Old 07-05-2010, 02:06 PM
maherr maherr is offline
Mein Auto: BMW 530i
Help: No Battery power,trunk closed
I disconnected my battery to replace the steering wheel, and accidently closed the trunk. This may sound silly, but how do I open the trunk with no power?
Thanks in advance for your help.
Old 07-05-2010, 02:18 PM
tagus1997 tagus1997 is offline
Mein Auto: E39 525tds
Use the key. Turn to the left (horizontal position).
Old 07-05-2010, 03:19 PM
mnepitjr's Avatar
mnepitjr mnepitjr is offline
Mein Auto: 2002 525 2000 M5
+1 use key turn hard to left. Unless key is inside the trunk.
Old 07-05-2010, 03:44 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
OMG! Key~key lock cylinder~insert key into lock cylinder~turn~should open.
Don't take this personal or the wrong way...you're not the first to ask this...and won't be the last. But it is unbelievably funny that the further we move away from the time when keyless entry was "rare" and has now become "common"...its as if we've consciously forgot that a key can physically unlock things when inserted into the lock cylinder.
And ditto...if there's more to this story...like you've LOCKED your ONLY key inside the trunk...then you have greater issues than what has been suggested so far. You may be screwed and it will cost you if you've closed-up your only key inside the trunk.
Or...you could hook up a battery charger (or another car using jumper cables) to the jump start locations under the hood...then you can use the keyless remote fob to unlock the car like you normally do.
Q {BMW CCA Member #191509}
(SOLD)
Old 07-05-2010, 05:15 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I suspect you could also jump start the car from the hood connection points and then you'd have power again.
BTW, I too am amazed at how many times this question comes up. With a key in our hand, and a trunk lock cylinder staring us in the face, we still blindly ask "how do I open my trunk?".
Interestingly, since I still haven't figured out how to properly repair my trunk loom, (I freeze when I'm clueless) the ONLY way I can get my trunk open is via a mechanical turn of the key.
I wonder if I didn't know already whether I would have been one of those asking how to open the trunk (as the key fob won't open the trunk, the button on the console won't open the trunk, and the trunk button on the trunk won't open the trunk).
But, the key still works. So low tech.
Old 07-05-2010, 07:15 PM
Mein Auto: BMW 530i
Thanks everyone for your help. I was tunring the key to the left but not hard enough thinking that the first stop was the end.
Thanks again!
Old 06-25-2015, 12:32 PM
kjartan kjartan is offline
Mein Auto: 2002 E39 520iA
Happened to me today.
I didn't have enough strength in my hand/finger to only use the key. I actually ended up breaking the plastic on the key!
I had to use a pair of pliers and hold the inner most edge of the key and use a alot of force to turn the key to the manual position and unlock the trunk.
2002 E39 520I DT21
VIN GZ11734 - M54 - 2,20l
Production date: 07.06.2002
Old 06-25-2015, 03:16 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Hose that key slot down with TriFlo.
Old 01-26-2016, 08:41 PM
Dukkhuli Dukkhuli is offline
Mein Auto: BMW
I have same problem at this moment it is not true that the key can open the trunk im trying for 10 min and wont open ill jump start tomorrow morning i gues that will hel sins the hud can be opened
Old 01-26-2016, 09:01 PM
Brandon002's Avatar
Brandon002 Brandon002 is offline
Mein Auto: 2002 530I Sport
The key will open the trunk. Its designed to. If yours won't something is stuck.
Old 01-26-2016, 09:04 PM
Mein Auto: BMW
It actualy did open it just nedet bit more force i was scared im gona break the key but is will klick if hou pres little more ***55357;***56397;***55356;***57339;
Old 01-26-2016, 09:13 PM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
This is what happens when you always use the remote. I manually use the key in all the locks at least a few times a year to make sure they all work, especially when the temperature starts to drop before winter.
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG (hello X7, and lottery!)
1999 BMW 740i - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 BMW 330xi - fXtXeX/son project time - still needs work but he's driving it
2008 BMW 335xi - quite the replacement winter beater for an Impala!
Old 01-27-2016, 08:56 AM
QSilver7's Avatar
Also...remember to lubricate your driver's door & trunk lock cylinder if you always use remote lock/unlock NEVER really insert the key physically into the lock cylinder.
Edjack mentioned using Tri-Flow in his reply from back in June/2015...I agree. But other lock lubricants can be used as well...especially something with graphite in it. I like Tri-Flow because it contains TEFLON...which helps smooth operations when two surfaces bind/move against each other.
Tri-Flow can usually be found at bicycle shops (many bike owners use it for their chains)...but you can also go to their website http://www.triflowlubricants.com/index to find local vendors.
(SOLD)
Old 12-01-2016, 12:24 PM
DelsFan DelsFan is offline
Mein Auto: 2007 525i
Thanks again!
Me too. Was out of town over Thanksgiving with lots of luggage and couldn't get trunk open. Called dealer, girl said to try the (old fashioned) key located in my fob (which I had forgotten was even there). I did, no joy. For some reason trunk started opening again with the remote on the fob, at least until we arrived home. Thankfully.
A week later it won't open for several days so I come here to see if I can get advice and I found at least how to get in the trunk: Turn key anti-clockwise 45 degrees until you feel the stop, then turn it another 45 degrees! I was really confused when I couldn't open the trunk manually with the key, but in fact I just wasn't turning it after it hit the first stop.
Still don't know why it won't open electronically, with the fob, or with my hand under the deck lid (it does make a whirring noise when I try and open it, but the latch doesn't release); maybe a little lube would be in order...
Idiocracy was a documentary...
