Old 07-06-2010, 06:14 PM
e39BMW e39BMW is offline
Mein Auto: 1997 BMW 540i
Battery light on, New battery, alternator is good
last night I came home from las vegas and the car had no red battery light on and everything worked perfectly. Today i went to pepboys to get some parts and once i restarted the car, the red battery light came on. At home i took out the alternator and drove it to pepboys to get tested and it passed all the tests. Cleaned everything off, put it back in the car and red light is still on. Then i did the OBC voltage test and at idle it was 14.4v (seems a little bit too high) and while reving at 4K it was 14.6v
The battery is less then 5 month old.
What could be the problem?
thanks
Old 07-06-2010, 09:12 PM
Spokane540ia Spokane540ia is offline
I need to replace what?
Mein Auto: 2002 540i
thanks
Maybe it will take a few sessions for your light to turn off.
Realize the "Battery Light" is all about the charging system- not about your battery. When you have a RED Battery light means your alternator charging system is not working right. You're running 14.4 volts- sounds like you alternator is fine, maybe you just need to run your engine a few more times to clear the code.
Clean off your battery posts once again. Tighten. Re post if you still have problems.
Old 07-06-2010, 09:26 PM
ganesht's Avatar
ganesht ganesht is offline
(oOO)\(lll)(lll)/(OOo)
Mein Auto: 98 528i 5 speed
i had a similar problem were i was getting 14v at the engine but was only getting 11.5 at the battery. after a ton of hunting around i found that the wire from my starter to the battery was partially corroded
on the i6 motors the pos cable goes from the alt to the jump point to the starter then through the firewall to the batt.
Alida:
Born: Friday, 9th January 1998
Arktissilber Metallic on Schwarz 528i/5
Fs: KAC-8103D, Kicker 08ts10l52
Old 07-06-2010, 09:35 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
+1. Check the wires that mount to the clamp that attaches to the positive post on the battery. On most cars (not sure on BMW) one of those wires is the "S" wire or sensor wire that feeds back to the alternator the battery voltage. If that is broken or not connected, the "batt" light will come on. A friend had this very issue on another make car...the wire was molded into the positive clamp, and unless you looked closely, it looked like it was still attached....it was not. He stripped the wire, and soldered on a couple more inches of wire, crimped on a ring mount, and bolted to the clamp, no more "batt" light.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 07-07-2010, 06:51 PM
Problem fixed. It turned out that the Fuse 15 was blown.
Old 07-07-2010, 07:10 PM
cn90 cn90 is offline
You might want to check oil level sensor:
http://www.bba-reman.com/content.asp...s_and_problems
Old 07-07-2010, 11:25 PM
why? how would that help?
Old 07-08-2010, 12:38 PM
ganesht's Avatar
-No transmission range display in the instrument cluster.
-Charge indicator lamp can flicker or it is permanently on.
-Fuse 15 (E39) is blown.
This can be due to a faulty oil level switch which can cause the fuse to blow. If this happens a loss of input to EWS from the Transmission Range Switch can occur.
Alida:
