2010, 10:44 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
is your AC on when it overheats?
Instagram | @randytheus
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
Check the fan clutch, and I'm not sure if the 318 has one, but if it does check to make sure the aux fan is operational.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 06-26-2010, 11:17 PM
No it isn't.
I'll check that tmr after work thanks :]
Old 06-27-2010, 06:34 PM
BimmerBling's Avatar
BimmerBling BimmerBling is offline
College Kid
Mein Auto: 93 318is
^OMG ,, thats how i feel after reading that post.
And to quote another member on this forum, "Preventative Maintenace"
Thats what its all about, yes you could cheap out and just fix the fan (if thats the issue), but in a week a hose cracks, then another, and another, and it will be more expensive than to do an overhaul.
Old 06-27-2010, 07:35 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
Originally Posted by John Deere e36 View Post
you dont need to blow all that mony on a coolonat overhaul new tstat and housing, water pump, hoses, radiator..... like that other guy sed, He must not no nuthin bout cars, Its your Fan, when your car stops movin the air to the radator stop cumin and that whin you need you fan that not workin, Your fan it ant workin , check it out and you will see, That other guy dont know, He just puts parts on untill he acscedently puts the right part on that fixes it, Thats just a big wast a mony
Well you "must not no nuthin bout" these cars. What the other guy "sed" is correct they are ALL about preventative maintenance. The cooling systems in these cars are time bombs. Most need replaced by about 80-90k miles. Since he is having overheating problems, granted it is probably just the fan, but why not knock out something that will HAVE to been done VERY soon? You are way better off to do it and not have to worry about "nuthin". This prevents you from having to limp the car home and run a chance of during a lot of harm to the motor.
Old 06-27-2010, 08:23 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
Correct
I'm so sorry boss, masta told me not to work on duh carz afta I brokeded de centrifigu;ll clutch on me transmizzion
Old 06-28-2010, 01:09 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
I don't know which Fester created the fake John Deere profile, but it must not be Franklyn because the answer he gave is *right*.
If it's fine while you're moving and just overheats at idle, there's a very good chance it's the fan. Most fan clutches fail locked in the engaged position, but perhaps yours failed as disengaged. Wait until the car just barely starts to heat up more than normal, take a rolled up section of newspaper (have it ready before you let the car get warm) and poke it into the blades of the fan. If it slows and stops the fan, even when the engine is getting hot, it needs to be replaced. Not a hard job at all, maybe an hour tops for a first timer.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 06-30-2010, 05:03 AM
Hellawut??
Mein Auto: who knows?
I remember my first time. WAY less than an hour
and it wasnt me. i get SOME stuff right once in a while
-Franklyn
