Old 07-20-2010, 06:24 PM
orbatrin orbatrin is offline
Mein Auto: 2006 325i
Exclamation Replacing battery triggered Seat belt/Airbag
Need Help.
I replaced the battery in my 2006 325i with an Autozone Duralast battery and after starting the car up, my display showed that seat belt and Airbag light is on. I know both items are in working condition but seems to me that replacing the battery/disconnecting the terminal caused the fault lights to come on. Does anybody have the same issue or a fix for this? perhaps a reset? Thanks for your help.
Old 07-20-2010, 08:37 PM
mclaren's Avatar
mclaren mclaren is offline
Chairman of the Bored
Mein Auto: 2014 M5
There was a thread quite a while ago about replacing batteries and how something had to be done to tell the computers it had been replaced or it wouldn't charge properly and other problems.
Old 07-20-2010, 08:41 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
the positive battery cable has a pyro explosive in the terminal connected to the airbag system. I am betting you disconnected the cable by accident. Make sure all wires are plugged into the terminal/ on the side of the terminal.
and yes you should have the dme informed of the new battery being installed, worst case if you don't the veh will burn out that battery prematurely
Old 07-21-2010, 03:21 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
I think you meant to say "the airbag system has a pyro explosive connected to a cable to the positive battery terminal", but, other wise, yeah.
Unless I have to worry about the battery cable going off.
Old 07-21-2010, 05:51 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
My understanding is that these cars need the computer to be told that the battery has been replaced - basically the computer monitors the battery and charges accordingly, if the battery is replaced with new, the computer needs to know or otherwise it may charge it incorrectly. I have read posts that others have had to replaced the replaced battery within months as it was being over under charged. Not sure if this senario would also lead to warning lights on the dash also, maybe disconnect the battery again and let it sit for a bit and see if the lights come back on or if they go out after a day of driving, otherwise it is probably a trip to the dealer
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 07-21-2010, 12:29 PM
I disconnected all cables including the green and red cable connected to the plastic assembly located on the battery. Once I installed a new duralast battery, I plugged everything back in as should. The seat belt and airbag light has been on for two days now. I will attempt to register the battery at the shop and see if that fixes the issue. Is anybody aware if their is a fuse in the black container located on the battery assembly?
Old 07-23-2010, 08:47 PM
dean2c's Avatar
dean2c dean2c is offline
Mein Auto: 08 E92 335i
Originally Posted by Zooks527 View Post
...Unless I have to worry about the battery cable going off.
Sorry if you already know this, but I couldn't tell from your post. The black box on top of your positive terminal is the "battery safety terminal", which has a small pyrotechnic charge that fires in the event of an airbag deployment. I believe it is intended as a safety measure after an accident to reduce the risk of an electrical fire. This post shows one post-deployment: http://www.e90post.com/forums/showthread.php?t=6313
When it goes off, the hazards, BMW assist telematics, and other low-draw circuits remain active, but there won't be enough current to start the car.
08 E92 335i, 6MT, Space/Saddle/Gray Poplar, ZPP, ZSP, PDC, CA, 6FL, nav, heated seats
ED 9/5-9/11/08, PCD 10/22/08
ďAn explanation of cause is not a justification by reason." --C.S. Lewis
Old 07-23-2010, 11:01 PM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
Hmmm... interesting point.
In theory, it cuts all electrical power (and the engine) so you don't have a small spark that ignites a fire after a crash. Yet, the hazards go on... doors unlock... BMW Assist calls for help... How? Do those subsystems have another electricity source?
- Mike
I am fortunate to have unique press cars delivered weekly, but I own:
'16 BMW X5 xDrive35i M Sport 8AT
'15 Volkswagen Golf TDI 6MT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... my E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Read my work as Editor-in-Chief for Autoweb and Autobytel!
Old 07-24-2010, 04:23 AM
BerfsBimmer's Avatar
BerfsBimmer BerfsBimmer is offline
Boosted Bavarian
Mein Auto: '08 335Ci
There are two hot (+) cables. One handles high current items (alternator, fuel pump and starter) and has the pyrotechnic device (battery safety terminal) that detonates when the crash sensor activates to remove power to those items. The other cable handles the low power and emergency equipment, like BMW Assist w/collision notification, the hazard flashers, interior lights/auto emergency door unlock, etc.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=93468&dateline=1203123566
'08 E92 SpaceGray/Gray/Burl/ZSP/ZPP/ZCW/Step/Nav/CA/6FL/HD/Original HPFP
Old 07-24-2010, 07:21 AM
Please see my original post. What went wrong when I changed batteries and why did it trigger seat belt light and SRS lights? If I register the battery will it fix the issue? My black box did not explode and my car starts up even better now with the new battery. Any suggestions?
Old 07-24-2010, 09:33 AM
Emission's Avatar
Thanks for the insight.
- Mike
Old 07-24-2010, 09:36 AM
Emission's Avatar
Your problems started when you disconnected the old battery. It simply sent an error through the system as the safety equipment had losts its power. You need to have the codes reset. Should be as good as new after that.
- Mike
Old 07-24-2010, 09:53 AM
chasvs1201 chasvs1201 is offline
Mein Auto: 07E92/Blk/Spt/Prm/Nav/Stp
- Mike
So if I simply remove the negative terminal to do a steering wheel swap I'll need to have it reset? Reason for disconnecting the battery is because I'll be removing the airbag as part of the process.
Old 07-24-2010, 04:02 PM
marinekilz's Avatar
Noone Special
If you changed the battery, the airbag light should not come on. The BST has connectors and cables connected to the positive terminal, I would make sure all the connectors are plugged properly into the positive terminal. That is where your porblems lies, or if you connected the battery, turned on the key before you plugged the other connectors in would also set the light. I would just have the faults deleted and the battery registered before you get too worried. And NO registering a battery will not fix a airbag system problem. Once a airbag fault is set, all you can do is delete the fault, disconnecting the battery will not reset the airbag system and shut the light off
Old 07-24-2010, 04:09 PM
Ryan M Ryan M is offline
Mein Auto: .
I couldn't tell you how many batteries I've changed at work. I've never had an airbag or seatbelt light come on.....let alone both. Something is wrong because they shouldn't come on simply from disconnecting the battery.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 07-24-2010, 04:25 PM
marinekilz's Avatar
Noone Special
I had it happen once, but I accidental pulled out a connect that was in the positive cable on a x5. plugged in the connector, had a shop with a gt1 delete the faults and the car was good to go.
Old 07-24-2010, 07:58 PM
Emission's Avatar
I think once the fault is triggered, it needs to be reset from the outside (I don't think it will "self-reset").
- Mike
Old 07-25-2010, 09:59 AM
Mein Auto: .
Correct, the airbag light will not reset without a tool.
Old 09-18-2010, 11:41 AM
kfeehan kfeehan is offline
Mein Auto: bmw 530 xi
Changed battery and warning light came on
Had same problem put in new battery for 530 xi and the seat belt/airbag warning light has been on ever since. Can I buy a tool to reset, found on for earlier models but not 2006. Anyone know where to go to get one....hate the dealerships!!! Also this was about 8 months ago, should I be concerned the system isn't working, is it wrecking the battery? Runs fine except for light!
Old 09-18-2010, 05:25 PM
RaceBlood's Avatar
RaceBlood RaceBlood is offline
Mein Auto: 2007 335i Coupe 6MT
How can you hate a dealership? We are talking about safety here, not a air filter. You buy a BMW for all the things that make it a BMW, highly engineered and safety, then you discount the safety feature in order to avoid a dealer? My dealers in Chicago kiss your ass and win your business by doing it right, we have 7 in a 100 miler circle...
Thats plain idiotic, and your insurance company will not lay a dime for your injuries if you have purposely faulted the safety systems, not to mention all your broken bones...
2007 335i|Space Gray|Coral Red Leather|6 MT|Sport/Premium/Cold Pkg|Logic 7|HK 300W|Xenon|Hankook V12's|M3 Rear Lip Spoiler|M-Tech Front Aero Spoiler| M-Sport Aluminum pedals| M-Sport Shifter| BMWCCA
