7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
DIY - My new fog light LED Halo's ! Check it out !
Hi All.
I need to thank t_clealy for this as i saw it in his signature pic so decided to do the same. I basically bought 2 off 80mm LED Halo Rings off Ebay. The LED plastic rings come in white so i painted them Matt Black to hide them a bit better. Even better i wired them to the Main Halo Ring wiring (super easy to do) so all Halo's come on at once ..... and best of all .....NO CANBUS ERRORS !!! Here's the photo's i took .....(sorry i didn't have time to wash my car 1st) .... Finished result ...taken in broad daylight ...(the daylight is even too bright for my main halo's but they are ON) Halo Lights OFF - taken in daylight Halo Lights ON - taken in daylight ... Close-up of Fog Halo LED Ring Halo Lights OFF - different angle Halo Lights ON - taken at dusk ... Halo Lights ON - taken at night ... The above photo's don't do them justice.......trust me they look superb !
My BMW ACS7 ![]() Last edited by TechFreak; 07-13-2010 at 03:44 PM. |
Halo LED's
I think these look great! If I were to search on e-bay or if I wanted to buy them new what would the exact description be for me to search?
Scott |
I bought these.....$10.99 for 2 http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT Took a week or so to arrive ....am in the UK.... You wire them to the Main Headlight connector .....X130 in this pic : Wire positive to the single thinnest wire at the bottom of the X130 connector (Left Headlight wire - Gray/Green) (Right Headlight wire - Gray/Blue) Wire negative to an Earth/Ground Nut on the car chassis.... ..that's it !! . . .
My BMW ACS7 ![]() Last edited by TechFreak; 07-09-2010 at 04:10 PM. |
And you say they are pretty easy to install right..... Nice look by the way Tech....
03 745 Li//Black Kidney Grilles//MTECH V2 Lights//MTECH HID fogs
To install the LED Rings i followed the DIY to install/change the Main Halo bulbs to LED.....in post 2005 cars this invovles removing the bumper......but if you have a wire coar hangar you can feed the cable through....it's just a bit fiddly. If you also remove the foglights (only 2 screws) you can get your hand right up inside the car to feed the wires through.....
My BMW ACS7 ![]() Last edited by TechFreak; 07-09-2010 at 03:47 PM. |
Looks great! This will be my next mod along with the LED turns sigs front and rear.
Borbet 128's H&R Springs Shadowline / Sport Trim Dual Exhaust ACS Lip and Spoiler Fully Loaded
i just ordered one too ....man i think that look awsom ...after all 7 look is getting kinda old...
Just ordered mine as well. Thanks for the info TechFreak!
Are they plug and play or do you have to splice wires? The wire looks too short in this picture.
Approved |
I like it, how much were they and are they water resistant?
ONLY E66 IN THE WORLD RESPECTED IN THE STANCE COMMUNITY -STANCE APPROVED-
i like it!
'03 745i - modded - GONE - |
i just bought them TOO
http://cgi.ebay.com/ebaymotors/2x-BM...item3f011eb8ea
the AE's look super clean but i'm just not feeling the fog halos.
![]() E66 SAPPHIRE BLACK |
i think you are right, i like them on TECH's car but to be honest i dont think i will install mine ![]() i gotta see if i like them when they come in... and if they are as good as TECH says i will have to kep them.
This is what you get delivered....2 off 80mm LED Rings with LED on a white plastic ring : First ring painted with Grey Primer (paint both sides to seal it better): Painting second ring ...(just take your time and not paint the top of the LED itself) : First ring painted Matt Black : Both rings finished on LED side painted Matt Black : Finally on back of the LED Ring.....I desoldered the short wires and soldered longer thicker guage ones .....then paint the connections to seal them : To connect the RED wires to the Main Headlight Connector you just need 2 off Snap Fit Connectors which splice into the wires.....you only need one for each side...... Here's my Headlight Connector.......For each side Wire RED to (Left Headlight wire - Gray/Green) and (Right Headlight wire - Gray/Blue)....it's the bottom thinnest wire on the Headlight connector : The Black wire just goes to an Earth Ground Nut on the car chassis ...which there are several to choose from....
My BMW ACS7 ![]() Last edited by TechFreak; 07-10-2010 at 02:51 AM. |
Tech, i think you have to put low amp fuse in line with your new halo lights, since i dont think original line has one, and this rings not as good as factory sealed, and will definitely deal with water, this is just my opinion.
I am not going to install it in my car, less is more, and also i seen this rings before on that 53' trucks
Tech,
I think they look great! Clean install and a very good DIY write up. Nicely done.....
2007 750LI Barbera Red 2001 330Cic Orient Blue 2000 328i Jet Black(Sold) 2004 X3 Mystic Blue 2012 X3 Alpine White |
I'd get it but im afraid of the water damage and stuff, they should be more like internal lights not for outside use
Hehehe....Great job TF,
Thanks for the credit. They look awesome, bro. Love it. Beautifully done. Also the paint job is nicely done. Very well my friend. And thanks for the PM, the photos and all. ![]() It does look very nice, man. Good choice. Great deal. Cheers!!! t_clealy
THE ONLY STUPID QUESTION, IS THE QUESTION NEVER ASKED Beautiful car is hard find Beautiful girls are just around the corner.
Why not these?
http://cgi.ebay.com/Angel-Eye-Halo-C...item2a0593db54
My BMW ACS7 ![]() |
Oh so you like the audi look
I do but i definately don't think it looks like an Audi cos they are round....and definately not at night or evening when all my halo's are on.....
I was even considering coating them in Humi-Seal but thought i'd see how it goes.......worst case i pop a fuse or knack an LED ring which are super cheap to replace. Quote:
My BMW ACS7 ![]() Last edited by TechFreak; 07-10-2010 at 12:38 PM. |
#25
Hmmmm..i'm up in the air on this one...wish i could see them in person...if you get a chance, post a youtube clip of them at dusk/dark...Maybe we can get a better sense of how they look...Installed with double sided tape??
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes, LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
