Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > New Member Introductions
Welcome to Bimmerfest! Whether you are a current BMW owner, shopping for a new or used BMW or just interested in cars, we hope you enjoy your visit. Take a moment to introduce yourself and post a picture of your BMW for the rest of the Bimmerfest BMW community to see.
Old 07-22-2010, 05:18 PM
beardstaff beardstaff is offline
Mein Auto: California
E34 540i Where is O2 sensor #2 located? Passenger side or driver side??
I have a 1995 540i E34, with 180,000 miles + the check engine light goes on after driving for about 10 minutes but does not light when I first start car. The stomp test came back with 1212 code, O2 sensor #2.
Just failed smog, check engin light went on, tester staed rich nitrogen output was the problem.
Few Questions:
Since I have two O2 sesor on this car, which one is #2 (driver side or passenger side)?
Besides the O2 sensor what else can be causing this check engine light code 1212?
I have listen for any hissing from engine to see if there were any vacum leaks, and did not hear any.
Once I identify which O2 sensor is #2, I will replace and drive for ahwile to see if the check engine light will register an error and light up. If it does not I will take car in for a smog retest.
Looking to identify which side O2 sensor #2 is located, driver or passenger side to start.
B
Old 07-26-2010, 12:12 AM
CDirks's Avatar
CDirks CDirks is offline
Is a real boy
Mein Auto: White 1997 328i
Welcome to the 'fest. If you don't get any helpful replies on this forum try posting on the e34 forums if you haven't already. Good luck !
