E46 (1999 - 2006)
Old 07-20-2010, 10:48 AM
Alex Phillips Alex Phillips is offline
Mein Auto: 2002 325CI
Anyone DIY - Power Window Switch Replace in Middle Console??
I took my car on 1,800 mile journey from NY State (Utica-area) up to VT, NH and Maine. I had no problems with the car except the driver's side window switch in the console broke. The motor for the window works as you can have the window go up/down through the door lock by holding to the right or holding down the unlock button on the key.
My biggest challenge is how do you unloosen the central console and/or remove the stickshift boot/top. I can't imagine putting a new switch in it's place is that hard. On my Dad's old 1989 535i, the center console had clips which held it in place, you had to use a screwdrive to pop it out.
Any thoughts/suggestions. I can get the switch at the dealer.
Alex
Old 07-20-2010, 11:36 AM
wdaveweaver wdaveweaver is offline
Send a message via MSN to wdaveweaver Send a message via Yahoo to wdaveweaver
Mein Auto: 2004 330i ZHP
Very easy. Just pull on the boot (if you have auto) upwards gently and the center portion will pop out. You will then have access to the screws holding down the trim that the switches are in.
Gig'Em Ags
Old 07-20-2010, 11:52 AM
Any difference in the steps/process if you have a manual transmission. Basically do you pull the top shift knob off?
Old 07-20-2010, 11:56 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
No need to pop the knob off; just remove the shifter boot bezel and pull it up around the shift knob.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 07-20-2010, 12:24 PM
Thank you!! I am going to give this a go tomorrow night after work!
Thanks again.
Alex
Old 07-20-2010, 04:10 PM
Getsmmr Getsmmr is offline
Mein Auto: '03 330i
Many a fester have given themselves a bloody lip or a black eye when pulling up on their shift nobs for the first time and having it suddenly release. Keep your face out of the way! You can't really hurt anything except your face/ego by pulling to hard if it's a manual.
Old 07-20-2010, 05:55 PM
I got the part from BMW Arlington, VA today for $61. The "cost" price for the dealer was like $30.00. Crazy mark-ups.
I followed the instructions given and I had a new window switch in within two minutes and it works. Thanks everyone. I guess I probably just saved myself $50-100 plus I felt good about fixing it myself.
In a few thousand miles I will try doing my spark plug replacement, maybe!!
Old 07-20-2010, 11:24 PM
B1scu1t B1scu1t is offline
Bimmer Rookie
Mein Auto: 2004 325i
OK, my additional question to this is... My drivers window is the only one that does not do the one touch open. I have to hold the switch. Plus the switch feels "loose" in it's slot. Will changing the switch give back my one touch operation?
Also, when the window is going up there is a click or clunk every now and again. I am guessing window regulator?
Old 02-19-2011, 09:46 PM
zpablo zpablo is offline
Mein Auto: 199 z3
I need t he same help. My windows will barely go down when the temp get below 30. If I do not help the drivers side window going down it stops before it gets all the way down, then the one touch will not work for a while. I told my parts man and he gave me some white plastic things he said will fix the slow window problem. I can't try them now becasue my drivers side switch is jacked up. going to keep an eye on this post.
zpable
Old 02-19-2011, 11:12 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
zpable
I have a feeling you`re posting to the wrong forum....is your car even an E46 ? If not, go to the Main Forums page to determine exactly where you belong (by year & model). You`ll get better answers if you ask in the right place.
The road goes ever onward....
(R.I.P. Jever)
Old 07-29-2011, 06:47 AM
DDailey DDailey is offline
Mein Auto: BMW 325ci
Replace all windows switch
Alex - Thanks for the info.
