Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 04-14-2004, 11:21 AM
PAGALM3 PAGALM3 is offline
Mein Auto: Jet Black 2002 M3
Thumbs up Thanks for all the info on the DIY!
Scott!
The DIY worked like a charm! My Bi-Xenon function is alive and well! There were a few differences since my fusebox was a little different, but other than that, everything worked! For the sake of not rewriting everything I did, here's the thread I posted on e46fanatics with some pics PAGALM3's Bi-Xenon Retrofit Success. Again, thanks for all the help & answering all my question!
  #27
Old 04-14-2004, 11:28 AM
RandyB's Avatar
RandyB RandyB is offline
Mein Auto: '09 E92 M3, '03 330i ZSP
That's pretty wild...
It cost you $719.00 and it's a $700.00 option from the factory. Glad I got them from the get-go because I doubt they would ever work if I retrofitted them!
  #28
Old 04-14-2004, 01:38 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Originally Posted by PAGALM3
Scott!
No problem; glad all worked out Ok
--Scott
  #29
Old 10-20-2004, 05:39 AM
Tichx Tichx is offline
Mein Auto: E46 1999 323i SE
Question for Scott
Originally Posted by Scott ZHP
Yet more photos...
Do I really need the fuse on Pin 30?
I only have a 12V relay with these pins:
87 - right bixenon
87 - left bixenon
85 - To Ground
86 - To pin 2
will this be ok? also my car is a RHD as I'm from London! please tell me the colour of pin 2 and 36 on the LCM, I assume I can tap into any of these?
  #30
Old 10-20-2004, 01:33 PM
Test_Engineer's Avatar
Test_Engineer Test_Engineer is offline
Drives cars for a living!
Mein Auto: 2011 BMW 335i
Old Speckled Hen Ale $34 Shangys Beer Heaven
I think this is the most important item on the list! BTW... GREAT BEER choice
  #31
Old 10-20-2004, 08:37 PM
Scott ZHP's Avatar
We want the Lion!
87 - right bixenon
87 - left bixenon
85 - To Ground
86 - To pin 2
Double check your relay or post a photo of the pins.
Pin 30 is the high current input lead and is ALWAYS present on a +12v relay; if you value your car, it MUST be fused.
If you are using a generic +12v relay, I'd guess you only have one 87 pin. It's fine to split the 87 lead and route it to each bixenon shutter.
You can use either pin 2 or pin 36 of the LCM to energize the relay coil (pin 86 on the relay). You only need one or the other. No idea what color the lead is, but the LCM pins are clearly marked in the carrier.
Yell if you need help.
