E46 (1999 - 2006)
Old 07-17-2010, 01:45 PM
Dunatic12 Dunatic12 is offline
Mein Auto: 325i
SES P0414 Code
I recently replaced my valve cover gaskets, spark plugs, O2 sensors, Oil separator, intake gasket and all oil separator lines and now have this code "secondary air system valve A circuit short" code. I have tried finding how to troublshoot that particular code but have been unsucessful, can anyone direct me to a place that will point me in the right direction?
Old 02-13-2014, 10:59 AM
MiguelH28 MiguelH28 is offline
Mein Auto: 2003 X5 3.0
I am having the same problem. I'm curious to know if you figured it out?
Old 02-13-2014, 01:02 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
The e46 wiki has a good write up and trouble guide for SAS. Almost sounds like issue with vac switch on back of intake manifold.
Either in maintenance or engine sections. Also a pic of the back of the manifold in the engine section.
http://www.bimmerfest.com/forums/sho....php?p=8014505
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 02-13-2014, 03:32 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
That code is your secondary air pump valve switch fault. Does your air pump kick on in the morning when you first start the car for about 2 minutes? You'll hear it, it is pretty loud.
