Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 07-06-2010, 09:26 PM
cnotesdip cnotesdip is offline
Mein Auto: 330ci
BEWARE OF ICS Performance over 3k for a aa kit install
I brought my car in to ICS to have my New STG AA KIT 2 with meth injection. It took ICS about 3 weeks to install the kit i paid $2400 i had to get a replacement bov valve because ICS did not know how to fit the bov my kit came with, i drove the car home The EML light was on, i was running super rich so bad i got sick and i smelled like gas for days. The check engine light was missing it did not light up after inspecting the cluster i found half of the screws missing.
AA said it was a boost Leak ICS said it was the tuning. I brought the car back a 2nd time it was a line that was supposed to be plugged i was charge $100, i hit the highway EML light on i call ICS they say is the tuning bring it back in a couple of weeks. I hit up the forums e46fanatics to get some support everyone is telling me that is a boost leak, while driving the car i stop for gas and i notice my engine oil is low i add oil and the engine is building up pressure i never had a problem like this before, i brought the car up ICS again 3rd time i show The owner George the problem along with a broken door handle cable that was broken at ICS
This image has been resized. Click this bar to view the full image. The original image is sized 900x1200.
George says oh you need a oil catch can HPF sells one for $500 i can custom build one for $350, at this point i just want my car back running good so i tell him go ahead 2 weeks later the car is ready. This time i came prepare with a scantool i ask if the EML light is on? he says "no but the coils are bad and so the car goes on limp mode" i'm thinking to myself so yeah the EML light is on i asked to see the dyno chart
This image has been resized. Click this bar to view the full image. The original image is sized 1200x900.
is at 240hp i tell him is suppose to be in the 300s he goes on his iphone does some calculations and says oh is putting out 290s, at this point i know the car is not ready so i call AA right then and there to try to get this issue resolve i get Carl on the phone George says oh the car has a problem i have to fix it, he starts working on the car he does a compression test and the compression is good he does a boost leak check with the smoke machine and the car starts smoking from everywhere
Old 07-06-2010, 09:27 PM
Mein Auto: 330ci
Old 07-06-2010, 09:28 PM
Mein Auto: 330ci
at this point im thinking to myself the oil catch can is useless since it did not solve my problem and ICS wanted $450 for it i mean it was custom made and it looks like crap. The line that goes in the valve cover was now re routed to the oil catch can the line from under the intake manifold was plugged with electrical tape how efficient is that lol. So im told that the intake manifold has to be taken out to plugged all the lines under the intake manifold im thinking to myself this should had been done when the kit was install.
Mein Auto: 330ci
3 weeks later after no one was answering my calls at ICS and my car was not being worked on and it was a different story everytime i decide enough is enough i pick up my car to find a broken control arm bushing which i had replace a week before and a broken hood lever the one inside the car, and a broken dipstick which was replace with the wrong one.
Old 07-06-2010, 09:29 PM
Mein Auto: 330ci
Mein Auto: 330ci
Old 08-03-2010, 06:43 PM
tonytone4143 tonytone4143 is offline
Mein Auto: 740i
wow!! thats messed up
Old 06-12-2011, 04:37 AM
ICS ICS is offline
Account Under Review
Mein Auto: Turbo BMW's
No sir whats messed is that we have another internet wannabe mechanic, key board warrior.
This car was brought to me because he could not successfully install the super charger kit himself. When I first saw the car and the condition it was in, I should have declined the job.
The Kit was installed successfully by us, I called an informed the customer about the tight fitment of the BOV. I was asked what can I do ? I said contact AA or the other alternative would be to overnight a another BOV and have it welded on. He said get another BOV. The car was on the dyno and would not make the claimed RWHP.
I pulled the intake manifold after smoke testing the vehicle and found numerous leaks in which we repaired them successfully. Re-Dyno'ed the car better but still not correct.
Compression Test, Leak Down Test was performed. Everything checked out. Remember keep in mind guys Time = Money...
We were super swamped at the time, I told the customer the car has come issues that need to be worked out, our labor rate is $95.00 and hour. I will work on your car in between cars to hep you out financially as best as I can.
The customer would annoyingly call, call from blocked number, phone spoofing etc.
I ended up, installing new plugs, new fuel filter, drain the fuel tank, fuel pressure test, extended dyno time at N/C to him.
The Oxygen sensor were with 1/2 inch from each other welded into the dyno pipe... Such a sight I will never forget,
The customer called on a Saturday and was told NOT to take the car it was not completed. He decided to take his vehicle and blame us for the following.
Control Arm Bushing Torn ? (He improperly installed it himself in which caused failure)
Melted Torched O2 Wiring LOL (He installed the O2 Sensors and had the wring laying on the manifold.
Check Engine light bulb removed, we never removed the cluster no need, besides the car does not have any CEL bulbs, the Cluster has LED's
Broken door handle ? The car was delivered to ICS with the door panels dangling not even fastened !
We got blamed for breaking his dip stock handle in which came apart when checking the oil level.
But the Person to Blame should be himself. For wrenching on his own car doing a swap from Auto to Manual and creating issues and blaming everyone else for taking the the time to clean up the mess he started.. Again Time = Money.
I spent 12-15 Hours plus parts and did not charge the customer. We tried to help the customer. We have done many of these kits 1,2,3 successfully without any issues,... Why because the vehicle was un molested when it was brought in for a Basic Super Charger installation.
BTW the last invoice was written up by my Uncle who has nothing to do with billing, customers etc. He does light mechanical work and keeps an eye on the shop. He also told the customer to wait for me and not to take the vehicle.
It's very exhausting responding to one sided, one minded posts such as these.
Lesson learned never take in a POS vehicle such as this one and try to help the customer when he does not appreciate your efforts.
Old 06-17-2011, 07:07 AM
GG///M3 GG///M3 is offline
Mein Auto: Earth
This is interesting
Old 02-08-2012, 06:49 AM
StreetPro StreetPro is offline
Mein Auto: 530iA & Prado
are you sure about this point?
Old 07-30-2012, 09:22 PM
Rare-M\\\ Rare-M\\\ is offline
Mein Auto: 2001 M-coupe
I wouldn't do any work for someone who keeps their engine compartment looking like that!!!! Gross keep that clean... But nice baby toes with the bushing pic, 2 thumbs up!!!
Old 11-04-2012, 06:03 PM
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Mein Auto: 2008 335Ci
You should consider taking pictures of the cars at check in, and not with a cell phone. Hard to say you did something when you have pictures to back you up.
No matter how fast I go, there's always someone slower in front of me.
JB4 PNP .... Love at every stomp on the go pedal!
Old 03-17-2013, 04:36 AM
yomost yomost is offline
Mein Auto: yes
thanks for share
_____________
vietnam visa on arrival | Visa to vietnam | visa for vietnam
