F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
F10 550i Valentine One Install ?
Hi all - just recently transitioned from an older BMW to a new F10 550i. I have a Valentine One radar detector that I had installed in the old car, wired to the switched power for the sunroof above the overhead lights, and positioned just to the left of the rear view mirror. It worked very reliably in that area.
With the 550, I'm trying to figure out: a) Where is the best place to put the V1 on the windshield? I've read some posts that indicate there is a coating on a majority of the windshield that limits radar transmission effectiveness.Has anyone else installed a V1 or other radar detector in their new F10 and solved these issues? Appreciate any help or feedback, and pictures are always useful - thanks! |
I just picked up a Cobra detector to use with my new 550 (too much risk of going fast without realizing it!). I used it for the first time today mounted with the supplied Velcro right on the dash. I can't say anything about hooking up power since I used the lighter outlet between the cup holders. After only one drive with it I will say that there was no problem with it picking up the random X band junk or the K band signals from the automated "Your Speed" signs. SO, without doing any formal sensitivity testing, it does not appear that the windshield is blocking any radar. Also, the Cobra has a GPS unit and it works fine receiving the sigs through the windshield and letting me know about red light cameras, etc.
Hope that helps a little.
2011 550i Sapphire Black, Cinnamon, Premium 2, Dynamic Handling, Sports package, Sports automatic, Heads up, Comfort Access, Cold weather, Smartphone |
Any answer here? I'm in the process of doing the same thing, and I'm thinking of popping the cover off the moon roof console to grab power. But how? Anyone?
I purchased a mini fuse tap from Autozone (similar to this one). I plugged it into the #57 fuse location (have to double-check this number, was a 5A that didn't seem to be linked to anything based on the call-out in the trunk) with an added 2A mini-fuse in the glovebox that is switched power linked to ignition on/off.
I couldn't see any screws that were grounded, so I wedged the ground lead into a joint in a metal box to the right of the fuses that is grounded, and taped down the wire with electrical tape. This step was ridiculously difficult - there is no space to see/work behind the access panel to the fusebox in the glovebox. I ran the cord out the back of the glovebox, up around the headliner (where it joins the windshield), and across to the left side of the rear-view mirror to the detector. At some point, will take a photo or two. Last edited by f10_owner; 07-30-2010 at 08:01 PM. Reason: Clarified explanation, corrected fuse # |
Can you check which fuse location you used? I'll try 5, but would rather use one that is known working.
As far as ground, remove the side panel on the dash (between the dash and the door). Once open there's plenty of place to work. If I cannot find a screw I'll just drill a hole in the metal bracket next to the glove box. Jeff |
How does one remove that side panel? Would make things much easier.
Will check on the fuse location this weekend - thanks. |
The side panel just pulls off.
And yes, let me know which fuse is switched with the accessory. The Germans are crazy, first the place for the fuses is insane as it takes tiny hands, and next I find most things are not necessarily switched from the accessory. ie - the radio always seems to have power. it turns off when you turn off the car, but you can turn it back on without the accessory on. so that fuse doesn't work. what else? i've tried 1/2 dozen. Last edited by blulite; 07-30-2010 at 06:17 PM. |
With a fair amount of force? Would appreciate a photo halfway removed or similar - mine didn't want to budge.
I used the #57 fuse - it has nothing associated with it, but it turns on with the ignition. Last edited by f10_owner; 07-30-2010 at 08:02 PM. |
Where is fuse box? in glovebox on right side of dash?
Yes. There is a removable door in the glovebox. Behind it is the fuse panel. There is another fuse panel on the right side of the trunk, attached to it is a folded up document which lists the fuses and their functions.
2011 550i Dark Graphite/Oyster Black, Sprt Trns, SP, PP1, PP2, DAP, CP |
How do you get to fuse #57? Can't even see it. How does that dash panel come off? Been tugging at it and it won"t budge.
Now, just one thing: Fuse 57 DOES NOT WORK, is not even wired at all. I tested almost every fuse (like 2 hours) until I found FUSE 48. Easy to reach and is switched by the main on/off start button. Enjoy your install! |
Please don't spread misinformation. If you have a 550i, then Fuse 57 works.
Sorry for the confusion. |
Sorry to drag up an old thread...
Did this install on a late 2011 520d M Sport Touring F11 using fuse 48 (if I have read the diagram correctly) but I tested the fuse tap as suggested by powering on the ignition with fuse 48 (5A) removed. Radar detector worked but iDrive screen blank. Replaced 5A fuse into fuse tap slot A and all OK, except that I now get an error on iDrive: passenger restraint system error. You should use the seatbelt and get the vehicle checked...
I can't seem to clear it! I realise (now) that I probably shouldn't have powered on the car with a missing fuse in slot A of the fuse tap, but I wanted to check that I had wired it correctly. I removed the fuse tap but error still present. Any ideas? Thanks. |
I installed my V1 with the super easy tip (that I found via Google somewhere) using the power port that is under the dash by the passenger foot well. Took me all of 10 minutes.
On my E60, I cut into the sunroof wires and had no problems, but I always hate to mess with the car's electricity, especially since BMW is so quick to void warranties.
2008 535xi 6-speed - Blk Sapphire, ---2011 535xi - Jet Blk, Blk Dakota, Blk Dakota, Bamboo Prem | Cold Wthr -- Aluminum | Prem | Prem 2 | Cold Wthr Sport | iPod/USB | Nav | Sat --- -------Sport | Sport Auto | Fold Down Seats Fold Down Seats | Htd Rear Seats -- ---Side/Top Cameras PDC | 18" wheels | Logic7 (Good riddance!) |
Ditto. I did same plugging into the outlet in the fr passenger footwell. Ran the cord in the seam between the dash and windshield so it is fairly clean looking.
Now i need to reset my v1 to pick up k band again . Previous benz had distronic which constantly emitted k band radar. (i am presuming that the blind spot warning system in the F10 does not set off radar detectors but would love confirmation) |
Thanks. Yep, saw that but alas my F11 has the place for it but not wired (is it a UK thing, a 520 thing (cost cutting), or maybe a 2011 build thing?). So, went for the next easiest thing (fuse tap) so no evidence of me being there - well so I thought (apart from a nice error now on the iDrive)!
Ok. Trip to local dealer and error cleared (so far). They said the error only showed once and reset it an did "a full vehicle check" also. All done in less than an hour and nearly £45 later the error is gone. They said fitters sometimes remove the side panel with the passenger air bag key switch in it to help with the fitting. I replied, yes the fitter must have done that as I saw it on the floor (ehhhmmm. That was my mistake then - to remove that panel)!!
| Bookmarks |
| Tags |
| 550i, f10, install, radar, valentine v1 |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
