E46 (1999 - 2006)
Old 07-20-2010, 02:18 PM
LemonLyman323i LemonLyman323i is offline
Mein Auto: 2000 bmw 323i
How often should you change spark plugs?
I have a 2000 323i which I purchased used about two years ago. I'm just wondering what type of maintenance I should be doing with my spark plugs (replace/inspect...etc) and how often. Since it is used I do not know the last time they received any attention. Any insight would be greatly appreciated. Thanks!
Carpe Diem
Old 07-20-2010, 03:04 PM
akhbhaat akhbhaat is offline
In vino veritas
Mein Auto: German Civic
I did the plugs in my last E46 (323i) at 59k miles.
My current E46 (330i) has 62k miles on the original plugs. Frankly, I think the 59k was a bit premature. Most evidence suggests that BMW's claimed 100k service interval is reasonably accurate in this instance.
What's the mileage on the car? If you're not sure if/when the plugs were changed, you could always change them for peace of mind--or even just pull one out and look at it.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
Old 07-20-2010, 03:49 PM
jzwu jzwu is offline
Mein Auto: 2005 330Cic
OP's car is ten years old. If the plugs are still the orginal ones, I would say change them. Technology ten years ago was probably not that good.
Newer platinum plugs should go for 100k with no problems.
Old 07-20-2010, 06:53 PM
Ricardj Ricardj is offline
Mein Auto: 2004 320i
The dealer recommends to change them about every 100K miles. I changed mine at around 145,000 km (just over 90,000 miles) and noticed a huge improvement in how smooth it ran. The original plugs were a little black with some tiny bits of debris on them, but weren't in horrible condition. I should mention that before I changed them, I thought the car ran just fine.
Old 07-20-2010, 07:22 PM
Yeah the car has 134000 miles on it. I'm not sure if they have been changed, but I guess I will pull them and take a look. Anything in particular I should be looking for when I look at them? I have also heard some about "re gapping" plugs.
Carpe Diem
Old 07-20-2010, 07:23 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
every 100k for e46, I just did mine before the motor blow at 157k. orginal plugs, they looked alittle worn, but the car still ran fine just like ricardj
Old 07-20-2010, 10:24 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
No go, Joe. Unless things were very different way back when the plugs were installed in yours, recommended plugs have four ground electrodes surrounding the center. So unless you have some special tool which I can't even imagine (which the maker surely has at the plant), there's just no way you're ever gonna get them regapped. Shown are the stock Bosch (BMW labeled) from my '06. NGK's are the same.
"Gapping plugs" is probably registered in the Obsolete Skills Database...
Name:	VANOS rebuild4.jpg
ID:	239073   Click image for larger version
Name:	VANOS rebuild5.jpg
2006 325Ci
Old 07-20-2010, 10:46 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
I'm admittedly old school in my maintenance beliefs and change the oil at 7.5K and the plugs at 50k. (half of what the manual says)
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 07-21-2010, 05:57 AM
Cliff Cliff is offline
TMS
Mein Auto: 2015 Golf R
I replaced mine at 96k miles. They were due. In hindsight, at $60 for the parts, it wouldn't have hurt to do them sooner. Mike Miller suggests 60k miles in one of his blog entries.
2015 VW Golf R: (pic)
Old 07-21-2010, 06:55 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
I did mine at 88k or so and they looked like Cliff's plugs. Use NGK plus and my diy vid.
Old 07-21-2010, 11:44 AM
catso's Avatar
catso catso is offline
catso
Since you bought the car used and don't know the maintainance history you should change them. Plug boots too probably. Change all the fluids too (trans, differential, power steering, brake, anti freeze) and fuel filter. Start off fresh and you'll avoid problems down the line.
Old 07-21-2010, 01:29 PM
e46_platform e46_platform is offline
Mein Auto: 2002 330Ci 5M sport
interesting website
Old 07-21-2010, 01:51 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I'd say 80-100k miles. I changed mine at 112k miles, they could have gone longer. Again at 190k miles with the new E3's because I had a gift certificate for them.
Old 07-24-2010, 09:28 AM
Thanks for the responses everyone I plan on changing them asap. I will be using this DIY which looks to be very thorough. Good luck for anyone who decides to do their spark plugs also.
Carpe Diem
Old 07-24-2010, 10:29 AM
catso's Avatar
catso
It's uber easy!
Old 07-25-2010, 06:14 AM
shadow 2 shadow 2 is offline
Mein Auto: 2011 335ix
Is one brand of plug favored over the other?
Old 07-25-2010, 08:10 AM
golforcars325i's Avatar
golforcars325i golforcars325i is offline
Mein Auto: 2001 325i
NGK is the OEM plug.
