Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 11-26-2003, 05:48 AM
kurti kurti is offline
Mein auto: bmw 520i
Question DIY changing coolant
I need to replace the coolant in a 1990 520i. Which is the best coolant to use for UK winter? How do I go about it?
Old 11-27-2003, 08:42 PM
kowached kowached is offline
Mein auto: 1998 540iA Sport
Official BMW Coolant top up procedure.
I would suggest a 50/50 mix of BMW coolant and distilled water. Drain from the bottom of the radiator and look for a drain or 2 on the side of the engine block, on the 520i I would guess that there would only be one drain, towards the rear of the block on the exhaust side, but thats just a guess.
My standard COOLANT blurb:
If you are going to spend the $ on the BMW coolant (82.14-1 467 704) consider using Distilled water ($1/gallon) as the 50% mix suggested by BMW. I just say that because the label on the BMW coolant touts how it was made with no impurities like nitrates or phosphates, why take the chance at adding contaminates back in with city water? I can guarantee you'll at least be adding chlorine and fluoride into your cooling system with city water. I have no experience with well water, but I’m guessing it would contain minerals that would precipitate out into your cooling system.
BMW does not specify the use of distilled water, they also don't specify any service interval for the power steering fluid, but I change that too. Why? Because both are cheap prevention. It cost me $2 more to use distilled water when I did the coolant service. $2 is not excessive. When paying $14 a bottle for the BMW Coolant that claims to be Nitrate and Phosphate free, if an additional $1 will indeed keep that bottle Nitrate or Phosphate (and who know what else) free in my cooling system, then I think I can spare it. If distilled water was expensive, I wouldn't use it, but it is so inexpensive I couldn't justify not using it.
BMW Coolant Product Description:
“This product is exclusively formulated and produced by BMW to protect your engine all year round.
It protects against freezing, boilover, corrosion and excessive silicate gel preciptation. This ethylene glycol based antifreeze contains no nitrites or phosphates, greatly reducing the possibility of harmful deposit formation.
This coolant is superior to off the shelf brands that contain phosphates. Your cooling system is expensive to replace so use Genuine BMW Coolant. “
http://www.bmwmotorrad.co.za/workshop/coolant1.html
Official COOLANT top-up procedure from BMW:
To ensure the cooling system is properly vented, it is absolutely essential to follow the steps below:
1. Undo cap but do not remove from expansion tank. This prevent excessive discharge of coolant from the expansion tank.
2. Turn on ignition.
3. Set heating controller to max. temperature.
4. Set blower to low level. This opens the heating valves and sets the auxiliary water pump in operation.
5. Run engine and briefly press accelerator pedal three to four times (approx. 4500 to 5000 rpm) to flush engine cooling circuit.
6. In doing so, do not run engine for longer than approx. 30 seconds; otherwise coolant will heat up and expand.
7. If the coolant level in the expansion tank drops in the process, top up the expansion tank to the max. cold fill level.
8. Screw on cap tightly and allow engine to warm up until thermostat opens.
9. Check coolant level. Pay attention to differing expansion tank designs.
Transparent expansion tank:
Allow engine to cool down before checking coolant level. Coolant temperature must not exceed 30***61616;C. If ambient temperature exceeds 30***61616;C, allow engine to cool down at least to ambient temperature. Check coolant level and if necessary top up coolant to max. cold fill level (see marking on expansion tank). Note: The tank mark indicates the fluid level at approx. 20***61616;C. Use recommended coolant only.
Black expansion tank:
Allow engine to cool down before checking coolant level. Coolant temperature must not exceed 30***61616;C. If ambient temperature exceeds 30***61616;C, allow engine to cool down at least to ambient temperature. Check coolant level and if necessary top up coolant to max. cold fill level (the ball on the float needle is on the same level as the top edge of the expansion tank). Note: The tank mark indicates the fluid level at approx. 20***61616;C. Use recommended coolant only.
Draining and topping up coolant
Unfasten cap on expansion tank.
M62
Release vent screw.
If necessary, remove front underbody protection.
Unscrew drain plug at bottom of radiator.
Unfasten drain plug(s) on engine block.
Top up coolant!
Replace all screws/plugs
M62 Slacken vent plug on expansion tank.
On vehicles with M52 engines, also unfasten additional vent screw.
Note:
Before filling:
- Switch on ignition.
- Set heater control to maximum temperature.
- Set blower to low setting. This opens the heating valves and sets the auxiliary water pump in operation.
Perform filling operation slowly.
Fill up expansion tank fully and wait until bubble-free coolant emerges from vent point. Close vent plugs.
bimmerfest 5-Series Welcome
Later,
Dave
E39 - 1998 540iA Sport (11/97 Production)
E30 - 1989 M3 (44k miles)
1979 Triumph TR7, still have my first car ;-)
Past cars:
E21 - 1980 320i (sold at 130k)
E23 - 1986 735i
Avatars under the signature are MUCH more prestigious than to the left of the post...
Old 11-29-2003, 07:28 PM
DSPTurtle's Avatar
DSPTurtle DSPTurtle is offline
MaxDH
Mein auto: 540i6
Nice post Dave!!! BTW... I have a 1998 540i6. Do I have a vent plug cause I have been unable to find it so far.
JB
Old 11-30-2003, 03:32 AM
Mein auto: bmw 520i
Thanx for that detailed reply. The 520i is my pet project in preparation for a cross- continent run at the end of 2004. I've not touched a wrench in my life and I'd like to be able to perform routine maintenance by then!
Old 11-30-2003, 01:53 PM
DSPTurtle's Avatar
MaxDH
Mein auto: 540i6
Do you have any tools? Might be a good time to hit Sears... Craftsmen tools are really the best value out there, especially if you buy a complete few hundred piece set!!!
JB
Old 11-30-2003, 06:40 PM
Yup, in front of the filler cap...
JB
Your vent screw is directly in front of the coolant reservoir cap, it has a black dime sized head with an "X" through it.
Later,
Dave
Past cars:
E23 - 1986 735i
Old 06-02-2007, 07:03 AM
boatingdobbins boatingdobbins is offline
Mein auto: 525i
I have an '04 525i and also trying to find the coolant bleed screw(s). Can anyone help?
Old 10-13-2007, 08:31 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator
Mein auto: Trek 6500 MTB
bump
2001 530i/5 (E39), Topaz Blue/Stone Green/Black
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred)
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
