Old 05-03-2014, 10:34 AM
bmdubya1198 bmdubya1198 is offline
Mein Auto: '99 528iTA Sport
Exclamation Speaker won't work
I've had this problem for a while, but at this point, it's really bothering me. None of my speakers will work. The MID will turn on, and all of the buttons work like they're supposed to, but there is no audio at all. I was going to look at some cords in the back of the unit to see if anything is bad, but I haven''t gotten the chance yet. I don't think that the speakers are blown, because none of them work, but there is obviously something wrong. Just before they stopped working, I noticed some crackling a popping after I turned off the stereo. I recently replaced the battery, so that is not the culprit.
I just really need some help, because I'm tired of waiting around and not finding anything.
Alex
1999 BMW 528iT Sport M52TUB28- 2-2-1999
--Alpinweiß III/Sandbeige, Style 29 Wheels, 35% Tint, Beisan Vanos Seals, 2,500k Yellow Fogs, German front plate
1998 Volvo V70 GLT B5254T- Daily... running a home-made MBC @9ish PSI
1995 Honda Accord EX F22B1- Junked project... glad it's gone
1984 Nissan 300zx VG30E 5 speed- Sold project... wish I kept it
Old 05-03-2014, 11:01 AM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is offline
Mein Auto: 03 Ex Cop 530d Touring
Hi,
It's impossible to tell via the internet/forum as well as there's multiple areas and reasons for something like this all of which need investigating and checking. You might have a loose connection at the amplifier, a faulty/dead amplifier, continuity issues with the speaker wiring loom, blown fuses, faulty head unit (i.e it's not sending out the switch on signal) and so forth.
In short, you need to spend time fault finding and eliminating potential causes until you find what's wrong. You'll need to try swapping out known working amplifiers and head unit modules etc and then all the checks above.
Cheers, Dennis!
Old 05-03-2014, 07:15 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Do you have a DSP stereo or a non DSP stereo?
Old 05-04-2014, 06:38 AM
I do not have a DSP button on the MID, and I could not find the cords in the CD changer you're supposed to check. I believe that it's non-DSP, though.
Alex
Old 05-14-2014, 02:02 PM
I pulled out the MID and all of the wires seemed in good shape. Again, I couldn't see all 10 speakers blowing out, so I'm thinking that it may be the amp(is that possible)? The display comes on and everything works correctly. The cassette deck and CD changer do not play audio, either, so it doesn't have anything to do with the antenna.
Alex
Old 05-14-2014, 02:39 PM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
you may want to get a multimeter/test light and check the power wire going to the amp as well as teh speaker inputs from the stereo.
Here is a diagram for your reference.
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 05-14-2014, 02:51 PM
Would you know the setting to use for the multimeter by any chance?
Alex
Old 05-14-2014, 02:55 PM
Egestrada05 Egestrada05 is offline
Egestrada
Mein Auto: bmw
setting has to be 2 or 20 v the lead in the V and the black in ground.
Old 06-14-2014, 02:48 PM
Ok, it's been a while since I was last on this thread, but I finally got a chance to check the fuses. They're all just fine (for the radio). I also cleaned out some water that was getting in due to clogged "gutters" around the rear hatch. I don't think it got near the amp, but I don't know if the wires going into a dome under where the spare goes are involved with the stereo. I think that those would be for the self leveling suspension.
I'll check the wires for the amp either today or tomorrow.
Any other ideas?
Alex
Old 06-17-2014, 05:24 PM
Just looked at the amp. Could I get some clarification on where the connectors are and how to test them? I'm not the best with electrical stuff.
Alex
Old 04-21-2015, 12:40 PM
bgldberg19 bgldberg19 is offline
TFRMNC
Mein Auto: 1999 BMW 528I Wagon
I have the same issue
Except I have no sound when I start my car, but If I go and unplug and reset the white plug after I start the car, when I reseat it I have normal sound... Is this a common problem? Also I have an aftermarket Dynavin Head unit, Is there any way to just bypass the amp? I think that there is to much output from the head unit into the amp, as I never have to turn the radio up above about 8 on the head unit (out of 32) and by that time the speakers start to crackle.
Old 04-21-2015, 02:11 PM
You won't be able to use the radio without the amplifier connected.
I ended up replacing my amp to fix the problem.
Alex
