My E60 Windshield Washer Leak Repair
Suddenly my 2006 525xi began leaking windshield washer fluid leaving puddles near the front drivers side tire. I did some poking around and found several posts for previous models that were extremely helpful. So, after successfully repairing my leak, I thought it would be nice to share some info.
Like previous models, the windshield washer pumps and reservoir are tucked behind the front section of the wheel well on the drivers side. So I removed the tire and removed all the small hex screws in the front section of the wheel well until I was able to peel back the wheel well enough to gain access to the reservoir and pumps. I added some water and found the leak to be coming from the black section of the bottom of the pump. I was hoping it was just the grommet, but for me it ended up being a slight crack in the pump. I disconnected the wiring and slid out the pump (with a bucket under the car) and lower grommet with strainer. I took the pump and grommet/strainer to the dealer and luckily, they had both in stock. Pump was $44 and new grommet was $2.75. Put it all back together and it's been fine ever since. Seems like a flimsy setup though. I can see why some others have added wire ties to keep things in place.
I have attached 2 images hopefully someone will find useful.
