Old 07-16-2010, 11:37 AM
pervenets pervenets is offline
Mein Auto: BMW
Hiss/static/crackling noises in all speakers
Please HELP. 2003 BMW E66 LOUD Hiss/Static/Crackling noises in both front door and rear panel speakers! Noise comes and goes, varies from really loud crackling to loud hiss and then silent. Noise migrates from one speaker to another or can be present in all. No matter if CD/Radio is on or off, if engine is running or not-the noise is there all the time and it sounds very much like the sound in between the radio stations when you tune the radio. Does not seem to interfere with neither radio nor cd (music just plays through the noise and seems otherwise sounding clean and clear with all frequencies present). Logic 7 seems to also work properly with balance/equalizer/fade controls all functioning properly but through the noise. The whole thing started from light hiss in the rear panel speakers and the next day migrated to the rest of them. Noise starts immediately when I open any of the doors or trunk and stops approx 2min after key is out everything is closed and all lights are off. Tried disconnecting the battery and and connecting pos and neg terminals with the jumper, removed and checked all the fuses, performed reset for the MOST-nothing worked. Any advise is appreciated.
Old 07-16-2010, 11:48 AM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
am,p
Old 07-16-2010, 12:10 PM
Mein Auto: BMW
Which amp?
Old 07-16-2010, 12:17 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Ummm....logic 7 AMP....Search the Forum
Old 07-16-2010, 12:24 PM
Mein Auto: BMW
Already went through the forum...Logic 7 only affects rear speakers and subs isn't it? If it's logic 7, then what's up with the front door speakers? When digital amp goes isn't it permanent??? In my case noise can completely disappear for like 5 minutes while driving and listening to cd or radio, why do you think that is? Thanks
Old 07-16-2010, 12:28 PM
Mein Auto: BMW
By the way, I visually checked the logic 7, looks brand new. No signs of water damage, no burnt components, cleaned all contacts just in-case and placed it back.
Old 07-16-2010, 12:51 PM
DFEL750I's Avatar
Mein Auto: 750I
Didnt read the entire post was just responding to the amp question. If its coming from all speakers then most likely is your ASK (CD player) that as gone bad. The fact that it goes away once in a while would indicate that most likely its not a physical wiring problem but the unit itself
Old 07-16-2010, 12:55 PM
Mein Auto: 745li
question is the cd player not working? is the radio and cd changer working?
Old 07-16-2010, 01:00 PM
Mein Auto: BMW
Just realized, it is only midrange and tweeter speakers located in the front doors and in the back panel that produce the noise. All the rest play clean sound including center speaker all the subs and speakers located in rear doors! Is it the ASK unit? How can I check to make sure??? Thanks
Old 07-16-2010, 01:05 PM
Mein Auto: BMW
All systems are working just fine, except for the noise !!! CD, CD Changer, Radio, Navigation, Voice command......ALL works but that Loud NOISE is killing me!!!
Old 07-16-2010, 01:47 PM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
Did you see if cooling fan working inside?
Old 07-16-2010, 01:56 PM
Mein Auto: BMW
Nope, I did not notice if it was working or not, I did not really look for it.
Old 07-16-2010, 03:58 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
your SOS might be interfering with your sound system
same thing happened to me and the dealer turned off the SOS sytem and all was good (knock on wood)
'08 BMW 535i - Sport - Sport Trans - JB4 - Catless DPs - Intake - E85 -
'07 SUZUKI GSXR-750 - Gray/Black - Akrapovic Titanium Exhaust -
'03 BMW 525i - Sport -
'98 Ford Expedition - 5.4L - 4WD - Eddie Bauer - 8 seater -
'03 BMW 745i - GONE -
'09 HONDA CBR600RR - GONE -
Old 07-16-2010, 03:59 PM
Mein Auto: BMW
Just noticed when MOST loop is disconnected whatever was playing goes off (Radio or CD), CD Changer starts flipping through disks but Hiss is still present!
Old 07-16-2010, 04:05 PM
Mein Auto: BMW
That SOS thing sounds interesting, did they just reset the SOS module or did they shut it down completely? What this SOS module is responsible for, do you know?
Old 07-16-2010, 04:45 PM
Seven11's Avatar
President
Mein Auto: BMW
its the button u press if u are "in trouble"
Old 07-16-2010, 08:11 PM
flyboy50dabo55 flyboy50dabo55 is offline
Send a message via AIM to flyboy50dabo55
Mein Auto: 2004 BMW 745 LI
How do they reset it?
Old 07-16-2010, 08:28 PM
Mein Auto: BMW
looks like SOS is not a separate module as I could not find it with trouble code scanner, there is like 45 separate modules to diagnose and reset trouble codes, but no SOS. Does anyone know where to look for it either through the scanner or physically? Thanks
Old 07-20-2010, 02:41 PM
RON7165994 RON7165994 is offline
Mein Auto: 2004 745LI
DO YOU HAVE TO PROGRAM THE ASK WHEN IT IS REPLACED?????????
Old 07-20-2010, 04:49 PM
Seven11's Avatar
President
Mein Auto: BMW
some people got away without programming and others needed programming
same thing with a logic7 amp
Old 07-20-2010, 10:16 PM
sooky sooky is offline
Mein Auto: 05 745LI
I'm having the same problem crackling noise in speakers ,lil bit of bass that goes in and out.not full bass.I just assumed its the amp for sure but was advised do not replace the logic 7 amp with a after market amp.
1)WILL THE dealership replace a amp if the car is under extended warranty with easy care?or is that considered wear and tear
2)I'm in the nyc tristate area anyone knows of a good shop to repair this issue and not the stealership?I tried looking for someone that does electric repair work to maybe repair the amp than replace it.
any help works.I really don't trust these low budget stero shops in bronx and queens.they don't cover anything if something wrong and I don't trust them picking around in my car like its a damn honda accord
Old 07-20-2010, 10:50 PM
diznik007's Avatar
diznik007 diznik007 is offline
Mein Auto: Kubota on 48's
you need to check the fine print in your policy with easy care to see if your amp is even covered. with aftermarket warrantys, you generally have to pay a few hundred extra for a electronics/audio/speakers/nav coverage. the dealership will replace an amp whether your covered or not. as long as they get paid.
E66 SAPPHIRE BLACK
Old 07-20-2010, 11:01 PM
Mein Auto: 05 745LI
i figured i pay the deductible and the after market company pics up rest of the bill
Old 07-20-2010, 11:21 PM
diznik007's Avatar
let us know what happens. just looked at the special elctronics coverage that was offered with my policy (mercury) and it makes no mention of amplifier. it only covers GPS/Navigation System; Night Vision system; and Video components including TV/VCR/DVD/Video Game Player. you may be covered.
E66 SAPPHIRE BLACK
Old 07-21-2010, 08:21 AM
Mein Auto: 05 745LI
i read that a few people had there old logic 7 amp repaired at a electronic shop.anyone know of a shop in nyc or somewhere to mail it out to be fixed?
how much would the dealership charge to just find out the exact problem not fix it??
crackling, grounding, hiss, speakers, static
