Old 02-05-2013, 01:37 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Some very nice pics from the fanatics (M54):
Old 02-05-2013, 01:38 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Wow, Doru, those pictures are fantastic!
Here's another side view, showing the knock sensors on the M54 engine:
And, another knock sensor picture from this thread:
Originally Posted by pleiades View Post
Google "M54 knock sensor" and click images to see many other examples of what's hidden down there. The two knock sensors share a single Y-shaped harness with one plug.
http://forum.e46fanatics.com/attachm...1&d=1328597980
You might want to replaces those two plastic pipes too while you're there. They are increasingly a coolant leak source on these aging engines and are inaccessible without removing the manifold.
ID:	360952   Click image for larger version
Name:	Engine front 1.jpg
ID:	364336   Click image for larger version
Name:	Engine exhaust side 1.jpg
ID:	364337   Click image for larger version
Name:	Engine inlet side 1.jpg
ID:	364338   Click image for larger version
Old 02-20-2013, 11:51 PM
bluebee's Avatar
For the crosslinked record, this thread today shows the 'restrictor' that is in the power steering hose:
Originally Posted by energizedmortal View Post
I cut it open and found a valve in there... First attachment shows where air box ate away at the hose. Second attachment is lower crimp cut off hose to show metal piece inside.
Originally Posted by Steve530 View Post
Yep, that's it. Not really a valve, just a restrictor.
Old 02-24-2013, 03:01 PM
bluebee's Avatar
This may be useful to help others understand engine temperature on the M54 engine:
Old 02-24-2013, 03:02 PM
bluebee's Avatar
The E39 EWS hood sensor:
This, about the EWS, may be useful for those with a diamond key:
ID:	365312   Click image for larger version
Name:	DWA Alarm Siren Location and Description.jpg
ID:	365313   Click image for larger version
ID:	365314   Click image for larger version
Name:	E39 Hood Sensor.jpg
ID:	365315   Click image for larger version
ID:	365319   Click image for larger version
ID:	365320   Click image for larger version
ID:	365321   Click image for larger version
ID:	365322   Click image for larger version
Old 02-28-2013, 11:41 PM
bluebee's Avatar
This one post covers every single fuse in my 2002 525i (pictures + description):
(Note that F1 to F5 exist in two different locations, just to confuse you, so I'll refer to the ebox ones as EF1 to EF5, and the glovebox ones as F1-F5).
There are SIX fuse box locations in my 2002 BMW 525i E39 (here is a 1997 540i fuse location chart):
  • EF1 to EF5 <= at the back of the ebox under the passenger side cabin air filter housing (5 fuse spots)
  • F1 to F45 <= in the glove compartment top panel (45 fuse spots)
  • F46 to F66 <= directly above the battery (21 fuse spots)
  • F67 to F74 <= don't exist
  • F75 to F76 <= behind the glove compartment (2 fuse spots)
  • F77 to F99 <= don't exist
  • F100 to F106 <= above the battery positive terminal (7 fuse spots)
  • F107 to F114 <= under passenger side front seat carpet (8 fuse spots
IN THE White E-BOX UNDER PASSENGER SIDE CABIN AIR FILTER:
EF1 = 30A, MAF, Cam sensor #1, DME, T-Stat, Evap emission valve (some say it's 30A - DME, Injectors, SMG Hydraulic unit)
EF2 = 30A, Fuel injectors, Both Vanos solenoids, Cam sensor #2, SAS pump electrical valve (some say it's 30A - DME, Idle control valve, Fuel tank ventilation valve, Fuel pump)
EF3 = 20A, Cam sensors, MAF, Crank Sensor, Heated O2 sensors (some say it's 30A, others say 25A - E-box fan, Transmission RPM sensor, CPS, MAF sensor, Fuel pump relay, SAP relay, A/C Compressor relay, Fuel tank leakage diagnostic module, SMG selector lever)
EF4 = 30A, DME (some say it's 30A - Oxygen sensors and oxygen sensor heater circuits)
EF5 = 30A, Unloader relay, power to coils (some say it's 30A - Fuel injector relay)
IN THE ROOF PANEL OF THE GLOVEBOX:
F1 = 30A, Windscreen wiper
F2 = 30A, Headlight cleaning system, Windscreen washer system
F3 = 15A, Horn
F4 = 20A, Passenger comp/trunk lighting, Windscreen washer system
F5 = 20A, Sliding tilt/roof
F6 = 30A, Outside mirror adjustment, Central locking system, Window lift
F7 = 30A, Cigarette lighter
F8 = 25A, ABS/ASC Control Module (Note: F8 was empty in my 2002 525i)
F9 = 15A, Air conditioner, Heated washer jets [JimLev says it handles the heated washer jets and the Check Control Module panel]
F10 = 30A, Passenger seat adjustment
F11 = 7.5A, Servotronic
F12 = 5A, Immobilizer
F13 = 30A, Driver seat adjustment, Steering column adjustment [JimLev says F13 goes to all of the motors in the drivers seat and the two steering column adjuster motors in a left hand drive gas engine E39 built after 9/'99] [cn90 shows an F13 trick here]
F14 = 5A, Engine control
F15 = 7.5A, Diagnosis plug, Engine control (JimLev adds: Oil level sensor, Data connector under the hood next to the ABS module (no data conn after ~6/2000), Alternator, Temp switch in DME box for cooling fan in bottom of DME box, Range switch for automatic tranny)
F16 = 5A, Light module
F17 = 10A, ABS, Automatic stability control
F18 = 5A, Instrument cluster
F19 = 5A, (empty) Electronic damper control [QSilver7 says F19 is in-between the ignition switch and an unloader relay terminal 15]
F20 = 7.5A, Air conditioner, Heated rear window, Heater, Tyre pressure control system [JimLev says F20 and F105 power relay K201, which itself gets power from F75]
F21 = 5A, Anti-glare inside mirror, Driver seat adjustment, Garage door opener [JimLev says F21 also powers the current cutoff relay, garage door opener, rear view mirror, park distance control module, and the cig lighter relay]
F22 = 25A, Fuel pump
F23 = 7.5A, (empty in my 2002 525i) Heater, Rear centre arm rest
F24 = 5A, Instrument cluster, Shifting gate illumination, Tyre pressure control system
F25 = 7.5A, Multi-information display, Radio
F26 = 5A, Wiper Relay I & Wiper Relay II (Note: F26 was empty in my 2002 525i)
F27 = 30A, Central locking system, Window lift
F28 = 15A, (empty in my 2002 525i) Transmission control, diesel
F29 = 30A, Central locking system, Outside mirror adjustment, Window lift
F30 = 25A, ABS
F31 = 10A, ABS, Automatic stability control, Fuel pump
F32 = 25A, Active seat, Electric seat heating, Roller sun blind
F33 = Open (empty in my 2002 525i)
F34 = 10A, Heated steering wheel (empty)
F35 = 5A,(empty in my 2002 525i) Rear A/C blower
F36 = Open (empty in my 2002 525i)
F37 = 5A, Immobilizer
F38 = 5A, Horn, Shifting gate illumination
F39 = 7.5A, Charging socket, Courtesy mirror illumination
F40 = 5A, Airbag, Instrument cluster
F41 = 5A, Brake light, Light module
F42 = 5A, Airbag
F43 = 5A, (Telephone), (On-board monitor), Radio, (Rear Washer) (Rear washer pump)
F44 = 5A, Multi-function steering wheel, MID, Radio, (Telephone)
F45 = 7.5A, Roller sun blind
IN TRUNK BATTERY COMPARTMENT:
F46 = 15A, Blower relay/Parked Car ventilation/Receiever, parked car ventilation (Note: F46 was empty in my 2002 525i)
F47 = 20A,(empty in my 2002 525i) Additional heater, independent heater
F48 = 5A, Anti-theft alarm system
F49 = 30A, (empty in my 2002 525i) Air suspension
F50 = 7.5A, (empty in my 2002 525i) Air suspension
F51 = 30A, (empty in my 2002 525i) Rear cigarette lighter
F52 = 30A, (empty in my 2002 525i) Cigarette lighter (AUS)
F53 = 7.5A, Central locking system [fuel door solenoid issue, which disables the central locking system] [JimLev adds Rear lid motor relay K70, Central locking & fuel door relay K121, Window motor relay K90, Diversity amp or antenna amp]
F54 = 25A, (empty) M5 Fuel pump
F55 = 20A, (empty) Rear washer, Rear washer pump
F56 = 30A, (On-board monitor), (CD changer), Radio, (Navigation system) [Black540eye adds On-board Monitor, Radio, Video Module, CD Changer, Amplifier, GPS Control Module, GPS Receiver]
F57 = 10A, (Telephone)
F58 = 10A, (On-board monitor), (Telephone), Radio, (Navigation system)
F59 = 20A, (empty) Trailer socket
F60 = 50A, (empty) Elecronic damper control
F61 = 5A,Park distance control module/ Seat heater switch, left rear/ Seat heater switch. right rear (empty in my 2002 525i)
F62 = Open (empty in my 2002 525i)
F63 = 7.5A, Radio relay/ Loud alarm relay/ Transparency relay/ Alarm control unit (empty in my 2002 525i)
F64 = 30A, On-board monitor/ Radio CD changer/ Amplifier/ GPS receiver (empty in my 2002 525i)
F65 = 10A, Transceiver (empty in my 2002 525i)
F66 = 40A, heated rear window
THESE DO NOT EXIST:
F67 = (does not exist in the E39)
F68 = (does not exist in the E39)
F69 = (does not exist in the E39)
F70 = (does not exist in the E39)
F71 = (does not exist in the E39)
F72 = (does not exist in the E39)
F73 = (does not exist in the E39)
F74 = (does not exist in the E39)
BEHIND GLOVEBOX (look from underneath):
F75 = 50A, Auxiliary fan (red) [QSilver7 says the aux fan is the electric fan in front of the radiator which also goes on when the AC is initiated.]
F76 = 40A, Heater blower (yellow) [cn90 says it should have 12V when HVAC is turned on][QSilver7 says the heater blower controls the air velocity for the cabin/interior HVAC system.]
Neither of these huge fuses is easy to remove or put back (due to the cramped location), but luckily the yellow one is the one aft, which is easier than the red to remove.
THESE DO NOT EXIST:
F77 = (does not exist in the E39)
F78 = (does not exist in the E39)
F79 = (does not exist in the E39)
F80 = (does not exist in the E39)
F81 = (does not exist in the E39)
F82 = (does not exist in the E39)
F83 = (does not exist in the E39)
F84 = (does not exist in the E39)
F85 = (does not exist in the E39)
F86 = (does not exist in the E39)
F87 = (does not exist in the E39)
F88 = (does not exist in the E39)
F89 = (does not exist in the E39)
F90 = (does not exist in the E39)
F91 = (does not exist in the E39)
F92 = (does not exist in the E39)
F93 = (does not exist in the E39)
F94 = (does not exist in the E39)
F95 = (does not exist in the E39)
F96 = (does not exist in the E39)
F97 = (does not exist in the E39)
F98 = (does not exist in the E39)
F99 = (does not exist in the E39)
ABOVE BATTERY POSITIVE TERMINAL:
F100 = 200A, Fuse panel 4, F107-F114
F101 = 80A, Power supply for fuses F46-F50 and F66
F102 = 80A, Power supply for fuses F51-F55 [wiring diagram here]
F103 = 50A, Open
F104 = 50A, Unloader relay terminal 15
F105 = ?A [JimLev says F20 and F105 power relay K201, which itself gets power from F75]
F106 = 100A, F75, Engine cooling fan relay stage 3
UNDER PASSENGER SEAT: (see more details in this thread & this thread)
F107 = 50A, SAS airpump Special Fuse: BMW PN 6113836590
F108 = ??A, [QSilver7 says this is for the ABS/DSC control unit]
F109 = ??A, [QSilver7 says this is for the DME (motor electronics)]
F110 = 80A, Power supply F1-F12 and F22-F26
F111 = 50A, Data link connector/ Ignition switch
F112 = 80A, Light control module
F113 = 80A, Power supply F13 and F27-F30/ Light Module
F114 = 50A, Data link connector/ Ignition switch
Old 04-15-2013, 05:29 AM
bluebee's Avatar
This picture shows the M52 coolant drain plug location:
Originally Posted by cn90 View Post
Thanks dortega4226 for the detail,
As I already mentioned, the M52 (and M54) engine drain plug sits at the same level as the Water Pump itself.
So if one is doing a cooling overhaul and the WP is out, that is sufficient;
no need to remove the drain plug because there is no additional gain by doing that (only pain, no gain):
Old 04-15-2013, 08:14 AM
doru's Avatar
Concerning the post above: Cn90 remarks that: "As I already mentioned, the M52 (and M54) engine drain plug sits at the same level as the Water Pump itself. So if one is doing a cooling overhaul and the WP is out, that is sufficient"
However, if you have the radiator in place and do a flush, and one uses the lower radiator drain (blue), despite the law of capillary tubes, there will be lots of coolant remaining in the system. The engine block drain plug removed allowed me to drain an additional 1/2 gallon (2 liters) of coolant. the heater core hoses were also removed AFTER I drained the radiator and opened up the engine block drain plug. Nothing came out afterwards, even when I used compressed air.
So the engine block drain plug is doing it's job. However remember to replace the aluminum crush washer once you're done flushing, and button up the plug.
Old 04-15-2013, 02:19 PM
bluebee's Avatar
This is interesting, as the engineers must have had a reason for adding it in the first place; yet, as cn90 mentioned, a heck of a lot of fluid comes out when you remove the water pump.
I only know intimately of one cooling system overhaul, which was mine, in 2010, and, well, what I did was remove all the normal stuff (radiator, expansion tank, water pump, thermostat), and then flush with a garden hose.
It was a royal mess as I was in my garage (lesson learned ... think ahead and park the car where flowing water doesn't have to be mopped up, and only then, start removing stuff).
One thing that struck me though, was that my 9 year old cooling system looked pristine, except for the expansion tank (which was a mess, as shown in the autopsy photos in this thread). The passageways in the engine that I could see (admittedly not very deeply) were clean aluminum.
So, I didn't worry so much about leaving some garden-hose water in the engine. When I filled up, I poured the requisite ethylene glycol (green stuff) first, and then filled it up with water, so, I'm at least at the 50:50 or better point in the end.
Of course, that darn expansion tank blew up within a year and a half - but that's a different issue.
Old 05-04-2013, 11:53 PM
bluebee's Avatar
I don't think we all have this, but here's the altitude pressure sensor (APS) in the E39 528 engine bay:
See also:
- How does the BMW E39 fuel trim behave at high elevation (1) (2) (3) & where is the BMW E39 altitude pressure sensor (APS) (1)
Old 08-05-2013, 01:52 AM
bluebee's Avatar
For the record, this thread has a lot of good information about the M54 engine:
> E39 (1997 - 2003) > M54 Engine Details
Old 08-24-2013, 02:09 PM
bluebee's Avatar
Oil pressure sensor location ... (from this thread today).
See also:
- List of all possible BMW E39 instrument cluster 20-digit alphanumeric display warning/information messages (1)
Old 09-13-2013, 08:55 PM
bluebee's Avatar
We probably should have a separate thread for the V8, but, barring that, here's a nice diagram of the V8 I found here today looking to help someone with a v8 waterpump to fix:
Old 01-07-2014, 05:32 PM
bluebee's Avatar
Originally Posted by JFrawley View Post
Just replaced the DISA valve on my 2003 530 i and while I had the intake hose off, I got looking at the box attached to it. I've seen it many times before but never paid it much attention. There seems to be no obvious reason for it being there. There's nothing attached to it. It just seems to be an empty box below the hose.
Originally Posted by JimLev View Post
Pretty sure it's called the resonator box. It smooths out air pulses going into the engine.
Originally Posted by edjack View Post
It funtions as a Helmholz resonator
Old 09-09-2014, 02:28 PM
mbushell mbushell is offline
Mein Auto: bmw 530i
Originally Posted by bluebee View Post
Good point. My writing mirrors my personality, which is far more loquacious than reticent!
Im just seeing how crazy you are... You helped start this site. My motor is going backin tonite. You are nuts.... and fun to chat with. look for pics
Old 10-01-2014, 05:37 PM
allenwilson33 allenwilson33 is offline
Mein Auto: 02' 525i
@Bluebee do yo happen to have the link to the diagram you created with color coded explanation of the wire harness? I'm doing harness repair on my 02' 525i and can't find a single diagram on the web or on Haynes /chilton.
Guess I need to pony up for Bentley volume 2.
Old 10-02-2014, 05:59 AM
bluebee's Avatar
I'm not sure what diagram you're talking about, but, one of the best ways to find where diagrams come from is simply to follow these simple three steps (at least in Firefox):
1. Right click on the diagram to get a popup with the selection "Copy Image Location".
2. Point your browser to http://images.google.com and click the little camera icon to "search by image"
3. Paste the bimmerfest image URL
That's what I do, anyway ...
See also:
- How to post, shrink, modify, edit, annotate, merge, upload & find pictures for posting here (1)
Old 10-02-2014, 06:16 AM
Mein Auto: 02' 525i
I'm familiar with the process and other search methods across mediums, yet I haven't been able to place the disgram you alluded to in 2010 (page 1 of this thread) thst you'd chart out for the entire m54b25. Not asking for all diagrams, just any thst may contain descriptions of the wire harness. Thanks.
Old 10-02-2014, 12:45 PM
doru's Avatar
Project: M54 Engine
Very detailed descriptions of various engine parts, with fixes, etc - courtesy of "E46 Fanatics"
Here is the excellent thread with numerous Hi-res pictures and detailed descriptions.
Old 10-20-2014, 03:10 PM
bluebee's Avatar
I hope that thread never goes away, because the scores of pictures in it are fantastic!
Links to parts of the project
Versatile Torque Wrench
http://forum.e46fanatics.com/showthr...7#post14300427
Crankshaft
http://forum.e46fanatics.com/showthr...6#post14278286
Pistons and Conrods
http://forum.e46fanatics.com/showthr...9#post14278249
Hydraulic LIfters
http://forum.e46fanatics.com/showthr...7#post14251457
Rear Crankshaft Oil and Seal
http://forum.e46fanatics.com/showthr...3#post14238223
Timing Chain Cover
http://forum.e46fanatics.com/showthr...1#post14238211
Vibration Damper, Front Crankshaft Oil Seal
http://forum.e46fanatics.com/showthr...4#post14238204
Oil Pan and Pump
http://forum.e46fanatics.com/showthr...5#post14238195
Valves
http://forum.e46fanatics.com/showthr...0#post14235440
Coolant Pump and Thermostat
http://forum.e46fanatics.com/showthr...6#post14230966
Head
http://forum.e46fanatics.com/showthr...8#post14230928
Timing Tools 1
http://forum.e46fanatics.com/showthr...3#post14115793
Timing Tools 2
http://forum.e46fanatics.com/showthr...2#post14115822
Camshafts
http://forum.e46fanatics.com/showthr...0#post14098020
Engine Timing
http://forum.e46fanatics.com/showthr...2#post14097982
Vanos
http://forum.e46fanatics.com/showthr...1#post14082281
Idle Control Valve (ICV)
http://forum.e46fanatics.com/showthread.php?t=901978
Throttle
http://forum.e46fanatics.com/showthread.php?t=901968
Intake Manifold
http://forum.e46fanatics.com/showthread.php?t=901967
Knock Sensors
http://forum.e46fanatics.com/showthread.php?t=901979
Oil Separator
http://forum.e46fanatics.com/showthread.php?t=901972
Valve Cover
http://forum.e46fanatics.com/showthread.php?t=901980
Oil Filter Housing
http://forum.e46fanatics.com/showthread.php?t=900804
Fuel Injection Rail
http://forum.e46fanatics.com/showthr...4#post14036694
Power Steering Pump
http://forum.e46fanatics.com/showthread.php?t=899351
Starter Motor
http://forum.e46fanatics.com/showthread.php?t=899366
ID:	470900   Click image for larger version
ID:	470901   Click image for larger version
ID:	470902   Click image for larger version
Old 10-20-2014, 07:17 PM
ca2014mp2 ca2014mp2 is offline
Mein Auto: E39 2000 528ITA
ohhh pop quiz.. I was good till the end.. then the last two got me.. dang nabbit..
Series E39 Vehicle code DP63 Model 528ITA Engine M52TU
Body type OTHER Catalog model USA Production date 1999 / 06
Transmission Automatic Steering Left Catalyzer YES
Production FROM : 1998/09/01 TO : 1999/08/31
Old 10-21-2014, 05:35 AM
E39 Fan E39 Fan is offline
Mein Auto: '01 530i
this thread alone massacres anything ive ever read on MBWORLD
Old 10-21-2014, 08:42 AM
Crutzy Crutzy is offline
Mein Auto: BMW 5-series E39
I didn't know HALF the stuff pictured here!
Old 10-28-2014, 05:48 PM
Mein Auto: 02' 525i
thanks @doru and @bluebee. Still coming up short with color coded wire harness diagram or anything like it. I think the burden's upon me to make one...
Old 11-07-2014, 07:28 PM
bluebee's Avatar
Here's a mystery part on the V8 engine posted here today:
> E39 (1997 - 2003) > plug melting under the hood
