Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here.
Old 09-21-2011, 03:50 PM
mzeed mzeed is offline
Mein Auto: e46 m3
I really think this may only matters at the high end of towing capacityand with excessive tongue weight perhap with towing a race car , horses or AirBus/Travel Trailer.
My x5 diesel has standard no frills rear with no excessively expensive goodies that will need to be ordered and replaced in 5 or 6 years. ....(Unlike my old VW Touareg with Multilpe Electric Differential Locks and Air Suspension which all needed to get serviced at my expense for corrosion). If you are not leasing, I will remind you that expensive goodies are expensive to repair and VW banged me for over 2K to repair that nonsense....hense the BMW. If you tow frequently with far distances think diesel. BMW's is Phenominal for a 6 Cyl.
Towing a snowmobile trailer with a tongue weight of 175 lbs (or a boat with 135lb.) I do not notice any sag or change in handling characteristics. Honestly, I do not even know I am towing with out using the mirrors and seeing the trailer. If your trailer does not have brakes , Braking is what will be most noticeable in the X5 (as well as all the others)
Old 04-29-2012, 08:29 AM
bujjai bujjai is offline
Mein Auto: X5D 2011
hey did bmw do this? can i install a hitch without cutting the bumper???? if so....i'm finally going to do it.
Old 04-29-2012, 08:43 AM
YuCrew YuCrew is offline
Mein Auto: 2012 X5 Premium
Bumper cut
On my 2012, using Drawtite/Reese hitch ... the cut was ~2.25" x ~8.25", only visible from BENEATH the vehicle.
Unless your eyes are BELOW the height of the bumper or on your back on your creeper looking up, you will not be able to see the cut, even if you remove the hitch later.
Old 09-24-2012, 01:27 PM
crsx5d crsx5d is offline
Mein Auto: 2011 X5d
Originally Posted by flymikeair View Post
attached is pictures of the hitch installed on my x5 the plug is a little crooked i need to get another screw to make it sit right. The top pic shows the modulite box installed. Pretty simple as it turned, out just had to tap the light wires and a simple volt meter let me figure out which was which. I'll post the directions for which wires tomorrow so everyone can save them selves the trouble of the testing to find the wires.
I think now that I look at it I might just cut a hole in the fascia to mount the plug so it's out of the way and will have a nice clean look to it
I'm new to the tow hitch and trailer thing so pardon me with these simple questions. I read through many posts on aftermarket tow hitches and decided to go with a Curt hitch and 119191 ModuLite HD Protector. The only thing is that the modulite is a 4pin connector and the car trailer I was looking to buy needs a 7-pin connector (electronic brakes). So I would need a Hopkins Wiring - 37185 4-7pin adapter and a separate brake controller?? Or does my car have a brake controller wire I can tap into? Thank you.
Old 11-29-2012, 04:26 AM
BeamerandBimmer BeamerandBimmer is offline
Mein Auto: M5, X5 50i M-Sport PP
Looks like no one ever gave you an answer.
You can get the wiring kit AND a brake controller from BMW to go with your aftermarket hitch.
Current BMWs
2013 Carbon Black X5 50i M-Sport
2010 Carbon Black M5
2010 R1200GS Adventure 30th Anniversary Edition
Past BMWs
2007 Graphite K1200GT
2008 335ia
2005 545i
2004 R1150R
2003.5 M3 Cabrio
2000 540ia
1997 M3 sedan
1997 540ia
