Old 07-11-2010, 08:14 PM
just bemmers just bemmers is offline
Mein Auto: 740i 318i
740i Transmission fail safe message
hi there my fellow bmw buddies i am new to the forums so just be a little patient with me i have a 1995 740i with 240000 on the tranny i keep getting this annoying trans fail safe (u know the message ) i took out my engine module by mistake and noticed that it had be tampered with (open) so i took it to the shop and was told that my tranny computer is not talking to my engine computer (what!) another shop told me that was impossible so i took it back to the orignal shop i was then told that there may be an electrical problem with the trans module (stop the madness)can any one point me in the right direction away from this shop that i have been going too to a good one so i can bury this tranny problem!
Old 07-12-2010, 12:01 AM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
i could honestly be quite a few things. like your were told, possibly the computer. it could also be as simple as a shift selector switch or wiring. at worst it could be the trans going out.
you will need to take it to a mechanic that actually knows what they are doing. there are a lot of ok mechanics out there, but knowing the ins and outs of BMWs are not quite as simplistic as some other vehicles. a lot of people will try and scam you though so be careful and definately get other opinions!
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 07-21-2010, 03:27 PM
YAH YAH is offline
Mein Auto: bmw 740i
i have 1995 bmw 740i that gives me the message: trans fail safe ; can anyone please help me as to what this code mean
and (2),can some one tell whats best laptop auto diagnostics software with the correct version that i can buy to scan this obd 1
bmw 740i that have.
any help appreciated.
thank you
Old 07-26-2010, 12:42 AM
scellpt scellpt is offline
Mein Auto: BMW 2003 735I
Came home yesterday parked all is fine start car this mornin trans failsafe on abs on asc on and dbc also on wat the hell is going on can anyone help me please.
Old 07-26-2010, 01:45 PM
balance balance is offline
Mein Auto: 97 740iL
I've heard of crazy things happening with low battery voltage, so my first reccomendation is to get the charging system checked out, starting with the battery.
Old 07-26-2010, 02:30 PM
did that already battery is fine jus came from my friend house and now all is back 2 normal so now am even more scared its loke a bomb jus waiting till am in the middle of nowhere to leave my ass, but the truth is a BMW will always bring you home.
Old 07-26-2010, 03:47 PM
Mein Auto: 97 740iL
I'm sort of in the same position in regards to transmission failure. I've been having issues with my tranny holding gear for the past month, and I'm having that "BMW paranoia" as well.
If your tranny failsafe came on, it should have stored a code in the computer. Unfortunatly, only the dealer and some specific BMW shops will have the round scanner to attach to the connector in the engine compartment to read the codes though. Hopefully it was just a one time thing on your car.
Old 07-26-2010, 05:56 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
several reasons why transfail safe mode kicks in
1)bad alternator
2) dying battery
U can check those 2 by opening up OBC#7 on your cluster
car idling should be around 12.2v-13.9v
turn engine off but leave key postion 1 ...battery should be 12.0v and higher
3) low transmission fluid.....
4) 99-2001 have ABS/DSC control module that go bad and when they do "Transfailsafe " kicks in
but u hav 1995 so ignore #4
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 07-27-2010, 04:00 AM
No I don't have a 1995 I have a 1999 735I and yesterday after work I stoped by my friend and wen leaving all was fine , then this mornin the problem is back .
Old 07-27-2010, 01:44 PM
Please tell me this is possible .. Can my car set the time and date on its own. Yesterday i took off the negative battery pole and that resets everything so the time was not set i drove 2 work 2day failsafe came back on after work still on went to friend house spend 1hour leaving and all is fine but the time and date remain not set, so i stoped in a store return some items and wen i start again failsafe didnt come back but most amazingly the time and date was set perfectly and i hope its possible or their is a ghost in my car.
Old 08-12-2010, 12:27 PM
I pulled the wire harness off of the ABS pump and gess what the tranny failsafe did not come on again as long as i keep it off, but i can still drive the car but there is no ABS ,ASC,DBC as all these lights remain on so i no now its the ABS module so thanks alot. Now am trying to get someone to repair it as a new one cost
Old 08-12-2010, 02:40 PM
Mein Auto: 97 740iL
Thanks for taking the time to reply as to what fixed the problem, I'm sure it will help someone later on. Just don't go crazy on any corners, and keep your distance in the rain, and you should be alright without ABS until you get it fixed.
Old 08-12-2010, 10:06 PM
tommyb2b tommyb2b is offline
Mein Auto: 1998 BMW 740IL
If I were you I would get one off a parts car.
Old 09-22-2010, 06:39 AM
does anyone know how 2 change my front brake pads i have a 1999 735i sport and i think the calipers used on my car is the 750il calipers these are sport looking and big. AM unsure if i should hammer the 2 pins in front of me out or release the four 10mm hex , or it might be alan key bolts.
Old 09-22-2010, 08:18 AM
Mein Auto: 97 740iL
It has been a while since I changed my brakes, so I don't remember what style caliper BMW used, and I'm not sure if the 750 uses the same style. But whatever you do, do not dissasemble the caliper. Take a good look around the caliper and do the least amount of steps to take the pads out. If there are pins going through the caliper and the pad, take the pins out and the pads should come out once you push the pistons in. If the caliper covers the pads, then there should be two bolts holding the caliper to the caliper bracket that need to come out. Remember that you need to push the caliper pistons in before putting the new pads on the car. You can use a c-clamp or a giant pair of channel locks. And most importantly, DONT FORGET TO PUMP THE BRAKES BEFORE DRIVING THE CAR.
It should be easy to tell if you have 750 brakes in your car once the pads are out. 740 calipers have one piston per caliper while 750 calipers have two.
Old 09-22-2010, 02:59 PM
thank you i checked and my calipers have 2 pistons per side of caliper and the pins are in the front of the caliper i see wat u mean the pins need 2 be punched out and it will release the pads. thanks 4 your quick reply as i went 2 the store 2 day and bought tools 2 disassemble the whole caliper.
Old 09-24-2010, 12:59 PM
does anyone know how to open the abs module i want 2 see inside to try and repair my old one.
Old 03-08-2013, 01:45 AM
w7oshy w7oshy is offline
Mein Auto: bmw 735il 98
does battery can make this error cause i think i have problem with battery how can i be sure if that it's battery problem!!
Old 03-08-2013, 02:14 AM
http://www.bimmerfest.com/forums/sho...d.php?t=679705
Old 03-08-2013, 02:38 AM
100% sure it's not the battery
Old 03-08-2013, 02:44 AM
If the asc or abs lights up its the abs module and u don't need a new trany , BBA reman repaid mine .
Old 03-08-2013, 03:37 AM
thanks for replay is , BBA reman a shop ? cause I'm very far away
i want to know how to know what is cause this failsafe issue cause all shops here said that i need new transmission without even do any test !?
does this error codes could lead to something
sorry the pic over pig size i think forum admin should install image resize MOD
Old 03-09-2013, 09:53 PM
gsxrfxr gsxrfxr is offline
Mein Auto: 97 528i, 99 740i, 00 740i
i got the TRANS FAIL SAFE msg last week + just a ASC light is been on all the time on my 99 e38, battery is been replaced so i know its not that, i just replaced my ABS module tonite with the used one (exact part #) but from an 01 e38 ASC light did not go away when i started the car but i am hoping once i test drive it in the morning it goes out so i dont have to get it Coded from the dealer.
Old 03-14-2013, 12:19 PM
jh53 jh53 is offline
Mein Auto: 2000 740i
To GSXFXR:
I was in the same exact boat you're in... 2001's won't work. The module has to be coded by the dealer, or you can send yours in and have it rebuilt. I have a 2000 e38. I had mine rebuilt at Module Masters. You take it off and mail it to them. It takes like a week... $300.00 with warranty/satisfaction guaranteed or your money back. Much better than the sticker price to replace with a new module. Here's the link to the company: http://www.modulemaster.com/en/index.php
I highly recommend this company and I'm sure others on this forum can vouch for them as well. What a GOOD feeling, everything working right again! hope that helps you out like it did me!
Old 03-14-2013, 02:54 PM
JJ740 JJ740 is offline
Mein Auto: 99 740IL
Replace the Battery! These cars get wacky when the battery goes bad
HTML code is Off
