#51
For the crosslinked record, this thread today discusses some of the various water pump brands:
> E39 (1997 - 2003) > 2001 525i Overheating
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#52
I got the Stewart myself because it's a fine piece of well made machinery. |
#53
The Stewart is really finely made, if you get a chance to hold 2 side by side, its amazing
![]() Checkout the pump http://www.bimmerzone.com/BMW_Perfor...STE-30330.html
![]() | Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 | Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!! |
#54
There are pictures of a recently failed Bosch waterpump over here today:
#55
This related question was asked today:
#56
The following question about an "UPDATED" BMW water pump was asked today:
> Now In: Engine Parts Water Pumps Water Pump - M52tu, M54 (Original BMW)Quote:
> Now In: Engine Parts Water Pumps Water Pump - M50, M52, M52TU, and M54 Engines with Metal ImpellerQuote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 02-04-2013 at 06:47 AM. |
#57
Based on careful reading of the Turner Motorsports advertisements above, it seems they're implying that only the "early M50 & M52" engines 'may' have had plastic impellers - after which BMW quickly switched to composite impellers (note: the aftermarket has always had the metal impellers).
Assuming this statement by Turner Motorsports is true, then the only remaining question to answer the OP's question is the following: QUESTION: What E39 models used the "early M50 and M52" engines? (i.e., these would have had plastic impellers originally, but which would have quickly switched to original composite impellers.)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 02-04-2013 at 06:48 AM. |
#58
got a new bosch with a plastic impeller and it went in less than a month. Had to throw the old one back on.
Stewart EMP is the only way to go. Do eeeeet!!!
![]() Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock [---Quote (Originally by Tex330i)--- You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote--- |
#60
I remember vividly about 2 years ago when I did the cooling overhaul, having the OEM WP compared to the Stewart EMP WP. It's like comparing the real deal with a toy. The difference is amazing.
Beside the stainless steel construnction, and very high quality materials, there's an important detail people often overlook: the beefed up bearing, which is very important if you use the OEM fan. That fan is not light, and the OEM sized waterpumps of any brand have the same small bearing rated for how many years? Does not matter if it's composite or plastic. If the impeller holds up, the bearing will go. There have been many reported WP bearing failures. The fan is heavy. The OEM sized waterpumps will hold longer if you use electrical fan.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
#61
For the record, this was asked today:
#62
Thanks after reading the posts on this thread the extra $100+ is worth the money if you consider the peace of mind and the cost of labor to replace the pump again. Thanks bluebee
Newbie question what is npg?
1970 Morris Cooper S * 2008 BMW 135i Coupe * 2008 BMW 128i Cabriolet * 2003 BMW 525i Touring Last edited by Guam135i; 03-26-2013 at 07:10 PM. |
#63
EMP Stewart has the best quality, if you have both in your hands, you will feel it right away, do it once and do it right
We have it for $175 if interested (free shipping 48 states) http://www.bimmerzone.com/BMW_Perfor...STE-30330.html
#64
I tried to put all the abbreviations used in the E39 forum over here:
- BMW E39 technoterms, acronyms, glossary, definitions slang, technical terms, abbreviations (1) But, interestingly, even though I spent perhaps 100 hours on that one thread, I didn't list NPG unfortunately - so you wouldn't have found it there. Luckily, the bestlinks has everything you need at the touch of a keyboard. Typing /npg F3 in the best links, for example, netted this: - What coolant to use (1) & all about propanol-based zero-pressure fluids like NPG+ (1) (2) (3) (4) (5) Clicking on those five threads, we find out this about NPG: Quote:
NPG = A high boiling point (375°F) waterless (ethylene glycol based) coolant used to keep pressures in the cooling system close to zero bar (aka Evans NPG+)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 03-27-2013 at 03:00 AM. |
#65
I did my cooling overhaul today(Behr rad leaking at the seam, unsure of mileage), when I went with the Stewart pump, the one I pulled out of the car had a metal impeller with bmw and a part number stamped on it. Does anyone know if BMW makes pumps with metal impellers? I will post pics of the pump I pulled out.
edit: Stewart on left, Old pump on right ![]()
![]() 1992 Toyota Soarer BPU 1999 BMW 528i/5spd Last edited by kapetajr; 04-21-2013 at 08:27 AM. |
#66
I pulled out a stock BMW pump with 105K miles on it. It was a plastic impeller pump. I replaced it with a stock plastic impeller pump that now has 45K on it. BMW service does the same. Me thinks the lore of plastic impeller pumps from BMW self destructing is way over blown. If they were that bad, BMW would not use them for replacement. Too many pissed customers.
And I see from reading an earlier post from bluebee that what we call "plastic" may actually be composite. "Based on careful reading of the Turner Motorsports advertisements above, it seems they're implying that only the "early M50 & M52" engines 'may' have had plastic impellers - after which BMW quickly switched to composite impellers (note: the aftermarket has always had the metal impellers)."
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
#67
The original pump is made by INA. Replaced mine after 160K kms with worn bearing. Not leaking but bearing noisy. Now at 195K kms and no problems. I expect it to go another 160K kms.
RonR 99 528iT M52TU |
#68
For the record, the question of which brand came up again today over here:
#69
When I bought my car and not knowing that BMW likes special parts I did what I always do and go to Rockauto and start my list of parts.
I bought a URO water pump since it had the heart by it as to be one of the popular parts bought. Has anyone used one of those pumps or know of experience as I have not installed yet. TomK
2002 530iA Sterling grey Metallic 88,000 miles |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
