E46 (1999 - 2006)
Old 06-28-2010, 12:36 PM
Nando779's Avatar
Nando779 Nando779 is offline
Send a message via AIM to Nando779 Send a message via Yahoo to Nando779
Mein Auto: 2003 325Ci, Orient Blue
P0174 - System Too Lean (Bank 2)
My check engine light came on today. Took it to Auto Zone and the friendly clerk said it is probably the rear upstream O2 sensor. Anyone know where this is located? Are all the O2 sensors the same part?
My bimmer and the son of Sam himself.
http://www.facebook.com/Nando.Alvarez
Old 06-28-2010, 01:09 PM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
Bank 1 if cylinders 1-3 (front of car) and bank 2 is 4-6 the last 3 closer to the firewall.
However this may also indicate a vacuum leak or the MAF sensor needing cleaned, but these generally show errors for both 02 sensors.
PT
___________________________________
Old 06-28-2010, 01:21 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
+1. Auto Zone always says the 0174 is 02 sensors (and it isn't). The codes for 02 are different and while it COULD be 02 sensor related, it is likely a vacuum leak. Usually a hole in the intake boot tract.
Old 06-28-2010, 02:04 PM
Nando779's Avatar
Cool, I'll check out the MAF and will probably just clean it since I am there. Would you be refering to the intake elbow boot connected to the MAF Shad? The one that is one of the culprites of the whistling problem?
Thank you both.
Old 06-28-2010, 02:33 PM
Razzman Razzman is offline
Mein Auto: BMW 330i ZHP
+1 My light recently came on and my BMW tech said it was most likley a leak if anything. I'm waiting to see if it happens again then I'm going to check for leaks. Doesn't have to be O2 sensor right away.
Old 06-28-2010, 02:39 PM
smolck's Avatar
ROLL TIDE!
Originally Posted by Nando779 View Post
Would you be refering to the intake elbow boot connected to the MAF Shad? .
Yes Or the one that goes to the throttle body (there are actually 2 seperate hoses). A lot of times the tear is where the main inlet diverts into the ICV.
Old 06-28-2010, 02:54 PM
Nando779's Avatar
Cool thanks Shad.
Old 06-30-2010, 12:10 PM
Nando779's Avatar
Check engine light gone! I replaced my air filter, and cleaned the MAF sensor with some CRC MAF sensor cleaner. Actually felt some difference in the acceleration, although my air filter was pretty dirty before. Thanks guys!
Old 07-06-2010, 11:02 AM
superzcomputer superzcomputer is offline
superzcomputer
Mein Auto: E90 328i
Most likely it's a tear in the MAF boot, check for cracks, replace, and fixed!
