E36 (1991 - 1999)
Old 07-27-2010, 11:42 AM
EROC_328 EROC_328 is offline
Mein Auto: '96 328is
Ok maybe I will try higher fuses before contacting DDM for a new ballast. The thing is I have been running with the 7.5amp fuses for around 6 months now with no problems.
Sport pkg./ADR version II wheels/H&R sport springs/Bilstein shocks/K&N CAI/OEM M3 exhaust/Shortshift
Old 07-27-2010, 12:16 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
I had 7.5 amps and i was perfectly fine... idk mannn :/
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 07-27-2010, 03:07 PM
the_brouhaha's Avatar
the_brouhaha the_brouhaha is offline
I run as fast as my car.
Mein Auto: e36 coupe
I have the same problem... but my headlights aren't aimed properly, so with one out it still looks like they're both on, so ha! I win!
Freude am Fahren
Flickr Album!!
Old 07-28-2010, 07:52 AM
Ok so I tried putting a 15 amp fuse in and that blew immediately. Looks like I will be getting a new ballast from DDM.
Old 07-28-2010, 09:32 AM
Tom Nguyen Tom Nguyen is offline
Make your own Luck
Mein Auto: Lexus
I think I need a new ballast too. The pass works now stil not driver side tho.
1998 328i -SOLD- 06/06/2011
Handful of things I don't need Check it out:
http://www.bimmerfest.com/forums/sho...d.php?t=551778
Old 07-28-2010, 11:04 AM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
Try and bend the fuse hold in so it grips the fuse tighter. This is a problem if its loose because it creates too much resistance and thus blowing fuses. I can almost guarantee this is your problem especially since you've probably put a few fuses in and out of the holder.
Old 08-02-2010, 05:16 PM
Make your own Luck
Mein Auto: Lexus
Okay old thread...but when I put in the ballast from the pass side to the driver side the lowbeams still nothing. I think the driver side ballast and bulb is out. Anyone ever had this problem?
Old 08-02-2010, 07:18 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Tom, did you try both the ballat and bulb that you know work? It may just be a wiring issue. Make sure that the harness works, isn't shorting out somewhere, then go from there.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-10-2013, 04:58 PM
M20_FrEAk M20_FrEAk is offline
dirt3
Mein Auto: 1993 325IS, 1989 F-150
im having problems with my dj auto light assembly, on the cover over the low beam where the ballast and AE gets plugged in there is no hole to feed wires through, did anyone else have this issue?
GFY- nuff said
drive in the snow with bald tires they said, it will be fun...they said
Old 01-11-2013, 08:34 PM
kptaylor kptaylor is offline
Mein Auto: '98 323iS, '99 528i
Yes, you have to drill a 7/8" hole. You feed the wires through that and use the rubber grommet to seal up the hole/wires.
Click here for instructions.
