X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
#26
But you said you didn't have the knowledge or the skills. The difference between not being ABLE to and not WANTING to is the whole issue. I find many people say 'their time is too valuable', and perhaps it is. But if you have the time to go to a shop and wait the 45 minutes it takes, or for an oil change you waste a half hour dropping it off and a half hour picking it up, you are saving no time. Again, if you can do it but choose not to because you don't want to get dirty, or your time is more valuable, these are all valid in my book. Not knowing how isn't. JMHO. |
#27
The reason I did it myself was not so much about my time, but about the knowledge and confidence that if the proverbial s**t hits the fan (dark, rainy, spotty cell coverage, not a friendly neighborhood, AAA over an hour away, you name it), I can change the tire under half an hour and be on my way. Exactly the same reason I've demanded, and watched, my wife change the tire in our driveway. Just my 2 cents...
#28
Dear All,
Two questions: Is it ok to use a generic floor jack on the X5, in the location where we are supposed to use a BMW jack (mine didn't come with a jack or spare)? If not, a jack from a 2004 X5 should be ok, right? If I use a jack stand, do I put it under the axle of the tire I just removed? Thanks, Walt |
#29
http://www.ecstuning.com/ES251251/ Several companies sell similar products. |
#30
A floor jack would be better IMO. This way you could get both wheels off the ground at the same time. Be careful when using jack-stands, most of the suspension bits are aluminium. I would suggest putting the jack stand at the other jacking point.
Try a floor jack in the rear and a jack stand in the front. This usually works on my 3 series to get one side off the ground.
I switched to Conti DWS 20" from Dunlop's using local Discount tires and I'm told to rotate side to side for 50K warranty in spite of staggered setup. Since then my steering wobble at high speed and breaking in spite of re checking the balance and alignment. Does Michelin Latitude HP's behave the same on X5? or this is the nature of non RFT's? Much thanks
2012 X5d...with all possible pks & flowers...
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
